Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Whirlpool ff 400 elite, probable pcb fault
I've a whirlpool FF400 Elite fridge, Everytime i switch it on the cooler fan runs for abt 5 secs and the fridge turns off, ive consulted the whirlpool agents in my country, but they did no good, they said that there had been a current overload and that the pcb and the compressor had been burnt, i had to pay 4 the pcb but the compressor was under warranty, Then the fridge worked after, but it had some unusual sounds, and worst of all ice started to form inside the fridge, and the electricity bill tribled after one month of use, i compaired the previous months bills and it was a big difference the units count had doubled, and now the fridge stopped working, but sometimes late night i saw it working, then again in the morning it stops working, all my fod gets spoiled, ive contacted the agents but they refuse to repair the fridge saying that its working fine, The fridge has no time to switch on, it all of a sudden starts working as if a ghost turned it on, please advise
    Scholar:
  • 91 Answers
The agent who repaired it, has an obligation to rectify the issue, sounds like they did a quick fix, out of the ordinary question I know, but does the fridge light come on when opening the door???, if it does not, they did not replace the ECU, sounds like your unit only working once in defost cycle then shuts down on normal cycle.(**** about), get your repairer to rectify the issue or report them. Russ
Posted on Aug 12, 2012
Compressor is running 10 menites after 10 to 15 minites compressor start
Posted on Jul 23, 2011
Refrigerator and freezer doesn't keep food as cold anymore. Food is spoiled and temperature is at it's highest. Whirlpool w8txngfwt
Get a repair man to check out the freon pressure in your unit. If the freon is low there will be no cooling power. Ours had a little leak in a hose and cost $95.00 to repair. If it's an older fridge it might be better to purchase a newer one. Unless you have the testers and know what you are doing to check this unit you need a repair man.
Aug 24, 2016 | Whirlpool Refrigerators
PTAC stops running after a short time
Sounds like a voltage or amp draw issue. So how about if you only try to run the blower??
Jun 05, 2017 | Heating & Cooling
I have a 1500w power inverter that has worked great for abt 2 yrs, I run a dorm size refrig. on it and sometimes a 700w microwave but not both at the same time. The fridge draws abt 180w at startup and abt...
Not likely as low voltage should shut the inverter down. Check your battery anyway. 13.5vdc fully charged and each cell that is bad is about 2.25vdc off that. Sounds like the inverter has had an internal failure and unless you are an electronics tech, beyond your capabilities to repair without serious training.
Nov 01, 2012 | Electronics - Others
Whirlpool FF400 Elite fridge is not cooling. Ice is not forming in freezer but its cold. refrigerator is not at all cool.
Check the fan in the freezer if that is working then you may have a defrost system problem remove back panel if coil is iced up you have a bad defrost timer or defrost heater assembly
Jun 22, 2011 | Refrigerators
Intermittent fan motor & relay switch (4-5 sec.) - warm freezer
you need a new overload contactor or they call them an RTX also that powers the compressor it is located on the compressor body,also replace the capacitor that plugs into the RTX at the same time you replace the RTX that will solve your problem
Dec 24, 2009 | GE Refrigerators
Why does it keep freezing up? The hot side works and the fridge compartment is fine
there is a small fan on the cooler side that may not be working. if this is the case, it will freeze everytime
Nov 27, 2009 | Hamilton Beach Water Cooler with Storage...
Whirlpool bottom freezer 5 years old everything freezes in the fridge
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 10, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore Elite Trio Refrigerator not cooling
No, it is not a failed condenser. You need to see if the compressor is running though. When it runs you shaould have a fan in the freezer running, a fan underneath the fridge running, and the compressor should be running. I would be willing to bet that either the compressor is bad, or the start relay on the compressor.
Sep 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Side by side
The clicking sound is either from your fan clicking against ice that's built up or from your compressor trying to kick on. Unplug your fridge and let it defrost for a day with the doors open. You will want to put everything in a cooler with plenty of ice. The next day plug your fridge back in. This should solve the click if it's your fan. If it doesn't then the click is in the compressor and you will need to hard start it. Hard starting a fridge is the equivalant of jumpstarting a car. It requires a specific machine. What happened was at the moment your compressor was going to kick on the power failed and so the compressor is frozen. Not temperature wise but figuratively. It needs a boost to get it kicking again. If you don't have a hard start machine consult fixya's local directory. This should just be a minimum service charge. I would try unplugging the fridge for a day first. It's cheaper. I hope this helps.
Aug 22, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
441 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
