The releif valve on my water heater was activated. Do I have to replace it or just wait until it cools off and then I can refill the tank. Kenmore Model # 153.333130
    Guru:
  • 415 Answers
It should reseal itself; however, sometimes the seal will leak. As long as it doesn't leak when you refill the tank, you will not have to replace it.
More information on Safety Relief Valves
Hope this helps
Please leave a rating.
Posted on May 09, 2010
Why does the water valves continually pulse?
It's hard to answer such a general question. I will assume your reference refers to a toilet, and that 'pulse' is regards a recurrent slight refill action of the tank fill valve. If this is the case the cause is probably a slowly leaking flush valve. When the tank water level drops enough to activate the fill valve, there will be a slight refill action (pulse) to top up the tank water level. It will repeat until the leaking flush valve is fixed.
Jun 06, 2015 | Home
I have a 2003 honda Odyssey. Does it have a releif valve or nut to release trapped air in my cooling system? I just drained my radiater and replaced my therastat and its running hot when im driving.
locate the coolant temperature sensor nearto the thermostat housing. Unplug, loosen then plug back up. To bleed, loosen slightly to release trapped air. Once air is relieved, only liquid will come out at this time the air bleeding is done.
Dec 21, 2014 | 2003 Honda Odyssey
Hot water valve leaking how do I take part no.
You will need to turn off the water heater first. Shut off cold water inlet valve to tank. Open the drain at bottom with hose attached to suitable drainage area, hot water will damage plants and grass so if you want to use the water let unit cool off for a few hours or drain down past the valve level. You can open the release on the temp/pressure vale and it will help vent and allow you to know the level. Take a small pipe wrench or large channel lock pliers and remove the drain line pipe connected to the valve body. Open a faucet that is the longest run and wait. The valve can be found at most home centers and are basically all the same with the BTU and pressure rating on the label. Take with you to match length and ratings. Apply Teflon tape or pipe dope on threads to help seal the fitting and tighten up till unit is secure and the opening points down for overflow pipe installation, reseal and tighten. Close off drain and refill with faucet and valve release open, when water starts to run out of valve close and continue filling until all air is bled out. Then relight water heater or turn on power. Check for leaks and test valve for operation. The TP valve should be tested annually for safety.
Aug 26, 2014 | Water Heaters
Black slim in hot water
SOUND LIKE YOU NEED TO DRAIN AND FLUSH YOUR WATER HEATER TANK. THERE IS A HOSE BIB AT THE BOTTOM OF THE TANK. RUN A HOSE FROM IT TO A DRAIN OR OUTSIDE. SHUT OFF THE COLD WATER INLET VALVE AND OPEN THE HOSE BIB. OPEN HOT FIXTURES IN THE HOUSE.CHECK THE DRAINING WATER FOR CLARITY. IF CLEAR OPEN THE INLET VALVE AND LET IT FLUSH(YOU MAY GET MORE DISCOLORED WATER, RUN UNTIL CLEAR). SHUT HOT WATER FIXTURES, CLOSE THE HOSE BIB AND LET TANK REFILL.
Mar 30, 2013 | Water Heaters
How do I flush the cooling system in a 2000 hyundai elantra?
There are several methods for flushing the cooling system on ALL engine cooling systems. Time honored is drain the radiator (drain ****). Fill with fresh water and run engine to operating temperature until cooling fans turn on. Drain cooling system again. Refill with 50-50 coolant. Another method is purchasing a "T" vlave (coolant flush/service kit) from Autozone, PepBoys, NAPA, O'Reilys, CarQuest, etc.). This "T" valve is installed in one of the heater hoses & attached to a garden hose. Remove the radiator cap & turn on the water supply to the garden hose. Let water run until flush water is 'clear'. Remove garden hose from T valve & refill radiator with pure coolant until the T valve drainage turns green/orange. Install T valve cap... DONE!
Sep 08, 2011 | 2000 Hyundai Elantra
My Rheem electric hot water heater occasionally leaks water then stops completely. This has done this three times now over the pact couple years.
It sounds like TP valve is releasing water, but you don't describe where water is located.
Run through process-of-elimination check list on following link:
http://waterheatertimer.org/Leaking-water-heater.html
1) If problem is TP valve, event could be caused by 'stacking'
Stacking is where you draw amounts of hot water many times in succession.
Top part of heater is plenty hot because water heater is keeping up with hot water draw.
Incoming cold water enters bottom of tank through dip tube causing thermostat to read cool temperature and activate burner or element. This causes higher than ordinary temperatures at upper part of tank and TP valve reacts by releasing water.
2) TP valve could be going bad.
http://waterheatertimer.org/How-to-replace-TP-valve.html
3) Improper venting can cause gas water heater to have water on top of tank or dripping down inside tank where it shows on floor after rusting out combustion chamber.
4) Thermostats are old or not reading correct temperature.
Turn down thermostats:
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
Replace gas valve on gas water heater, and flush tank.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Replace electric water heater thermostats
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
5) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 17, 2011 | Rheem Water Heaters
Water heater keeping running
Check releif valve and make sure it is not running out of it. Sounds like the releif valve may be bad.
It's on the side of the water heater with a lever on it they are for safety reasons, they go bad from time to time. It may be piped through floor to a drain or outsude.
Feb 21, 2010 | General Electric GE SmartWater Household...
I have a propane hot water tank that in discharging the hot water out the relief valve (Champion energy saver series)
possible problems not knowing age of unit the
control valve could be sticking open allowing gas to continue to flow until high limit is reached and shuts down valve another possible problem with the newer style back flow preventer being install by water companys the rapid heating and expansion of the water over pressures the water system causing releif valve to pop open and reclose most water heater manufacters are recommending instalation of an expansion tank to allow the growth in volume of water somewhere to go is valve constantly leaking or only during heating cycle if you could supply additional information does unit only leak when heating
or is steam expelled when releif valve opens
t-stat not opening gas valve sticking partially open
bad high limit bad pressure releif valve no expansion tank to allow for thermal expansion if steam is present and unit is boiling water inside replacement of water heater for safety concerns,would be reccomended if only water and pops couple of times water temp not over 140 degrees after most hot water has been used out of tank and is reheating most of capacity probably lack of expansion tank as the releif valve is the final safety device on a water heater is of great concern
the temp control gas valve or high limit are supposed to shut unit done long before the safety limit of releif valve is reached
Dec 11, 2009 | Water Heaters
Water Heater drain leaks and has caused rusting on tank
If you're sure it's the DRAIN, just get a garden hose cap for it (your other option is to replace the valve - drain tank, replace valve, refill).
NEVER CAP THE RELIEF VALVE DRAIN!
Sep 18, 2009 | Fasco Bradford White Hot Water Heater...
Hydronic Boiler relief valve problem?
Check the pressure guage. Typically the pressure in a water boiler should not be more than 20 psi. If you are approaching 30, the relief valve is doing it's job. I would replace or adjust the automatic water feed if the pressure is high. Always replace the boiler relief valve. Tap on the expansion tank, it should sound hollow. Replace it if it is full of water. If you have one of the old expansion tank that has no bladder in it, drain it.
Dec 03, 2007 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
