Pioneer djm800 keeps blowing fuse J on main processing board. Fitted an anti surge plau to try and stop fault but fuse went again after 10mins use.
  • Audio Player... Master
  • 5,056 Answers
Replacing the fuse to a different rating or type is very dangerous! The fuse is blowing because something has failed and is causing an overload. The fuse is there to protect and stop whatever is causing the problem from overheating the Amp and causing a fire.
Now to what might be causing it to blow. In most cases it's either something in the power supply for instance the transformer or any semi-conductor such as diodes, voltage regulator or what converts the supply from AC to DC.
The other area that will cause the fuse to blow is the main amp section, the transistors etc of which will be found on the heatsink.
If you have an Ohm Meter you can test transistors with it and diodes. In this case it will show up well, for when you put the test probes to the terminals it will be just like you have touched the probes together.
Posted on May 09, 2010
Pioneer Rear Projection TV problems
a 240 ac voltage appliance will run happily on 220 volts but ther is obviously a fault as the green spark was possibly a fuse blowing
ie main fuse as power is not reaching the tv
Aug 14, 2012 | Pioneer SD-533HD5 53" Rear Projection HDTV
Fuse is blown in circit board
Did you have a power surge recently? That fuse can't blow itself. If a power surge got you then I would say to pull the board and put another fuse in. Of coarse unplug the refrigerator first. This may involve some soldering to remove the caps over the end of the fuse. If you did not experience a power surge then you should probably replace the board. If a component on the board has faulted, then replacing the fuse would be pointless. Because it would just blow it again. Hope this helps.
Mar 24, 2011 | LG 19.7 Cu. Ft. Side-by-Side Refrigerator...
I have a problem with the power supply board with my TV (Samsung LN46A750). I had a fuse blown and tried to replace it (with a like fuse, of course). Replacing that fuse and attaching the power cord let...
Power supply board have power surge parts,but not totally dead,it just giving to much power some where,that why it keep killing ur fuse.This problems,u must have great electronic skills to track it down.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.Power surges are rarely happen,but the surge protector will stop massive power will go the protector when it happen instead all the power will go to the tv itself.
Mar 16, 2011 | Samsung Televison & Video
I have an alesis transactive mobile, which persistanly blows the 3.15a glass fuse. can anyone help........? Thanks Jamie
Generally a blown fuse is an indication that something is wrong and needs to be fixed.
If it is happening while the unit is in use, it may indicate power leakage to earth, which could be a safety hazard.
Or it could be drawing too much current because of a circuit fault.
If it happens when the unit is first switched on it could be be because of the initial power surge.
All three conditions could be contributing to some extent.
It should probably be checked out by an electronics technician.
If it only ever blows the fuse on switch on, fitting a slow blow fuse could keep it in service, and may appear to solve the problem, but i would still consider having it checked out and a component fitted to limit the initial current surge, as was fitted in most cathode ray tube computer monitors.
Jan 29, 2011 | Alesis TransActive Mobile PA System...
I have a Mikomi model number 15LCD250. FS601 is blow open circuit, it is a 1206 Surface Mount Fuse with a 5 marked on it in green. Any idea of the value / surge or anti-surge ?
try to look for the caution sign printed in the main board beside the ac supply it is printed there the exact value of fuse. is it totally burned if totally burned you have a shorted parts before replacing it try to locate other defective parts.
Oct 13, 2010 | Televison & Video
No Power on 32" Panasonic
A slow blow fuse is also known as an anti-surge fuse the idea being any sudden "spikes" in you mains electric when you switch on would blow a quick blow fuse. Anti surge fuses are designed to tolerate any sudden initial electric pulse.
Jun 22, 2009 | Panasonic CT-32SL14 32" TV
Oven element tripped main fuse box switch
Try running it with the element disconnected, if it does not trip, then element is causing prob.
If it still trips, then look elsewere for prob,.
Please rate my solution.
Thanks.
Feb 24, 2009 | Bosch HBL 5032 Electric Single Oven
Home Amp fuse keeps blowing
This usually happens when there is a problem with the main power supply and is relatively rare. If you can post the make and model, I can give you some things to check if you are somewhat familiar with electronics.
Thanks,
Dan
Feb 19, 2009 | Pioneer Audio Players & Recorders
310 people viewed this question
 Grubhead
Grubhead
