Oven elements both have power at connections but no heat its an old moffat
    Guru:
  • 415 Answers
You most likely have open heating elements. Try ohming them out. If there is no resistance, they are open and will need to be replaced.
Testing Oven Elements
I hope you find this information to be very helpful to you moving forward. Contact me with any further questions or concerns.
Please leave a rating. :-)
Posted on May 09, 2010
Moffat oven fan wont turn off. just keeps blowing cold air but eveything else is working
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
: I offer free advice bcuz God is so good!
Jun 03, 2015 | Moffat Ovens
Moffat oven doesn't heat .The elements don't turn red
Check the oven fuse. If that's OK, unplug it from the power supply. Remove the screws holding the element to the oven and pull it carefully back away from the oven wall. Connect your VOM test leads to the 2 terminals (meter set to at least 250Vac). Make sure the leads are not touching any metal parts of the oven and they are not touching the element. Plug oven in and turn the oven on. Do not touch the oven during testing. Reading 220 - 250 Vac power is OK. Element is bad. Reading lower then 220 or none at all no power getting to element, need more testing to find the problem. Be careful, and use common sense when working with and around electricity.
Feb 05, 2015 | Moffat Ovens
1965 Moffat Electric Built-in oven - model #21K90. No manual and no information on any of the websites I've searched. There is power (oven light, warmer light, rotisserie, power rack), but clock and...
My father solved this one, those clocks were such a hassle, ours buzzed for days til he fixed it. It requires opening the control panel and bypassing the wiring that allows the clock to turn the oven on and off. Of course you lose this function. Is that the complete model number?
Oct 26, 2013 | Ovens
While roasting a chicken in the oven, a "fizzle" was heard and the lower element shut off, the light on the dial did not work although it would go on when switching it to broil but there was still no heat,...
your heater element went (the metal rod that heats up inside oven). can easily find replacement and not hard to do but make sure you shut off power/ unplug oven. usually a couple of screws where the element goes into back of oven to hold it in place. then can pull element out enough to see the screws that attatch the wires the the element. most appliance repair shops carry them in stock. may be easier to take old one in to match up then trying to locate the make model and seriel number you would need wuthout it.
Sep 21, 2013 | Moffat Ovens
Broiler will not come on when baking
Take a look at the element ( the "tube" inside the oven that glows red hot when the oven is turned on). If the element is burned out it will not be hot and glowing. You may have a loose connection to the element but most likely it is burned out and needs replacing.
Our stove is 27 years old and I have had to replace top or bottom elements every 6 years or so. I just bought a replacement element at Canadian Tire in Calgary for about $34. Just undo the 2 screws around the element and attach the new element to the old wires.
Good Luck -I hope this works for you
Jan 10, 2013 | Moffat Ovens
Replacing heat elements in oven
To replace oven heat element follow the steps below carefully
Turn off the power to the oven at the breaker box.
  • Step 2 Take out the screws holding the element bracket in place. These will be on the back wall of the oven, or sometimes on the top.
  • Step 3 Pull the element toward you a little bit until you see the wires behind it.
  • Step 4 Unscrew the leads and take the bad element out.
  • Step 5 Hold the new element up while you attach the wires to it. Don't stretch the wires any more than you have to.
  • Step 6 Line up the element while tucking the wires back in. Be sure not to pinch the wires between the bracket and the back wall.
  • Step 7 Fasten the brackets, making sure they're tight.
  • Step 8 Restore power to the appliance.
  • basically to install the elements , place it in the same position as the old one. Connect it the same way the old one was connected, using the same screws to hold it in place. Just about all the other components of an electric range or oven
  • Jan 03, 2010 | Jenn-Air Ovens
    Problem with oven on Moffat Program Gas Cooker
    Sounds to me like the oven thermostat has gone.
    Dec 30, 2007 | Moffat Ovens
    Oven heats up very slowly and does not get very hot
    Check your power to the oven at the terminals where the power cord connects.Should be 220 volts. Also check the terminals of the bake element for loose connections or a burnt wire.
    Dec 28, 2006 | Frigidaire FEB30S5D Electric Single Oven
    Heating & Cooling Logo
    96 people viewed this question
    Top Heating & Cooling Experts
    paulcarew
    Dan Webster
    Dan Webster
    Donni Steen
