Question about LG WM-2277HW Front Load Washer
Vibrates badly My LG wm2277hw vibrates very bad on spin cycle,dances across the floor
  • 3 more comments
  • rinaldos Mar 28, 2008
    Purchased in Jan. 2007
  • mee338 Nov 29, 2008
    vibrates VERY badly
  • iatrkmn Dec 01, 2008
    I have put a level on all sides, it is level but still moon walks like MJ what do I do?
  • sim36 Dec 05, 2008
    Have had washer two weeks. 8 loads. Last two machine violently shakes. All plugs removed. Put level to machine. Completely level. Machine is a WM2233H. We are concerned that use will cause severe damage to motor, etc. Any suggestions?
  • robert samples May 11, 2010
    is it a brand new washer
    President:
  • 1,314 Answers
Did you remove the shipping braces when you installed it you can find their location in your owners manuel under installation
Posted on Mar 28, 2008
    Scholar:
  • 106 Answers
I also suggest trying to use shelf-liner, the rubber padding, people stick in their silverware drawers. It works, and its very cheap. This will help reduce some of the vibration, people are getting. I recommend this, to all my customers.
Another problem, are the pedestal. These will cause the unit to shake, unless they are leveled properly. Also, with the older style, the ones with the four-metal plates that attach to the side of the pedestal, you'll get some clicking noise. I think this problem, was somewhat solved in the new style.
Posted on Mar 28, 2010
    Problem Solver:
  • 16 Answers
90% of vibrations are caused NOT by the machine, unless your getting an error message on the display. If you can spin the unit empty and its fine, you have an issue with either the floor not able to support the spin. Keep in mind, most front loaders are designed to have the weight and spin go to the feet and thus the floor. If your unit is on a second level, mobile home, or older home, you need to resupport your floor. If the unit is new.. contact LG at 800-243-0000 and have them send a tech out to check it. You also might try using a rubber type mat under the unit to absorb the vibration. Good Luck.
Posted on Dec 07, 2008
SOURCE:
My whirlpool top load washer vibrates bad and will walk across the floor during the spin cycle even with no clothes in it. I replaced all the springs, the unit is level. I don't know what else to do.
Check the giant flywheel on the back of the drum. Sometimes, the legs that make it up start to corrode and break. When they do, the drum will wobble.
Feb 08, 2017 | Whirlpool Washing Machines
Washer vibrates on spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 05, 2010 | LG WM-2277HW Front Load Washer
Washing machine vibrates bad in spin cycle
dont put full load please check it with half load or add water excess
Sep 15, 2009 | Kenmore HE2 Plus Front Load Washer
Maytag front loader MAH-3 vibrates. Level & on concrete floor.
THERE ARE SHOCK ABSORBERS IN THIS UNIT,SOUNDS LIKE ONE OF THEM IS BROKEN.HOPE THIS HELPS
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Vibration
just because the level shows it is doesn't mean it really is. check the pedestal first. make sure it is level and all legs are tight and there is no wiggle. next do the same for the machine once it is put back on the base.
Sep 18, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg Tromm wm2277hw
Try Ke shake away pads. i found them at lowes for $30. Solved my problem with a front load pedestal. Shook the pictures off the wall in the room next door. Best money I ever spent.
Jan 28, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM-2277HW Front Load Washer Logo
280 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
