Question about IBM Lenovo 3000 N200 PC Desktop
My password don't work i need to reset bios cmos help me please ;
  • 69 Answers
There is usally a jumper on the mother board that needs to be moved which will clear the cmos if that doesnt work you can try removing the cmos battery aswell as the power from the unit and leave that way for a day or so and then insert the battery and power
Posted on May 09, 2010
Please can you tell me how to reset the cmos on a samsung R510 Laptop
Hello you just have to remove the cmos battery:
Press the release pad and the battery will pop out
DO NOT have any power on disconnect all power and usb cables
when you do that.
Wait for 10 min. or so with the battery out
and the bios will reset back to factory settings.
Replace the battery and boot up your machine and enter the bios
you kave to configure the boot order.
Here is some youtube videos how you do that:
http://www.youtube.com/results?search_query=Intel+D945GTP+bios+setting&oq=Intel+D945GTP+bios+setting&gs_l=youtube.12...55167.59517.0.61846.6.6.0.0.0.0.85.411.6.6.0...0.0...1ac.1j2.lSt1MwgqUkQ
But it depends what bios you have.
Good luck
Dec 04, 2011 | Intel D945GTP Motherboard
I forgot my BIOS password and i can't access it becos i don't know the password.
HP Spare Key can be used to reset BIOS password. It is provided by HP Corporation. So when you forgot BIOS password on HP computer, just download it and get perfect BIOS password reset.
How to reset HP bios password with Spare Key or other ways?
Please refer to reset HP Elitebook password. In this passage, you also can learn how to reset Windows administrator password easily.
http://www.isunshare.com/windows-7-password/reset-hp-elitebook-password.html
Jun 12, 2011 | HP Compaq 6730s Notebook
Hello, My name is Vahe and I have got the following problem, I have forgot my BIOS password and I can't to turn on. Laptop model Toshiba satellite A200-13M. So I have got some solution to delete...
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 02, 2011 | Toshiba (K000002020) Motherboard
How to I reset the bios password,on my LT2021u?
If you know the bios password, then change it in the bios menu,if you don''t know the bios password, then clearing the cmos battery should work. You will need to disemble your netbook apart until you can get to the motherboard, there you should see a baterry of a nickel size and take it out and back it, resemble your netbook and you should be good to go.
Here is a link that may help you out too. http://www.askvg.com/how-to-reset-remove-bypass-a-bios-or-cmos-password/
Jan 30, 2011 | Gateway LT2021u Netbook
Hello : my problem is i have laptop acer model 5230z : i cant access to the bios becuas is encrypted in passwoed and i try all way that found in web put is no result thank you i hope be help me
There are four common categories of solutions to remove or reset a BIOS password and here are the details on how to go about resetting your BIOS password.
Manufacturer Backdoor BIOS Password
Most of the BIOS makers have set a backdoor password on the older computer models. That is the master password for BIOS. To reset BIOS passwords first you need to check the manufacturer of your computer's BIOS. Most computers have BIOS include AMI,
IBM, Award, and Phoenix. These are the most common BIOS. You can unlock your locked BIOS using this master password. It works, no matter what the user sets the password to. Many popular computer and laptop manufacturers such as HP and DELL lock the BIOS because they want to protect their machine's most sensitive areas (those areas which have warranty) from their customers. These passwords are usually used by computer technicians for testing and repairing.
Reset the jumper that holds the password
Open the computer and locate on the motherboard the BIOS password jumper. The jumper is usually jumper 1 and often labeled as PSWD, PWD, CLRPWD, CLEAR, JCMOS1, CLR, CLEAR CMOS, PASSWD, or PASSWORD. Normally you would have 3 pins and to reset the password you just need to put the jumper on the 2 and 3 pins leaving pin 1 empty. After you move the jumper, turn the computer on to clear the password, then once password removed turn it off and put the jumper back to its original position.
Removing the CMOS Battery to reset the BIOS to default
Switch off your computer, and open up the case. You'll see a circular metallic silver item on motherboard. This is called CMOS Battery. Remove it carefully, and leave it out for about 2 minutes. This act will remove the CMOS memory which contains BIOS password. Set the CMOS battery back and switch on the computer. Restore the CMOS configuration as default. Your BIOS password has been cleared now.
Using third party software utility to reset BIOS password
To reset BIOS you can use third party software like Kill CMOS which wipes out CMOS, or CmosPwd which is a BIOS utility. Hiren's Boot CD has a few programs including the above two that will help you to reset the password. Here is a link to Hirens Boot CD website http://www.hirensbootcd.org/. To download the latest version, click on the Download link on the left side and go to the last page. You will need a CD writer to put the content on a blank CD.
Please let me know whether this works or not.
Dec 26, 2010 | Computers & Internet
Hi i am an indian.sir my laptop toshiba model:satellite A130/A135 Series is asking for bios password.ples help me.
Hi.
If you dont remember the BIOS password, you may remove it by resetting the BIOS password.
Please follow the below steps to reset the BIOS password:
1) Please remove the bottom casing of the Notebook.
2) Once you have removed the below casing, you should be able to see a CMOS Battery.
3) The CMOS Battery will be of a size of a coin.
4) Once you have found the CMOS Battery, please remove and re-insert it again.
5) The CMOS Battery will have the information about the Computer Date, time, BIOS Password etc.,
6) Removing and re-inserting the CMOS Battery will reset these settings, which will also remove the BIOS password.
Please perform the above steps and let me know the results.
Hope this helps.
Please feel free to contact for further information and assistance.
Oct 02, 2010 | Toshiba Computers & Internet
I have a Wipro Laptop. His BIOS is Phoenix. It has a CMOS password. How shall I clear the password.\?
Hi Nayanranjani.
As you trying to reset the BIOS password, let me provide the required steps.
You may reset the BIOS password by just removing and inserting the CMOS Battery.
The CMOS Battery will have the Computer date, time and also the BIOS password saved in it.
Hence, removing and re-inserting the CMOS password will reset the BIOS password.
Once the BIOS password is removed, you may assign a new BIOS password.
Hope this helps.
Please feel free to ask further questions.
Aug 18, 2010 | Computers & Internet
How do i reset bios password on a used dell 710m inspiron?
For you to reset the bios all you need to do is to take it out, but before you do that you'll need to power off your laptop.
Regards
Oct 13, 2009 | Dell Inspiron 710m Notebook
Crack bios password on compaq nc6320 - please
You can crack dell bios password with Windows Password Recovery Tool 3.o . Here is a good post to help you:
http://www.windowspasswordsrecovery.com/crack-dell-laptop-password.htm
Oct 09, 2009 | HP Compaq nc6320 Notebook
I neeed clear bios cmos and cmos run to my hp ze4315us
Restart system holding down f11 key till it beeps. Dont forget to backup your documents.
May 26, 2009 | HP Pavilion ze4315us Notebook
IBM Lenovo 3000 N200  PC Desktop Logo
136 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
