Question about Panasonic PT-50LC13 50" Rear Projection HDTV
I replaced the lamp in my pt-50lc13 tv. this is my second lamp. I sent the fistone back, thought it was defective. Is there something I am doing wring. I cant get the tv to turn on. It blinks green for a wile the back to red inicating its the lamp.
  • Panasonic Master
  • 5,138 Answers
Make sure the Lamp Fan is running if it stops cooling Lamp or is not running Lamp will not Light.
Posted on May 09, 2010
We are having the same problem. Turns out, it's probably not the lamp, it may be a problem w/the ballast needing to be repaired, or replaced. Look into that.
Posted on Jun 07, 2010
PT-50LC13 reset lamp timer
Replaced the Lamp, on my PT-50LC13 pan TV. But cannot reset the timer because the screen does not light up. and the instructions say to hold down the -Vol button and the pip button. But which one? there are 3 buttons with the word PIP
Apr 02, 2010 | Panasonic PT-50LC13 50" Rear Projection...
How do you remove the lamp
To replace lamp in Panasonic PT-50LC13 tv, please follow this...
1- Place your fingertips under the front cover and pull it from the projection display.
2- Loosen the lamp cover screw using a screwdriver.
3- Using a screwdriver, loosen the lamp unit screw.
4- Grasp the lamp unit handle and slowly pull the lamp unit from the projection display.
5- Put new lamp and fix things in reverse order.
Now need to reset lamp timer as follows,
While pressing the VOL Down button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneously for more than 5 seconds.
When lamp timer will reset, tv sill show "lamp time was reset to 0" message.
Hope this info will help you.
Thanks.
Feb 25, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Panason PT-50LC13 TV won't come on, light blinks green then red
Ballast failure is more that likley the problem. Is the lamp light blinking,...once every 5 seconds? Discontinued part and can only be purchased used or rebuilt. Rebuilt units are available, check Ebay. Have a service type person confirm problem before throwing good money after bad!
Jan 03, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I just replaced the lamp in my tv and now it shuts
You probably have a defective new lamp. Did you put the lamp door back on?
Aug 08, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panny pt-50lc13 steady amber flashing light
Sounds like a defective lamp diever or ballast.Listen for a buzzing sound when you turn the set on. If you do not hear it then most likely you have a bad ballast or lamp driver. Worst case scenerio would be the engine itself.
Dec 28, 2008 | Panasonic PT-50LC13 50" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Ballast problem on PT-40LC12
Sent me the serial number, and I can check for any re-call ...
my e-mail is <ultraman_s@yahoo.com>
Feb 01, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
Nov 19, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
326 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
