Question about Garden
6 HP Tecumseh Engine won't stay running
I have a Murray string trimmer with a 6 HP Tecumseh engine. I went to start the engine this week and it won't stay running. I have to prime it 12 - 14 times to even get it to crank, but then it only runs for a second and cuts off. I added Stabil to the gas before I stored it for the winter, but I went ahead and emptied the gas tank and carburator bowl, put in new gas, put in a new air filter and a new spark plug, J19LM. It still does the same thing...runs for a second and then cuts off. Any ideas? It has always been a little hard to start even when it was new.
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
I can not keep my weedeater running?
Mark, Ensure plug is good, remove,inspect replace in tn tank fuel filter if clogged, remove muffler and clean screen in side, carb., carb. could be dirty or out of adjustment or diaphragms worn out and needs rebuilding. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
http://support.mtdproducts.com/app/answers/detail/a_id/10666/~/basic-troubleshooting---handheld-string-trimmers-(gasoline-powered)
Toro String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Jun 11, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
What weight of oil is used in Ariens st622 string trimmer with a tecumseh 6hp motor
Since this is used in the summer any good grade is SAE30 oil will protect the engine..no need for muti viscosity oils..good luck.
Oct 02, 2014 | Ariens Wheeled String Trimmer - 946152
6 hp tecumseh engine wont stay running
What you are more than likely experiencing is a blockage in a passage in the Carburator. Cleaning the Carb will take care of your problem
Apr 09, 2013 | Garden
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
Carburators are not getting fuel
have a murray 20 hp tecumseh has gas in the bowl but wont start unless u spray the carb then it dies when u stop spraying any ideas
Apr 14, 2011 | Tecumseh Enduro VTwin Vertical Engine with...
What type oil and what level should I put in my 6-7yr old Murrary riding garden tractor. Model=?, but 25 HP, 2cyl 52 inch deck.
You didn't specify what engine is on your Murray, but most of them were either Briggs & Stratton or Tecumseh. Both of these engine take SAE HD30 weight motor oil. Appoximately 48 ounces will fill these from a complete drain.
If your Murray has an imported engine (honda or kawasaki) then they would use 10W30 oil.
Aug 30, 2010 | Garden
How much oil to fill a tecumseh 6 hp engine on an ariens string trimmer?
This engine should take just alittle less than one quart. Doesn't it have a dipstick on it ? Irregardless about 1 quart should do it. Good Luck
Sep 08, 2009 | Garden
Garden Logo
735 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
