Question about RCA HD50LPW42 50" Rear Projection HDTV
Really green picture with flashes
My RCA hd50lpw42 Works fairly normal at power up. after a few minutes the screen begins to flash and flicker then it goes really green and flashes and flickers a lot. you can turn off the power let it go through cool down and power back it starts all over
  • 1 more comment
  • danandtonya Jul 13, 2008
    When I turn on the tv after about 20-30 minutes the tv flashes green. I noticed in the past that there was a hum coming from the tv. I have read that this is the color wheel, and also read that they are not making the color wheel anymore. I purchased the tv from Wal-Mart in '07. Hope you can point me in the right direction to get a replacement wheel.
    Thanks,
    DAN
  • aerocool Jan 31, 2009
    I replaced the bulb about 6 months ago and just now replaced the color wheel. I am still getting the green lines to come across the picture randomly and it is jumpy when I go to the menu screen. What next?
  • Anonymous May 13, 2009
    I have the same problem with the picture going pure white and black for a few seconds and then going all black, only displaying sound, and then the TV changes channels by itself. If it were just the color wheel why would the TV change channels by itself?
  • 59 Answers
Hi...the flickering and the green is the colorwheel going bad. Very common for this model and an easy fix too.
Posted on Mar 28, 2008
  • LeAnn Hill
    LeAnn Hill Mar 30, 2008
    This will help.
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
My RCA rear projection wont turn on the light flashes when i push the power button, i got it to turn on once and i had a vertical line running through it. and colors a little distorted, i tried in the menu...
The flashing light opposed to a solid pwer indicator light usually means it needs to be serviced. I wouldn't reccomend home repairs, but repairs sometimes cost more than the product. You should compare prices and such before making your move.
Aug 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
White flashes on screen , then temporary black screen.
I would try the lamp first,if it has never been replaced they only last for up to 5,000-8,000 hours.
Jun 17, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Compaq 7550 monitor keeps turning pink. Works fine for a few minutes then back to pink and hard to see. Sometimes moving the mouse quickly will help but only for a few minutes. Have tried adjusting all...
Defective CCFL backlight may has the following symptom:
· Screen flashs on red/pink and off.
· Picture stays on in red and slowly be come normal.
· Picture flickering with dim display.
· Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Power button blinks, tv won't turn on
replace the flyback, that should straighten it out. You need flyback 259296 you can get one at the following link with free step by step instruction on how to replace it, from beginning to end.
http://servicemanuals.vstore.ca/
Sep 05, 2008 | RCA HD52W59 HDTV Projection Television
Screen goes crazy after about 1 minute
try it on tuner mode to seperate the fault from video to rf input,if gone the video pc board is at fault.
Aug 11, 2008 | Samsung HLN467W 46" Rear Projection HDTV
RCA D52W20 52" TV SHUTS DOWN AFTER A FEW MINUTES
this is the filment circuit having a problem. i think you will find it is a loose connection on a solder joint. Goodluck
Jan 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
36" RCA TV SNOWY WITH GREEN BARS FLASHING
I believe this has a tuner built on the board it has to soldered
Dec 06, 2006 | RCA F36645 TV
RCA HD50LPW42 50" Rear Projection HDTV Logo
183 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
