Question about Troy-Bilt® Briggs and Stratton Chipper
Engine blows oil out the muffler - Troy-Bilt® Briggs and Stratton Chipper
    President:
  • 986 Answers
Your piston is worn and galled, you might be able to do a rebuild with a new piston and rings and hone the cylinder, but please always consider cost, of the price of a new engine,if you cannot do the work yourself,
Posted on May 09, 2010
Why is oil blowing out of my 1997 873 Bobcat muffler?
is it fresh oil or blowing out old oil it will take a few to clear out muffler , but after that there's more wrong ,when you pulled off old turbo was it leaking , did you clean out intercooler of all the oil ?
Sep 08, 2014 | Cars & Trucks
Engine oil blowing out from muffler
Sounds like blown rings, stuff a rag into muffler while running, one way to tell, if it comes out oily. Try buying a ring sealer at Auto Zone or stores like thar
17.5 briggs on troybuilt riding mower blows black liquid out muffler on startup.
the black liquid is most likely oil and the smoke indicates the rings are bad or a valve is sticking allowing oil into the cylinder.
you are most likely looking at an engine rebuild
Aug 15, 2014 | Garden
Why is oil blowing out of side vent and muffler on my poulan push mower with briggs engine
I f your engine smokes constantly while running then chances are your rings are gone. do a compression test. compression should be between 60 and 80 psi for healthy engine. If not this good replace engine or machine
Aug 03, 2014 | Garden
Leaking oil around muffler and valve cover
Did change valve cover gasket? I blow mine with each time I use it. Then every month soap and water. When engine is cold.
Mar 21, 2014 | John Deere Seat For F710 F725 F735 Riding...
When you start engine white smoke pours out and oil is blowing out 2 feet out of muffler.
Hi michelley636
Check your oil level, it sounds like it is too much oil in the crankcase causing it to burn in the combustion chamber
Bud
Apr 29, 2013 | Briggs & Stratton Garden
Engine will not go to high speed fuel oil mist blows out .checked spark arrestor ,muffler,exaust ports.
If the mix is blowing out the muffler than it is flooded either due to improperly adjusted carb, stiff diaghrams in the carb or weak spark. Weak spark could be a bad plug, failing ignition module, or spark ouit of time ( sheared flywheel key).
Bad fuel will also cause this symptom.
Oct 25, 2012 | Troy Bilt Tb320bv Spring Assist Blower/Vac
I have a Toro Zmaster mower The engine is a FH580V KAI19. It was running fine. Parked the mower last night, tried to start it today and oil is coming out of the OHV cover and blowing by through the...
you could have a broken piston ring. check the oil level. if it is ok or low and still smokes or hard to start then you may have to overhaul the engine. let me know what you find.
Mar 13, 2011 | kawasaki Garden
Craftman 6.6 self propelled mower blowing oil between the upper &
The Breather or Dip Stick Gasket at Engine. It you had the mower turned on its side befor problem, its coming out of the Muffler. This will go away but check your oil level.
Sep 08, 2009 | Craftsman Garden
Muffler blowing white smoke
take it back the engine has a blown head gasket or cracked head all cost over 1200 to fix
Mar 15, 2009 | 1997 Dodge Caravan
Troy-Bilt® Briggs and Stratton Chipper  Logo
239 people viewed this question
Top Troy Heavy Machinery Experts
Roland W VanLue
Roland W VanLue
Matt Olenzek
Matt Olenzek
Paul Sikkema
Paul Sikkema
Are you a Troy Heavy Machinery Expert? Answer questions, earn points and help others
