Question about Whirlpool LER4634J Electric Dryer
Won't start light comes on and no circuits have been tripped
    Genius:
  • 1,122 Answers
Check the door switch,also remove the back and chek the main fuse(it is long and white)mike
Posted on May 09, 2010
Electrolux EWF1074 suddenly no power at all. Working fine before.
While there could be many reason, begin by looking at the power source. Has it tripped a circuit breaker or blown a fuse?
The most common cause:
If the fuse is ok next check the door interlock. If the lights come on but the machine won't start, this might be the issue. The door interlock is the safety device that sends a signal when the door is securely closed so that your washer can run. You will need to call in a professional to trepair this fault.
Less possible but still reasonable:
If you've run several loads, one after another, your washing machine may refuse to start due overheating.
You will find a more detailed explanation here
My Washing Machine Won Start Find Out Why
Jan 11, 2018 | Electrolux Washing Machines
Main oven wont come on or the light but the fan does
Hi, I hope I can help you. If you're referring to the overhead fan above the oven, that fac is usually on a separate circuit. The oven itself is connected to a separate circuit breaker, hence, that is why the oven and light won't come on.
Check your circuit breaker box, and see what circuit has tripped. Check to see if there are any burn marks around the breaker before resetting it.
The reason the breakers may trip, is the breaker is old, may have the incorrect rating, or may be linked to other circuits, such that when too many items are all drawing power at once, it will trip the breaker.
Feb 02, 2016 | Ovens
Smart drive
Will need the tender hands of a qualified repair person.
Jul 07, 2013 | MediaFORM SmartDRIVE (CD-816T) CD-RW...
2001 heritage softail that won't start, please HELP!!!!!
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to Ignition
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a prime suspect please visit website below and good Luck.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
May 11, 2013 | 2000 Harley Davidson FLSTC Heritage...
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
Can i make a 40 amp circuit breaker with two 20 amp breakers?
Yes. A two-pole breaker is just two breakers hooked together. But the very important part is that if one pole trips THEY MUST BOTH TRIP. If only one trips, then the circuit won't operate the appliance (whatever it is) but one of the poles will still be live!
Jul 19, 2012 | RTO Pushmatic 40Amp 2-pole circuit breaker
1996 yamaha royal star won't start only the red light on the gages comes on when you hit the starter button it has full power were do you start
Hi, Joezeppee200 and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Main fuse or circuit breaker may be blown or faulty.
10. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Bike won start Need advice
Steps to Take When Your Motorcycle Won Start Dennis Kirk Powersports Blog
http://www.yamahaventure.nl/pdf/servicemanualxvz13tf.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/1998/Lit-11626-11-17_320.pdf
Sep 10, 2011 | 1996 Yamaha Royal Star XVZ 1300 A
Dryer model DBSR453EB1WW won't start. It has power and the light comes on when the door is opened, but when you try to start it there is nothing.
8_29_2011_7_53_41_pm.jpgYou might have a tripped high limit. Looks like this.
Mounts on rear wall atop the heater element. If the dryer needs cleaning it someimes will overheat and trip this limit. I recently repaired one of these and made some PHOTOS
Aug 29, 2011 | GE DBSR453EBWW Electric Dryer
Compressor tries to start but won't ...odd odor when fan runs....approx 8 year old unit... will trip surge protect power strip, but not 20 amp circuit..
IT PROBABLY IS OUT OF FREON AND AS IT TRIES TO START DUE TO THE LACK OF REFRIGERANT AND OIL IN THE LINE IT SHUTS OFF OR IT COULD BE A BAD STARTING DEVICE ON THE COMPRESSOR THAT POPS THE POWER TRIP.
Aug 01, 2011 | Breezaire WKL 4000 Wine Cooler
Whirlpool LER4634J Electric Dryer Logo
56 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
