Question about Ryobi 18-inch Electric Chainsaw Chain Saws
I have a Ryobi ecw 1835 electric chain saw. The electric motor is working but it doesn't turn the chain. What might have broken? Thanks Duncan
Has the guard had its saftey device activated?
Posted on Sep 11, 2010
Bought a Ryobi cs214 at a pawn shop. There is no oil in the holder for smooth running of the machine. Would like to know what kind of oil does the Ryobi CS214 takes.
Just fill the tank with regular bar/chain oil available at home centers, hardware stores, and saw dealers. Don't use old used motor oil or similar. Hope this helps!
Dec 21, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
No local Ryobi dealer; what other brand chains will fit my 18" Ryobi ?
Any saw service dealer can fit a chain to your saw. 'Oregon' saw makes bars/chains for about any saw made in the last 50 years or so. Just take the chain itself in to get a replacement. Good luck!
Nov 18, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
I bought a ryobi 14 inch electric chainsaw. Is
Use regular bar/chain oil available from home centers, hardware stores, and saw shops. Always keep the chain properly sharpened and tensioned so that you don't have to force the chain into the cut which causes motor overheating. If you need to make an 'under' cut, do so with the top of the bar--don't run the saw upside down. Good luck!
Jul 30, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Start procedure for chainsaw ncr 4550
The header says that this is an electric saw which doesn't have a start procedure--just push the button and it runs. Electrics also don't have a clutch because the motor doesn't need to continue running when not cutting like a fueled engine does. Most electrics, however, have a safety device that uncouples the chain drive sprocket from the drive shaft to protect the gearbox. Remove the bar and chain, then look for a broken/disconnected drive link or spring connected with the sprocket. If the shaft itself does not turn, then there is likely problems in the gearbox. Hope this helps!
Jun 03, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi ECW 1836 electric chain saw. No drive
Check to be sure your chain brake is in the OFF position Pulled back towards the operator
Apr 01, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Chain saw brake does not go off
Your switch is broken and needs to be replaced. You can do it yourself when you get the part from a Ryobi dealer.
Jan 16, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Just received recondition Ryobi 18 volt chain saw. Motor runs backwards.
electrical motor was wired in reverse, If you you attempt repair assuming product was purchased from store ,your sure not to get a fund or in-store credit.
Dec 07, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
Ryobi 540A need manual runs slow/ chain too tight?
Actually, I own one of these battery operated Ryobi chain saws too. It is normal for the saw to run slow. Remember it is battery powered, not gas, so its not going to be a high rpm saw. Be patient whit it, and you'll get about 4-6 cuts per battery. I take mine camping. It sure is nice not having to listen to a two-stroke while relaxing in the woods! Dont plan on cutting lots of stuff, either, or you'll burn up the motor. This thing works great for very mild workloads.
Aug 14, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
Ryobi 18-inch Electric Chainsaw Chain Saws Logo
496 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
