Question about Refrigerators
GE Monogram ZIS36 Side by Side refrigerator built-in about 15 years old. Defrost problem. Freezing compartment has ice running down the sides. Both refrigerator and freezer work fine. I have cleared the drain tube of debris and cleaned condenser. Problem persists. Do I replace: 1. Defrost Control 2. Drain Trough Heater 3. Defrost Heater 4. Defrost Thermostat It seems as if the Defrost Heater is working fine, otherwise the icicles would not be running down sides of freezer and entire freezing compartment would be frosted (it is not frosted).
5 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Posted on Oct 15, 2008
  • 1169 Answers
SOURCE: GE Monogram Built-in Refrigerator Side keeps freezing
Sounds like a faulty thermostat. Try replacing it with a known good one and retest.
Posted on Apr 20, 2009
SOURCE: Defrost problem with GE Monogram ZISS48DAASS 48 inch side by side
I have ge monogram POS model zisw 42. Had the same problem. Poor design is the issue. Drain tube exits the case of the exchanger, is strapped to top of frig box, then up and over the pullout glides for the compressor. Water has a hard time running up hill. Stuff collects in the tub and blockage and or major restriction occur.
GE fix: replace defrost timeer to run longer,( so much for energy savings...nothing like runnig a heater full time in a freezer to keep ice cream soft) replace ss heater tray with one made of AL to conduct more heat. This fix worked for a while, then problem reappeared.
MY fix: Buy 2, 90 degree 1/2 inch fish hook style elbos, gray in color, at the local hardware store..see where PVC fitting are kept, Cost was less $5.00. Plus about 12 feet of 1/2 inch clear tube...about $6.00. go back home. Cut drain tube at top of box at about where it was attached, mid way between the pullout tray with the copressure and where it exits the freezer/exchanger box. Fit one elbo, point to the rear, add new clear line long enough to exit the rear of the frig case. Add 2nd elbo, pointed down, keep it close to the back of the frig. Add additional clear line to chase the drain line down through floor or wall such that the drain tub is now dripping it's waste water (very small amount really and under no pressure) outside the house. This fix has worked for about 10 years.
Posted on Aug 11, 2009
imufo2
  • 3773 Answers
SOURCE: Problem with the GE Monogram
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 18, 2011
My GE Monogram side by side built in refrigerator will not freeze ice or keep food frozen. It stays just under the freezing temperature. The refrigerator portion seems to work. Can anyone help?
its possible that its either short of gas or the little fan motor in frezzer/fridge is not working,but if its only making ice now and then its sounds like a gas shortage
Aug 28, 2012 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram ZISW36DYA ... frozen ice-cycle rivulets run down both sides of freezer (water off for days to verify it is not ice maker) ... defrost control clicks when rotated and advances with time ... do...
Seems to me that might be a clogged defrost drain or maybe a dripping water valve. Doing that. I have the service manual with nice pictures in it that show clearly how to access the components.
GE MONOGRAM SERVICE MANUAL
Nov 10, 2010 | GE Monogram Side by Side Refrigerator
Fridge temperature has suddenly dropped to 15
Check the door gaskets, condenser fan, refrigerator fan and the freezer fan. That should narrow down the problem.
Dec 03, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
I have a monogram zis 42d side by side the freezer section works but in the defrost mode the unfrozen ice runs down the sides of freezer and into ice cube storage container, I have cleaned out the drain...
I have this same problem. Now, the freezer will not get cold enough, but still water runs down into the ice bin and just turns into a big solid block of ice. The water is dripping from the top of the freezer compartment. I have disconnected the water coming to the refrig to not allow it to make ice, but still happening. Please post if you have found a solution? Defroster issues?
Nov 09, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Ge Monogram built in side by side. Water and Ice
You can do it yourself if you feel comfortable, Here is a service manual for you that should help out. 31 9091 GE Monogram Side By Side Refrigerator pdf
Jun 10, 2017 | GE Profile PSW26P Stainless Steel Side by...
Vegetable and meat draws freezing everything temp@16 deg. f.
Turn your thermostat down. If all the rest of the food was even 45 degrees, it would be okay. The vetable and meat drawers will always be colder, so you set the level for the rest of the fridge at what is tolerable.
May 14, 2009 | GE Monogram Refrigerator Built-In...
Apr 20, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Ge Monogram ZISS420DMAS compressor and fan not running
ICE CREAM WON'T FREEZE
The ice cream does not freeze, it stays soft. I have a GE Monogram 42" Built-in-Side-by-Side Refrigerator.
Nov 28, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
GE GSH25JSTA SS side by side fridge not cooling/freezing
In most cases it is the Defrost timer circuit. One of three things the Defrost time (most likely) it allows the cooling for a 6 to 10 hour period and the defrosting for 10 to 30 minutes to remove ice buildup, ICE BUILDUP is the main problem as it restrict air flow, the cooling air circulation through the system. You see cool air only comes in the freezer side and passes through vents (pass ways) to the refrigerator side. Ice buildup in the freezer side inhibits cooling air to the refrigerator side. You think the freezer is working, but it is only cooler because there is ice in there that you can't see. The Terminator (a LIMIT switch) opens the defrost circuit if the defrost heater gets too hot (second likely) the next is the Heater which heats for those 10 to 30 minutes to melt the ice buildup (least likely) no matter the Unit you have they all have this circuit... Hope this helps, I'm Tango
Jul 26, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
Jul 17, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
Refrigerators Logo
117 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
