Question about Mitsubishi WD-65733 65" HDTV
My lamp on my Mitsubishi WD65733 DLP TV actually blew up while I was watching it (kablooey). So, I bought a new lamp and replaced it. Now, the picture and sound comes on for about 30 seconds then it turns off and the red "lamp" LED on the front panel of the TV starts flashing. Do I need a ballast?
  • dyoung1975 May 10, 2010
    Since the time that I posted my original question, I opened up the lamp assembly and found a crack in the glass shell of the lamp. I am pretty sure that is what the problem is, so I will be taking it back to where I got it from. Also of note, the lamp that I got doesn't exactly fit into the slot that it is supposed to fit into in the lamp enclosure. So, I think the local TV repair shop installed the wrong lamp into the lamp enclosure.
  • Mitsubishi Master
  • 5,138 Answers
No check for bad capacitors on Power supply board they will be vented swollen or puffed up on top.
Go to Encompass Parts Distribution and look up your Model number.
Posted on May 09, 2010
  • ladywinn
    ladywinn May 10, 2010
    Lamp part number is 915PO61010, Encompass has it for $273.00
    Mats $99.00 1-800-628-1118
    Encompass Parts also has Free service manual for this model.
Green blinking light on Mitsubishi DLP 52825
Hello, unplug the tv and check the lamp to see if it is broken inside. here's a link on how to replace the lamp.....tks.... https://www.youtube.com/watch?v=3bQ0wut_pWg
Jan 26, 2015 | Mitsubishi Televison & Video
BULB IS BLOWN ON THE MITSUBISHI WD65733
your model uses the Mitsubishi 915061010 Lamp assembly with housing which is available from www.tvrepairworld.com under the Mitsubishi DLP Lamp category. The lamp comes with installation instructions and is a simple plug in , It includes the housing so you dont need to remove the old bulb from your housing to reuse since the new lamp already has the housing with it.
Aug 22, 2011 | Mitsubishi WD-65733 65" HDTV
WD65733 Mitsubishi projection HDTV worked fine last night. This morning when I turn it on I can hear sound but no picture. After a minute it turns itself off. What is the problem?
Most likely just needs a new lamp.
the lamp is easy to replace , google for the lamp to buy one online.
a few screws hold the lamp door and lamp in place.
Dec 17, 2010 | Mitsubishi Televison & Video
Can I replace the DLP lamp myself or do I really need a repair technician to do this?
U can replaced the DLP tv projection Lamp ur self.Try website like YouTube.com.Type in Mitsubishi DLP tv projection lamp replacement.There will be a tutoring video by somebody,replacing the DLP tv projection lamp.Tries websites like Ebay.com,Partstore.com to buy a new DLP tv projection lamp.
Oct 15, 2010 | Mitsubishi WD-52631 52" Projection HDTV
Mitsubishi dlp tv WD65733 has white spots, like stars on screen, what causes this
If you get White or black dots all over the screen (DMD symptom)
If you get a pixilated picture (DMD Board)
Mar 27, 2010 | Mitsubishi WD-65733 65" HDTV
HEARD LOUD POP NOISE DLP TV DOES NOT WORK
Following up on my Feb 7 post. My new lamp arrived, and I replaced it and it works great. The old lamp had many shards of glass come out of it. It was tore up. I saved some money buy purchasing just the lamp and not the cartridge. It's a little bit more work to take apart, but saves money. Mitsubishi wanted $289 for the lamp replacement kit. I got a lamp for $114. TV is working just fine now!
Jan 30, 2009 | Mitsubishi WD-57734 57" HDTV
How long does a lamp/bulb of a Toshiba DLP 46HM95 46 in last?
Your bulb may be blowing because of airflow issues or power cycling issues, first does your outlet get switched off at any point in time? if so you may be killing the bulb before it cools, if you turn the set on/off alot and or restart it after off quickly this could lead to permature bulb failure, if the original lamp was not replaced with a proper lamp to match the ballast it could blow the bulb. If your tv is too near a heat vent or the airflow thru the set is not adequate it could blow the bulb.
Aug 01, 2007 | Toshiba 46HM95 46" HDTV
Mitsubishi WD-65733 65" HDTV Logo
1,452 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
