Question about HP 16 GB USB FLASH DRIVE PRO FULL SPEED 2.0 Server
I bought new hp usb flash drive 4 gb when i go to
I bought new hp usb flash drive 4 gb when i go to my computer i see the dirve when i click on it i got message..please insert disk in drive G
  • 69 Answers
You can try getting a flash for your bios to see bigger drives it is probably a size limitation in bios what operating system are using and how old is the computer
Posted on May 09, 2010
HP 8 GB PENDRIVE NOT READ
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Mar 29, 2012 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
I have HP V165W Flash Drive of 4GB, its not detecting on laptop XP, but its working good with Desktop computers, what's solution you suggest. I think its manufecturing fault. Mostly I purchse Kingston...
NO LAPTOP STATED.
ok what are you doing, tell that first. the job at hand.
then tell symptoms.
omg , i can buy generic USB memory sticks in a bundle at Walmart check out. the all works on every PC made.
so do yours.
did you try this stick on other PCs, (NOT WITH XP )
you do XP is a dead OS not for 3 long years, right
and plug and pray is not dead at HP , and MS. right?
for XP to work , (good luck there)
it must have SP3 loaded, does it?
and be connected to the internet ; are you.
XP will try to find the USB drivers to run your stick as ALL OS do the first time, and XP will fail. in most cases now
that is because microsoft pulled the XP plug. 3 years ago
that means they only have 1 tiny bit of support left,
that is activation, only
time to up grade to w7, for sure
or go to GOODWILL Buy pc used with W7 COA sticker on the bottom for $20 and win.
this is the support in the STICK.
https://support.hp.com/us-en/product/HP-Brand-License-USB-Flash-Memory-series/3261337/model/4077082
Aug 08, 2017 | HP 16 GB USB FLASH DRIVE PRO FULL SPEED...
My kingston 2 gb flash disk is not recognized, how can i fix it?
Please follow the below steps to fix your problem
Connect your flash drive to your computer using an available USB port. If your flash drive is not recognized, you'll usually receive an error that says "USB Device Not Recognized."
Click "Start" > "Control Panel" and open the system configuration by double-clicking the "System" icon.
Navigate to the "Hardware" tab and click the "Device Manager" button to open the Device Manager.
Click the "+" next to "Disk Drives" and locate your USB flash drive. A question mark icon should be shown to the left of the label. Right-click the device name and select "Uninstall."
5
Open the "Action" menu at the top of the Device Manager and select "Scan for hardware changes." This will scan your PC for any new devices. Because you uninstalled the flash drive, it will be detected as a new device and the drivers will be reinstalled.
6
Click "Start" > "My Computer" and look for your flash drive. If this process was successful, your flash drive should now show up under My Computer as a storage disk.
Hope the above information will be helpful to you.
Thanks.
Oct 22, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Where can i download driver for hp v165w USB flash
The USB driver installed by default. U need not have to install it separately. If it is not recognised then try to use it on another system, see whether it gets connected or not
Apr 19, 2010 | HP 16 GB USB FLASH DRIVE PRO FULL SPEED...
Sir, I have TDK 4 GB Pendrive. I was formated some
this the great solution... try low level format..
1. plug ur usb flash
2. run Formatter v2.9.0.9.exe
3. follow the instruction and wait for the format (might take 5min for 4GB)
4. after complete, may the small volume (about 2MB...here the solution
5. plug your usb flash on other computer and format like regular (make sure u untick quick format) and click on "restore device defaults" then click format
6. now your usb flash drive was like a new one
Dec 14, 2009 | Vacuums
Pen drive is not working
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove Hardware icon and then click on USB flash drive you want to remove)
Dec 14, 2009 | Kingston Technologies 512MB DataTraveler I...
How format SanDisk cruzer Micro 8GB
copy the files to you're pc, and if you use windows just go in my computer and right click on the flash disk icon and click format check the quick format box and the press format.
Jun 14, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
How to download files onto USB flash memory
Just plug the memory stick into your USB port on the computer. Windows has the drivers already installed. A taskbar icon will appeer us a connected USB device, exacly as a digital camera would. You will find the stick in My Computer as a removalble drive. Click on the right side mouse button over the flash drive icon and click properties to see the stick memory size, ect.... Use it as you would any other removable dirve, ie: 3.5" floppy disk, CD Read/Write. I would go to the TOOLS button for the drive and click FORMAT for you first use of the stick to test its memory. After that you can just copy, save, drag and drop files like always....
Apr 09, 2009 | Shuttle XPC SD32G2 Barebone
HP 16 GB USB FLASH DRIVE PRO FULL SPEED 2.0  Server Logo
166 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
