Question about Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven
My electrolux premier cooker oven isnt working
After swiching on the oven,the house electric sockets all went off.when i did a reset on the power,the oven wouldnt work.
  • 187 Answers
Check to make sure that the circuit breaker/gfi is not flipped for the oven. Push the switch all the way to off and then on again. If the power goes off again, this indicates a short, which is very dangerous.
If you already checked this and the power does not come on, make sure the breaker is set to off and pull the oven and check the cord and plug for any sign of fraying, loose wires, blacked areas, etc.
Since this is 240v, I would not recommend going beyond these basic instructions. If you feel confident to remove the panel to run some electrical tests, please post comments and we will help you do that.
Posted on May 09, 2010
Electrolux EOD5310 Electric Double Oven power to oven but no heat
If you have a problem with your Electrolux EOD5310 cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Jul 06, 2014 | Electrolux EOD5310 Electric Double Oven
Oven problem
have you tried resetting the house RCD for the cooker supply? Alternatively if you had to pull the appliance out it could simply be a loose connection
Apr 04, 2014 | Ovens
Electrolux EOD 985 bottom oven over heats burnng food
thats because the heat sensor isnt working properly need to replace
Apr 25, 2012 | Ovens
My new oven electrolux EUEE63CS WILL NOT TURN OFF. display lights turn off but oven still going
My oven seems to turn off but the fan keeps working! Takes about 1hr for the fan to turn off after l have turned oven off. Is this normal? Im quite concerned. Will be calling help line monday morning......
Jul 28, 2011 | Electrolux 30" Built-In Double Electric...
Electrolux oven won't come on
It appears that the "return to manual" button has to be reset
Aug 25, 2009 | Electrolux EW30EW65SS Stainless Steel...
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
Cant set cooker clock so cant use oven as a result
You will probably have to replace the cooker clock. Do any of the other parts work? This fortunately is not that expensive and you were blessed not to have more damage than this.
Jan 29, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Display works but no lights on either oven and no fan
If the display is flashing, it sounds like the timer needs resetting
U need to refer to your instuctions on how to do this..
If it does it again once u have reset it, then I suspect that the oven element has blown..
Pls leave feedback.
Thanks.
Nov 28, 2008 | Hotpoint DY46 Style Line Stainless Steel...
Electrolux EOG7330 gas cooker - electric timer fails?
Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
Jul 18, 2008 | Electrolux EOG7330WN Gas Double Oven
Hotpoint DY46
had the same problem with my Electrolux. Element blew and the fan stopped working and food was stone cold. I pulled the element out - had to remove the rear panel to get to the wires but the element came out from inside the oven by removing a few screws. Went off to the local Applaince store and bought a new element which was pretty dear as this model was made in NZ. Replaced the element put it all back together and away she went. If you do it yourself make sure you TURN OFF THE POWER at the power box. It is a good idea to have an electrical tester to make sure the element is the problem. These are usually not hard to repair and it is usually just a few screws to remove the rear cover and possibly a cover inside the oven to get the element out. A Handy Person will be able to do this job. Hope this helps.
Regards
Bryan
Jun 01, 2008 | Hotpoint DY46 Style Line Stainless Steel...
Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven Logo
255 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
