Question about Toto Aquia II Dual Flush Toilet
How do i replace the tolet seat - Toto Aquia II Dual Flush Toilet
  • 37 Answers
The seat has two bolts that go straight thru the bowl at the back of the seat just loosen the nuts on bottom of the bolts replace same way you took it off
Posted on May 10, 2010
New tolet and 540 flapper leaks into bowl replaced with new 540 flapper and it still leaks
Check if flapper is correctly installed,. check if it doesn't have some "protective" sticker which should be removed before installing it. Check that the chain or rubber ribbon should not be tense and rraised.
If everything looks right, return that defective flapper to the store where you bought it and get a new one.
Nov 09, 2015 | Home
Looking for parts for kohler tolet
Lowe's and home Depot or any other hardware store
Sep 28, 2014 | Home
Self closing all in one tolet seat boxed, hidden screws, how to tighten
If you are trying to install a standard toilet seat on a special "smooth sides" toilet, it likely will not work. Most hidden bolt toilets come with a special seat because you cannot get to anything from below. This special seat has a set of expanding style bolts that are attached to the screw that is part of the seat. The plastic expanding bolt goes into the hole(s) on the toilet, and as you tighten the screw on the toilet seat bolts, they expand the plastic part in the hole of the ceramic toilet.
Aug 29, 2013 | Kohler 3386-6 Rialto Skylight Round Front...
97bmw my top dont workwhere is thecontrol tolet my top down ,, and should it make a noise to work,
The control unit for your top is below the rear seat/under top boot cover. You're going to need a BMW dealer to look at it because the motors have a specific sequence to go through to make top operate. Trust me you DO NOT want to attempt this yourself.
Feb 21, 2011 | 1997 BMW 328
The side mount for a tolet only 92762 works only upside down
thats cause they have a right and a left hand
Nov 16, 2010 | Home
It take about three time for the trip lever to flush the tolet what my trouble shooting for this
The round thing in the center that the metal rod pushes down on can be turned...turning it counterclockwise will make it higher and get you flushing...
It may take a bit but you can get it adjusted so that it will flush everytime..
heatman101
Aug 07, 2010 | Sloan M-101526-F42 Flushmate?® Complete...
After the tolet is flushed it will make a hissing nose for along time.What can I do to cure this?
It might be the issue with the valve from where the water gets in the tank, get the washers replaced, or you might want to open it and clean it a little.
Regards,
Jul 14, 2010 | Toto Toilet Onepiece Ultramax ...
Dishwasher not working and rinse aid and eco light flashing.
you must fully fill rinse agent close the door raise the door up and down 3 times then add more liquid tolet out the air ,repeat until fully filled then turn on hot water until it get the hottest THEN START THE MAVHIN. problem should be solved.
Mar 02, 2010 | Dishwashers
Jucuzzi era bk 37 959 just installed 6 weeks ago , I have to use
when it was installed the wax ring was most likely installed wrong or has moved and is blocking drain it cost 5 or 6 bucks to replace. thank you for for useing fixya please rate me
Feb 26, 2009 | Jacuzzi Bath Era BK37 959 White toilet...
Toto Aquia II Dual Flush Toilet Logo
170 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
