Question about Bosch WFMC 3200 Front Load Washer
Loud ratteling sound when spinnining
I took back panel off to see if something lose or stuck it was clean. it spins freely. there is a sound when i turn belt that is coming from the shaft of the motor. does this mean motor might be on its way out or maybe just lose or something that needs maintaining?
  • Bosch Master
  • 2,605 Answers
Hi, You could try it without the belt on and see if it is noise created by the motor, could be easy to repair if so. **shut off the breaker before trying to service it in any way please** Although there is no adjustment and these are "brushless motors" there may a loose mounting bolt, check closely for that. Worst case scenario the motor is available for around $150-$175 at most brick & mortar parts places or on-line vendors like repairclinis.com, apwagner.com etc. Let me know what you find out, cross your fingers and good luck. Macmarkus :)
Posted on May 09, 2010
  • 2 more comments
  • Mark MacDonald
    Mark MacDonald May 10, 2010
    Hello again Steve,
    not sure how your diagnosis went but I realized I had mis-spelled one of the on-line parts depot's. It should have been repairCLINIC.com as oppossed to repairclinis.com. Sorry for any confusion I may have caused.
    Let me know how you made out or if you found the cause if you don't mind. Your symptoms are not that common to the "WFMC" Bosch so I'd like to find out what was happening if you can post your findings.
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald May 13, 2010
    Hello again,
    I was wondering how you had made out and what you found. Can you post an update or status report ?
    I just like to do a follow-up on where you'd left off with your question, did our suggestions here yield anything ?
    Please let me know when you have a moment.
    Thanks,
    macmarkus :)
  • Mark MacDonald
    Mark MacDonald May 22, 2010
    Going once...
  • Mark MacDonald
    Mark MacDonald Jun 12, 2010
    Going twice...
GE Profile top load washer not spinning during drain cycles. Have tried resetting motor with door switch trick but still stuck. Water drains but machine not spinnin out.
it seems to me that the water sensor switch is not letting the control panel that the water has all gone therefore check in the back of the machine and look for a small 5mm pipe take it off and blow gently into it you should hear a click and one when you let the air out if so then the place where you took the pipe from is blocked not allowing it to operate so take a pipe cleaner or a steel rod to fit the hole and unclog it its normally blocked with soap goo eric
Jan 02, 2018 | GE Washing Machines
Bissell heavy duty 9x cyclonic vacuum cleaner has loud noise when brush roller is turned on
Inspect the area around the brush roll. There may be something stuck somewhere in there. Remove the brush roll to see if the brush roll end caps will spin freely. If there is hair or debris restricting the brush roll may be causing noise.
Feb 19, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
How to fix a motorola solid state turntable that turns on but wont spin
Hi, remove the platter and check the state of the idler wheel. Is it in good condition? Doe's it spin freely? The cause of the problem should reveal itself. Keep em spinnin, John. Stylus City
May 03, 2014 | Audio Players & Recorders
Whirlpool cabrio washing machine doesn't spin
Try to turn the drum by hand, if it hard to turn, there may be something stuck underneath spin basket. If it does turn freely but makes a loud growling sound, you probably have a bad bearing. You should notice black oil and water mixture at bottom of washer, on the rotor. It will usually throw a f51 error code. This unit has service bulletin on this problem.
Apr 05, 2014 | Whirlpool WTW6400SW Cabrio Washer
My 2000 dodge neon has a loud noise coming from the front and feels like something is not letting the tire move freely
Safty first,Can you safely jack the frount of the car chalk the rear tires and put the transmission in nuetal. Try to spin the wheel by hand. Then take the wheel off and checked your brakes? It could be be the brake pads or caliber locking up. Or as simple as a rock stuck in there. I hope this helps you.
Feb 21, 2014 | Cars & Trucks
Making a loud sound
could be that the clutch is bad or the brush roll needs to be removed, cleaned, ends removed and lubed. Try to spin the brush roll and see if it moves freely...if not, it needs to be cleaned and lubed at both ends. I fixed mine today by doing this...not an easy task to remove the brush roll, but it can be done:)
Mar 17, 2013 | Miele S7210 S7 Series Twist Upright Vacuum...
Kenmore oasis makes loud noise when spinning
You can check the shock absorbers, maybe is not in good conditions.
Dec 23, 2017 | Maytag LAT3600A Top Load Washer
Loud blower on my Coleman Furnace
Usually a noisy blower motor is a bad bearing. The motors now have oil impregnated bearings and you can't oil them, you have to replace them.
Sep 19, 2012 | Coleman Mobile Modular Home Electric...
Loud Clicking rattle during spin
you may have something stuck in the pump
pull hoses off pump and see if there is anything stuck in it
Jun 13, 2009 | Admiral AW22 Top Load Washer
Slow to spin and making a loud noise.
Control boards don't growl, the fry out and die. Sounds like a drive train problem to me. If it's a front load machine, the spindle/bearing assy. has gone to washer heaven. If it's a top load machine... could be the transmission, brake/clutch assy. or the tub bearings. In either case, if it's less than 5 years old, the drive system will be warrantied through the manufacturer. If you could provide a make and model number, I could narrow this down to a fine point.
Dec 15, 2006 | Kenmore 43142 Front Load Washer
Bosch WFMC 3200 Front Load Washer Logo
112 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
