Question about Broksonic SC975 19 in. TV/DVD Combo
How to turn off Closed Captioning on Broksonic Model SC-975
How do you get the "closed caption" option to turn off? I have gone into the captioning section and ACC says "Off" and OCC says "Off". Also, when I push the caption button on the remote it only turns off on the TV screen for a few seconds, then comes back on. The TV was given to me and I have no manual - Thanks for your help!
  • 267 Answers
SOURCE: Broksonic TV, cant turn on
IF IT'S NOT ON THE REMOTE GO INTO THE MENU.
Posted on Jan 22, 2009
  • 7 Answers
SOURCE: How do I turn off the close caption on a Broksonic
Try to press buttons simultaneosly for a few seconds to get to the menu, i.e. volume up and down together, channel down/up together etc etc
That very well may get you to MENU
Posted on Jun 12, 2009
SOURCE: Trying to turn off the close caption on a
With assistance from another user on FixYa, they mentioned that if you hold down the volume or channel button together, that it might help. I tried different variations and figured out if you hold down the up and down volume buttons at the same time for serveral seconds, that the volume settings reset and the close caption turns off.
Posted on Jun 14, 2009
EduTech
  • 54 Answers
SOURCE: sc20145 television broksonic television dvd vhs combo
Buy universal remote for $10-$20 at radioshack, mcm.com, box stores, etc. Check to make sure your model is listed and/or ask if its returnable if it doesn't work with our set.
Posted on Jun 26, 2009
SOURCE: how do i get the closed captioning off?
You should be able to do that with your remote. Just look for the `caption' or `c.c.` button and try using it again. You may have to push it several times to completely turn it off as it may cycle through the different types of captioning systems before reaching the `off' setting.
If you don't see it on the front of the remote, you may have a remote with a second compartment and the keypad may flip or slide open to allow you access to the additional buttons.
Posted on Mar 10, 2010
Cannot turn closed captioning off. I have gone to setup, closed captioning and turned it to off. I still have closed captioning and I can't turn it off.
Sounds like the CC data is coming from your cable service. I would check your cable box options and turn CC of there as well. what company are you with as far as cable ? also what model cable box do you have?
Sep 05, 2011 | Sanyo DP32746 32 in. LCD Television
My 9" Broksonic TV/DVD player
Will tries go into the tv screen menu again tries see if u can locate and functions like TEXT ON/OFF TEXT 1,2,3..Tries to off all that.The Close Captioning 1,2,3.. and TEXT 1,2,3..are same functions as TEXT 123 3..funsctions have a permanation of a big black box on the tv screen as Close Captioning functions writting without the big black box on the tv screen.
Aug 18, 2011 | Broksonic TV
I need closed caption
Tv air broadcasting shows have to say it,to have closed captioning or have to have a white small sign that said CC to be able to get closed captioning ok.Look for it in ur remote there a button that said CC pushes that button go to CC1,2,3..now u will get closed captioning.Or go into ur tv Menu find closed captioning functions turn it on like CC1,2,3...or Text 1,2,3.. on.Now ur tv are ready to get closed captioning,for the tv air broadcasting shows,that have closed captioning.
Dec 10, 2010 | Broksonic TV
I can't turn the closed captioning OFF on my insgnia flat screen tv model NS-L CD37. i have a universal rca remote & the closed captioning won't go away - HELP !
The problem is that the universal remote is not sending the correct IR signal to your units IR receiver, regaurdless whether or not you turned the captions on with the universal, it is unable to send the signal to turn them off, if you have a menu button on your unit you could try accessing the closed caption option that way, alternatively you can do a system reset, if you can access that menu option, you may need to do a tv retune to get your stations, but the closed captioning should be off. I hope this helps. Good luck.
Jun 07, 2010 | Insignia 37" LCD Flat-Panel HDTV
Need to know how to put the tv on close caption
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option.
1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
  1. 2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
  2. 3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
  3. 4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
  4. 5)If you're watching a DVd on your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
  5. thanks.
Nov 11, 2009 | Televison & Video
I need to activate CC for my Dad, Please help I have to go to work. I have a flat screen SOYO
Determine if closed captioning is available on the program that you've selected. In your program guide, the letters "CC" should appear at the end of the description.
Locate the closed captioning option on your remote. Some remotes have a "CC" button that you simply need to push to activate closed captioning
Locate the closed captioning option in your television's menu if there is no "CC" button on your remote. To do this, push the "menu" button on the remote control. The closed captioning option will probably be in the same section as the language function.
Set the closed captioning option to "on." Within several seconds, you should see the text appear on your screen.
To use closed captioning for DVDs, look for the "CC" label on the lower back section of the DVD case where it lists audio information. Turn on your TV's closed captioning and you should see the captioning like you do on a television program. Alternately, some DVDs include English subtitles that you can turn on in the setup/language menu of the DVD.
Thank you.
Aug 28, 2009 | Televison & Video
Black box on screen covering the picture
This is a box for text, such as closed captioning or demonstration mode. Go into your setup menu and turn off closed captioning or return to factory settings.
Jun 28, 2009 | Broksonic Televison & Video
We can not get CC Closed Captioning to turn off.
had a power outage and it said to reset the clock I went some where and changed the close caption from off to on. It was a in a set up menu
Jun 09, 2009 | LG 37LP1D 37 in. LCD Television
Have a black-out square appear on some channels especially FOX
GO INTO THE MENU AND TURN THE TEXT OFF. THIS IS ASSOCIATED WITH THE CLOSED CAPTION. CC1, CC2, CC3, CC4, T1, T2, T3, T4, OFF
Jan 22, 2009 | Broksonic TV
How do I turn ON Closed Captioning.
It sounds like that option is not available on that model , contact samsung
Dec 07, 2008 | Samsung DLP HL-P5663W 56" TV
Broksonic SC975 19 in. TV/DVD Combo Logo
120 people viewed this question
Top Broksonic Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
