Question about Zanussi 18 in. ZDT5052 Slim-Line Built-in Dishwasher
I cant get the machine to start.
I have not used it before. The machine is ZDT 5152. No English instructions. What buttons do I press?
How to change back to english
Press the MENU button. Use cursor-left/right to select the settings tab (not the camera icon). Use cursor-up/down to select the seventh item on the menu and press the OK button.
Jan 02, 2013 | Kodak EasyShare C1505 12 Megapixel Compact...
Instruction Manual
There is no user manua l available for this model anywhere.The only way to get the manual is to call the Main support number at 1-800-626-2005 and tell them to email you a copy of it.
If you need anymore help let me know.
Please don't forget to rate or accept the solution
Jun 26, 2008 | GE (WMM317440) Answering Machine
I have a ZDT 5053 and the programme light is green but I cannot change programmes and it won't start. Any idea as to what is wrong?
MAYBE YOU SHOULD USE SOAP AND WATER LOL .....A LOT EASIER BUT MAYBE UR JUST TOO DAM LAZY .....THE SAME AS WHEN UR LOOKING FOR A MAN ....
May 18, 2012 | Dishwashers
How to change Brother MFC 5890CN Language
Please follow the instructions below to change the language to English.
1. Turn off the machine
2. Hold in the MENU button.
3. Turn on the machine while holding the menu button
4. Maintenance should come up onscreen and the lights should flash.
5. Key in the numbers 74 and press Mono Start button.
6. Key in 0004 and press Mono Start button.
7. "MAINTENANCE" appears again on the display.
8. Key in 99 at the maintenance prompt to exit to the date and time
It should be now in English.
Apr 26, 2010 | Brother MFC 580 All-In-One InkJet Printer
The language on my hewlett-packard f600 notebook is changed and i cant get it back to english
You may try to go to Setup Menu (reboot while pressing delete or F2; you need to see which button should be pressed upon booting up to access BIOS menu because this varies between laptops). Using the tab key, highlight Restore to Default Settings or Failsafe Defaults or similar instructions, enter, then save settings and exit. Reboot.
You may also borrow a friend's laptop with the same OS. Follow the English menu. Click Start, Control Panel, click Date, Time and Language Options, choose English.
Sep 02, 2008 | Compaq Computers & Internet
Child lock light stays on - & cant start mc programmes
HI I KNOW IT SOUNDS DAFT BUT HAVE YOU TRIED SWITCHING THE CHILD LOCK OFF? I CANT REMEMBER EXACTLY WHICH BUTTONS IT IS ON YOUR MODEL BUT YOU USUALLY HAVE TO PRESS 2 BUTTONS AT THE SAME TIME (& SOMETIMES HOLDING THEM FOR A COUPLE OF SECONDS) RATHER THAN JUST 1 TO SWITCH THE CHILD LOCK ON/OFF. IF YOU STILL HAVE THE INSTRUCTION MANUAL IT WILL TELL YOU WHICH BUTTONS YOU PRESS TO SWITCH CHILD LOCK ON/OFF HOPE THIS HELPS!
Jul 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
On a Cannon Powershot IXUS 86015 How do i change the language back to english?
Hey thaze,
According to the manufacturer you need to press the playback button, which looks like a triangle pointing to the right. Next you need to hold down the func. /set button, and press the menu button. Next you need to use the up/down arrows, or the right/left arrows to choose the desired language and then press the func. /set button. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 19, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Zanussi zdt 6252
I had the same problem with Zanussi ZDT 6252. To fix it, turn power on, close door fully, then open door, turn off then turn back on again. If you follow this sequence the machine is reset and you can select programs again.
Dec 26, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Open Questions:
See all Zanussi 18 in. ZDT5052 Slim-Line Built-in Questions
Zanussi 18 in. ZDT5052 Slim-Line Built-in Dishwasher Logo
57 people viewed this question
Top Zanussi Dishwashers Experts
paulcarew
Owen Barnes
Gerard Curran
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
