Question about Philips Televison & Video
Phillips TV model 26HF5444/10 is locked, cannot view menu etc.
3 Suggested Answers
tlm931
  • 273 Answers
SOURCE: My Phillips Plasma tv MENU pops up unasked and obscures screen.
there is a soft ware upgrade for that problem on there web site you can down load it to a thumb drive and upgrade your set
Posted on Oct 31, 2009
SOURCE: screen is black but we have sound
The problem is a faulty inverter kit (2 boards).
I live in the Netherlands and had it twice, tv is 2 and a half years old! In the Netherlands Philips replaces the inverterkit without any
costs for the consumer (even after warranty time) cause they have
admitted that it is a production fault.Philips made a new inverterkit
which should solve the problem indefenit.Be sure the kit is Version
1.3! I had 1.2 after the first problem, and that went wrong after 7 months again. Today got revision1.3 installed which is Philips final solution.
Posted on Jul 21, 2010
Testimonial: "Thanks very much for your help. I will contact Phillips Ireland and see what they can do.Thanks again"
How do i get the v-chip lock code to unlock the parental lock from my Mitsubishi model code ws-55413
Bypassing the V-Chip Lock
After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus.
If you forget your passcode, you can view the locked TV without entering your passcode. When your password is requested, press the number 9 and QV buttons on the remote TV control at the same time. This process temporarily unlocks the TV.
When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode
hope this helps
John.
Jan 11, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I have an apex tv that has a lock(key symbol) on the lower left corner of the screen. The tv seems to be locked how can I unlock it? I using a phillips universal remote.
Hello
Just try the following to unlock your Apex TV.
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
  1. To use the override code:
  2. Hit the MENU key to get to the menus.
  3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
  4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
  5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
OK.
Dec 27, 2010 | Apex Digital AT2702 27" TV
Phillips TV with no on screen menu, only Caption, Text and Sleep. bought TV's from factory auction. PA5032-C102. or 32R505-00BB.
The OSD (on screen menu) is locked. Those two serials (not models) are for two completely different tv's: the first is for an very old standard 32 inch CRT and the second for an old plasma.
To unlock it in the first tv you need to just press the menu button for 10 seconds. For the second tv you must start the tv and immediately press both the menu and channel up buttons for 5 seconds.
Dec 15, 2010 | Philips Televison & Video
How to install digital TV via Free View Box
Put ur tv in channel 3,take the cable came with the converter box put it in tv antna hole in the tv ,the other to the converter box said tv.Take antena,portable or roof antena put it in the converter box said antena hole. Go to menu resacan channels u done.
Nov 15, 2009 | Televison & Video
How do I access the menu without a remote?
You don't. A good "universal remote" available from Radio Shack (Phillips) for about $15 will provide access to all TV adjustments. Easy to program for all TV models, VCR's, DVD players, etc. About $35 + S&H for the Sharp remote replacement.
Nov 14, 2009 | Sharp 27J-S100 TV
Channel instalation problem
Phillips' Website contains manuals etc for your unit.
I was able to view the manual for this model (their UK manual) here
This is according to the model number you listed...
I would print out a copy and keep with your files...
K
May 13, 2009 | Philips Televison & Video
Tune 14 inch TV on remote ie BBC1 on No 1 thro to No5.
here is a link to thhttp://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&cat=TV_CONVENTIONAL_CA&sct=COMBI_TV_SU&session=20090102155334_65.38.34.98&grp=TV_GR&ctn=14PV182/05&mid=Link_UserManuals&hlt=Link_UserManualse manual
Dec 29, 2008 | Philips TV Tuner Video Capture PCI Card -...
Phillips TV Model 25HT2012/79R
YOU GET INTO INSTALLATION MENU WITH USUAL REMOTE THAT COMES WITH THE UNIT
PRESS 3-1-9-7-5-3 MUTE WHICH GETS YOU INTO THE INSTALLATION MENU WHERE YOU CAN DO YOUR TUNING ETC.
Dec 13, 2008 | Televison & Video
When Turned on the Screen says ''Locked''
Please post the model of your TV. 0711 is a default code to access the blocking menu items on some Phillips TVs. have you tried changing the channel. maybe it's just the one channel is blocked. More likely the TV may be in a blocked mode. If you have the manual there should be instructions to reset the blocked mode. There are manuals online. Use Google or any other search and type in your model number and "manual."
Nov 25, 2008 | Philips Televison & Video
Phillips 28PW6006/05-Locked
First you need to get your remote working, without it you cannot unlock the tv. If the romote is not phisically broken (or smashed) make sure the battery contacts are clean and install new batteries.
Once you get the remote working (hopefully) Enter the MENU and select 'Features'. Set the Child Lock to OFF. If you cannot get the remote to work try a universal remote, setting it up with the codes for your tv provided in the setup manual for the universal remote.
Mar 17, 2008 | Televison & Video
Televison & Video Logo
242 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
