First go to Control Panel, Hardware, Devices and look for your webcam. Go through the tabs to make sure it is Enabled. If you don't see your webcam, or you can't click enable, then you will need to reload the software drivers, either from disc or the manufacturer's website. Once you think you have it working you may want to reboot your computer, and then try the free webcam test tool.
The error message "Webcam Not Found, Connect USB Device Message" or a message stating to plug in a webcam, indicates that there is an issue with thewebcam hardware.
The system will need to be serviced to correct this issue.
If the error is just regarding webcam not found, the drivers and the Application has to be installed.
