Question about MyMusix PD-6030 MP3 Player
Music does not sync......={
I tried to put new music in my mp3 from my windows media player but it said stopped and it doesnt put the tracks in it what can i do?...
  • 8,596 Answers
Make sure the songs are in the correct format. Make sure the songs are not AAC, WAV, streaming, or some other non-supported format. Good info should be available from the user's manual for this product, which can be acquired at www.mymusix.com
Mp3 players are more complicated than ever. This player may only accept DRM-encrypted WMA files. I would first check the songs that you have downloaded to make sure they did not have "temporary" licenses with a fixed end date. You can do this by right clicking on an individual song, clicking on properties, and selecting the "license," "digital rights mgmt" or "media usage rights" tab - the wording varies by configuration. It will give you info on the license. If the song says that it has no license, it will not work with this player. One remedy is to use mp3 converter software to convert all of those wma files to Mp3's - I don't know of any free ones, but you can certainly look for free Mp3 Converters. Another remedy on unlicensed songs is to hit the "acquire license" link in the license tab, if one exists.
-Tha Mp3 Doctor
Posted on May 24, 2008
6ya staff
SOURCE:
How do you add songs on device
Hi atiug b...
Downloading Music to MP3 Player
1...You must download and install Windows Media Player 11 on your computer.
NOTE...Some older MP3 players will not work with Windows Media Player 11 or Windows 7 with Windows Media Player 11.
If this happens to you, then you will have to uninstall Windows Media Player 11 and install Windows Media Player 10.
2...After you have downloaded and installed Media Player on your computer.
3...Open Media Player on your computer.
4...Install all your music into Media Player that you want to install on your MP3 player.
5...Plug in your MP3 player to the computer using your Data/Sync cord, be sure that Windows Media Player is on.
6...Media player should recognize the MP3 player and sync with it.
7...After it is sync'ed with the computer,you can add the music you have installed into Windows Media Player to your MP3 Player.
Free Answer...Please take time to rate me
Jun 11, 2011 | SanDisk Sansa Clip MP3 Player
How do I put music onto my new Innovatek premium Edition mp3
Hi taylor91...
Jun 02, 2011 | Audio Players & Recorders
I copied my music into the music folder, but when i disconect from the computer, the player says that the music isn't there.
Try importing your music into Windows Media Player.
Hook up the mp3 player, make sure all appropriate drivers are on the machine, open Windows Media Player. Windows Media should see it as a device and you will be able to sync songs by either selecting individual tracks and dragging them to the icon of the MP3 player (in the left pane) or syncing all music to the device.
To import custom music folders on a Windows 7 machine:
Open windows media player
right click on the "music" icon
select "manage music library"
Chose the "add" button on the right side
Find and select your folder.
All of the songs in that folder will be pulled into the music library and you can sync from there
Mar 08, 2011 | SanDisk Sansa e270 MP3 Player
Have put music on mp but wont play
check the format of the music. if problem is not solved then when transferring the music to the player transfer it one by one
Mar 13, 2010 | Philips GOGEAR SA6045 MP3 Player
My Phillips Go Gear 8GB MP3 player wont sync music
Windows Media Player 11 ruins this player. Uninstall Windows Media Player 11, and roll back to Windows Media Player 10. Then use version 10 to sync songs to your device.
Sep 11, 2008 | Philips GoGear HDD1830 MP3 Player
Cant put music on it
You can format the player in Windows Media Player itself.
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Apr 09, 2008 | RCA TH1101 MP3 Player
Mp3
format ur music player i the settings menu, this will delete all the music on the player, or plug in and delete off the playlsit on windows media player
Mar 12, 2008 | SanDisk Sansa Clip MP3 Player
Unable to sync music
What happened when you tried to sync? it could be a device certificate error...what i would recommend you to do is to sync using your windows media player...assuming that you have windows media player 11...open up your windows media player and click on sync..then you can drag the tracks you want to sync and then click on start sync...if you are not able to transfer the songs to it..use a song that is not from yahoo like the sample one that came with your computer and see what happen...if that doesnt solve the problem check your usb mode..it should be under MTP mode or auto....then open up your windows media player and format the device there...after you have done that..that should solve the problem you are having..let me know what the outcome is....
Jan 06, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Sony walk man mp3
try these methods
**Drag and Drop**
Connect your MP3 player to the computer. Some MP3 players connect directly to a USB port, while others connect to a USB port by way of a specific USB connector that comes with the MP3 player. Open the folder on the computer that contains the music files you want to transfer. This is usually the "My Music" folder, available from the "Start" menu, but it can be any folder where you save your music files. Scroll down to the song you want to transfer to the MP3 player. Right-click on the title. When the options are displayed, click on "Send To." Scroll down the "Send To" options and select your MP3 player. This can be listed as your MP3 player's name or as "Removable Drive." Click on this selection. Continue this process until you have transferred all songs that you want to your MP3 player.
--**Windows Media Player**--
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Mar 23, 2007 | Sony DNF420PS Walkman Personal MP3/CD...
Adding music/software install
THREE things to check and do 1. xp 2sp must have it! 2. The model designed for media player 10, or download imesh. is free and more faster than media player. 3. if it is full delete at least 2 songs from the database of the 512 mp3 player. It easily get crazy when is fully loaded
Jan 25, 2007 | Samsung Yepp YP-T7JX MP3 Player
MyMusix PD-6030 MP3 Player Logo
53 people viewed this question
Top MyMusix Audio Players & Recorders Experts
Damen Wong
Damen Wong
Ekse
Joe Negus
Joe Negus
Are you a MyMusix Audio Player and Recorder Expert? Answer questions, earn points and help others
