Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Looking to reset the password
I have a Sears Garage Opener Model 139.53962SRT1 The keypad Part #53975 is not working. I figured the battery needed to be replaced. Still not working. I wanted to see if there is a way to wiped out the old code and start from default.
    President:
  • 3,197 Answers
You can wipe out the old code and start from scratch. Locate the smart/learn button on the rear of the motor unit near all those white wires. Press and immediately release this and then walk over to your keypad and key in any 4 digit code you like and press enter. Your keypad may have just quit working though.
Posted on May 10, 2010
How do I reset my keypads outside? My battery
There is no reset. You can try programming it and see if that works. If not it is probably dead.
On the rear of the motor unit you will find the smart/learn button. Press and immediately release this and then walk over to your keypad and key in your four digit code and press enter.
Oct 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do you change the access code for the 53975 craftsman garage door opener thanks
If you mean the code for the keypad do this:
Press and immediately release the smart/learn button on the rear of the motor unit near where all those white wires go and then walk over to your keypad and key in any 4 digit code you like and press enter.
Oct 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remotes quit working on Craftsman 53975 garage
It sounds like you have a logic board problem. If your remotes work at all it is not a programming problem. You could pull the logic board and check for loose connections especially around the small transformer. 18 years for an opener is very lucky. Their average life is about 1/2 that.
Oct 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
OLD garage door opener
Sounds like you have the keypad that is hardwired.
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
These instructions may not work if the keypad is some other manufacturers.
Aug 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
My outside Craftsman keypad will not open the door but will close it.
Most likely if the opener will close the door, but not open it, the springs are fatigued enough to where the opener is exceeding the force limits established. If the door is really heavy the opener will not open it as a safety precaution.
The keypad is probably fine, but you need to have a professional garage door repair technician come out and take a look at the garage door hardware! Repeat: Do not work on the springs yourself!
Apr 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad opener outside garage seems to be "dead." Batteries? AC?
Press and release the learn button on the opener. Then within 30 seconds enter in the 4 digit code followed by the up/down button. Thanks BB
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Key pad won't open garage door
You probably have an eletrical device that is messing with frequency. Make sure that everything is off inside garage.
Jan 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad garage door opener will not operate
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
Dec 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears craftsman keyless entry for model 139.53684
If I am correct, there is a green button on the opener. Hold that down until it stop blinki ng. Once it has, pres the opener. It should read the code and work the next time you hit the opener remote.
If not, sorry. This has worked for me
Jun 01, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
187 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
