Question about GE (PSS26MSRSS) Side by Side Refrigerator
My coils are freezing . i have replaced the heating elament and timer and its still freezing.
  • GE Master
  • 1,606 Answers
What timer did you replace ? Your refrig uses a control board , not a timer .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a defrost heater WR51X10055 not working or the defrost thermostat ( pt. number WR50X10068 ) not working . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off / on .
Posted on May 09, 2010
  • GE Master
  • 8,220 Answers
    Genius:
  • 1,122 Answers
Did you replace the mi metal switch on the coils?thats the only thing left-mike
The fridge keeps freezing over
The evaporator coil is freezing, there could be a number of reasons.
a) drain line is clogged... defrost the fridge and shoot short bursts of compressed air into the drain to clear the clog
b) the defrost sensor on the evaporator coil is faulty... replace the sensor
c) the freezer is so PACKED as to impede air flow... stop stuffing your freezer
d) the defrost timer, defrost coil, etc. is faulty... replace as required
You could defrost your evaporator coil by turning off the fridge for several hours with the doors open, blow dryer, heat gun, etc... depending on skill level
Feb 27, 2014 | Refrigerators
It's freezing everything.
Hi, refrigerators have either a mechanical defrost timer, or an ADC (Adaptive Defrost Control). If your refrigerator has a mechanical timer, set the cold control to the coldest setting and then advance the defrost timer. You can manually advance the timer with a screwdriver. Insert the screwdriver into the advancement pinion and turn clockwise a 1/4 to 3/8's of a turn. If the compressor starts, replace the defrost timer. For further help, you'll want to call a professional appliance repair technician.
You can use a condenser coil brush to clean the coils periodically. Because the coils exchange heat, any dust, lint, or dirt on them cuts down its ability to exchange heat.
May 19, 2011 | Dometic Refrigerators
Heatting elament will not get hot
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape. If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Please rate me,
Aug 17, 2010 | Kenmore 62602 Electric Dryer
Freezing up Just replaced thermostate Heating coil has continuity, still freezing up
The new one maybe faulty....also check the timer...are you sure it was the heating element that was blown...maybe it was the timer all along.
Jul 24, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Have a freezer on bottom fridge that keeps freezing where the fan is
defrost not working check defrost t-stat, timer, or heating element.
find timer and rotate till compressor turns off; defrost should start and melt ice, if no melting then check defrost t-stat ( round disc located nead heating coil) if you remove it and jump around it will begin to heat normally. If so then do not leave it jumped!!!!!!!! Replace it and you're done!!!!!!
Oct 24, 2009 | GE Refrigerators
No heat. Coils should be good as they were
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 14, 2009 | Amana NDG7800AW Gas Dryer
Dryer ran all night now no heat
Jul 13, 2009 | Estate TGDX640JQ Gas Dryer
Whirlpool gas dryer what does the heat ciols look
Jul 12, 2009 | Whirlpool LER5636P Electric Dryer
Timer not running and no heat
Sound like you need to replace the heating elament you will need to take your model number and make to repair shop for replacement parts or have a repair person come out and fix it for you . thanx for using fixya
Jun 15, 2009 | Kenmore 73952 Gas Dryer
No heat and the timer won't turn the dryer off
The timer runs thew the heat cycle with no heat it will run forever the heat runs thew the timer and thew thermstats and thermal fuses be for going to the heat elament check for 220volts at the heater if the heater has 220volts to it and not heating the elament is bad
Nov 30, 2008 | Roper RGX4634KQ Gas Dryer
GE (PSS26MSRSS) Side by Side Refrigerator Logo
493 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
