Question about Grilling
I have a 5 burner grill that will only burn 2-3 burners. As soon as I turn on the 4th burner. They all go out. Is this a regulator problem?
  • 187 Answers
You should not smell propane at any time when the tank is closed or the flame is lit. Make sure that the connection is tight between the grill gas line and the tank. You might want to take it off and reattach it to make sure there is no cross threading that is preventing a good seal.
The new tanks have a safety valve that can interrupt the flow if the knob is turned to on before the tank is opened. When that happens, the flame is low and sputtering. It will often go out if all of the jets are turned on at once.
You can actually hear the difference when you first turn the knob. If the valve is opened fully, you should hear a healthy hiss from the gas. You should use the ignition quickly after turning the knob and pay attention to whether one jet is assigned as the one to light.
It can be a regulator on the gas line as well, but this is actually less common. If you have not had this problem before hooking up this particular tank, try a new one. Those trade in tanks are often culprits because all tanks should have been updated to new standards a few years back. The trade ins are often older than they should be. There's a date on the top that will give you an idea.
Other than that, make sure that there is not a lot of debris, no loose connections, and the jets are clean. Thanks for using fixya.
Posted on May 09, 2010
Burning Hot and Burning propane tank empty in 2 to 3 uses
What does "and parts to burners" mean? it sounds like you have NG orifices on a LP appliance or the LP orifices are not properly drilled. I use my barbecue several times a week and exchange an LP cylinder about every 6 months. If you are using the grill twice and the cylinder is empty that is not a lot of burning, that is a leak.
to adjust the burner the first and most obvious place to look is to check the pressure on the regulator (LP is 11") and the orifices. Next are there adjustment screws inside the valve stems? if so light the barbecue so the flames are visible and insert a long flat-head screwdriver to adjust the set screw inside the valve stem. turn the valve to "low" and adjust it until the flames are just barely staying on. Leave the set screw in that position and turn the valve on high, close the lid. if you're over 400 degrees in 10 minutes you'll be fine. if not adjust the set screw up a quarter turn at a time.
Feb 24, 2014 | Barbeques Galore Grilling
Gas grill was washed now it won't light
Regulator. Tanks were non burped... Regulator stuck. Turn off tank slow. disconnect. Turn burners on. Tap the regulator with a piece of metal. Turn burners off. Connect tank. Since it was washed out electric starter dont work. Turn burners on. Then you will hear it. Gas. Take lighter and start. Big startup. The hair on your hand burned off wash your hands. Then get the meats! Easy as Cake
Jul 13, 2012 | Grilling
We have intermittent low gas flow to our Viking grill. We have replaced the burners and the regulator. It worked fine on Sunday but now today only the first burner lights (and it's low even though I...
Lynn, the problem lies with the gas regulator and the way you turn the tank ON. But it's readily solvable.
1. Turn the tank valve OFF & disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the valve is fully open, light the burner farthest from the tank first and set it on HIGH.
Does the flame height look correct? If so, light the remaining burners the exact same way.
Do all the flame heights look correct? If so, your solved the problem. Always remember to
open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. They run about $30.00 at any hardware store or home center that sells grills and accessories. Simply take you old one with you for comparison purposes.
Hope this helped you troubleshoot & solve the problem. Please let me know. Thanks.
Jul 06, 2011 | Viking VGBQ410-3RT Grill
I have a brand new , full tank of propane. I cannot get the propane from the tank to the burners. I am not sure if Ihave a bad hose and regulator or a bad valve that will nto allow the propane to flow...
Julian, let's get this corrected for your 4th of July Cookout.
1. Turn the tank valve OFF and disconnect the hose from the tank.
4. Once the valve is fully open, light the burner farthest from the tank first & turn it to HIGH.
Did the burner light and the fa,e height look correct? If so, light the remaining burner exactly
the same way. Now, do all the flame heights look correct? If so, you solved the problem.
Always remember to turn the tank valve ON Very, Very Slowly.
If the above didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly, as the regulator is locked up. You can pick one up from any home center or hardware store that sell grills and accessories for about $30.00. Take your old one with you for comparison purposes.
I hope this helped you troubleshoot and solve the problem, Please let me know and Happy Grilling!!
Jul 04, 2011 | Weber Genesis E-310 Gas Grill
Flames on burners not at full flame
Hope you get this in time for your 4th of July Cookout.
Jul 04, 2011 | Weber Genesis Gold B Grill
My grill is on, the flame is burning, but the temperature never gets up to 300 degrees with all 4 burners going
Try this, turn on just one burner, once it is lit, turn on a second burner. If the flame on the first burner gets lower when you turn on the second burner, you probably have a bad regulator. Replacing the regulator is cheap and easy and may solve your problem.
Jan 10, 2010 | Kenmore Grilling
My grill burners burn unevenly and usually too high. Adjustment?
If this is a natural gas grill, check to see if it has a regulator on the gas line. If it does not, you can install a regulator to reduce the gas flow.
Dec 01, 2009 | Char-Broil Commercial Stainless Steel...
Loss of pressure on Kenmore 16322
I can tell you EXACTLY what is wrong. Remove the tank and open all valves to the grill. Reconnect the tank and turn it on just slightly. Relight the grill.
Ther is a safety device in the tank that needs to be reset. The only way to do it is removing the tank.
Dec 17, 2008 | Kenmore 16322
Kenmore 4 burner grill only lights 3 burners
Looks like your regulator is not venting properly to relieve the back pressure. The best thing you can do here is replace the regulator.
May 27, 2008 | Kenmore 490 sq. in. Cooking Area Gas Grill...
Grilling Logo
61 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
