Question about iLO 3200 32 in. LCD Television
I have an ilo 42inch lcd when it comes on vertical lines on the left hand side of the screen after it warms they go away. I have a degree in electronics if someone can just point me the right way
  • josh garrett May 09, 2010
    thanks for ur help
  • 10,594 Answers
This kind of symptom / problem is related with LCD Panel and two possible solutions, either T-Con board is defective or LCD Panel itself is bad. (T-Con board considered part of lcd panel)
Check T-Con board connectors that hold flexible ribbon wires coming from LCD Panel, unlock connector and reinsert flexible ribbon wires of lcd panel in T-Con board connectors just to refresh contacts. That might help to solve problem.
T-Con board would be located on top center position at rear of lcd panel and this board would be shielded.
If that does procedure does not help, replace T-Con board, if possible and last option is LCD Panel replacement but that would be costly fix.
Hope this info will help you.
Thanks.
Posted on May 09, 2010
I have a 50" Insignia plasma tv with vertical lines running top to bottom on left hand side of screen, colorful lines, it covers the menu screen and doesn't go away on different hdmi channel.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 05, 2016 | Insignia Televison & Video
I have a Sharp aquos 60" lcd that has 1 vertical blue line on the left side off screen. what part would cause that ?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 17, 2014 | Sharp Televison & Video
How to fix green vertical line on 60" vizio led smart tv
I had a similiar problem on a Sony , vertical line or lines on the left side of the screen. It was the driver board for the LCD. Good Luck
Mar 17, 2014 | Televison & Video
Picture has red vertical lines, will become
The problem is most likely the panel itself where the ribbon cables are corroded. There is however the also possibility that the tcon connectros need A clean.
May 23, 2010 | Toshiba Regza 47ZV650 47 in. LCD TV
New lcd installed in satellite l505, started out fine, as it warmed up a single vertical line appeared about 3 in from left, will occasionally disappear, but comes back in same spot after a few minutes,...
Yes, this unfortunately is the beginning of the end of the LCD screen, you see the "Driver Circuit Transistors" are starting to go faulty... this is a very common problem, occasionally, it may be the Video card, you will have to "monitor"...(pun intended), the situation. If it continues, as I expect, and lines appear down across, the screen that never go away, and are RED or BLUE or GREEN, then it is most definitely the LCD itself, if however they go away come back in differing places, then it is more likely the Video card. replacement is the only fix sorry. I would wait until it is unbearable before you do anything.
Feb 23, 2010 | Computers & Internet
Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Nov 28, 2009 | Sony BRAVIA KDL-46V3000 Television
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Vertical colored lines on left half of screen.
I had a similar issue. Took it in and apparently i had 4 bad capacitors and after replacing those, my tv was perfect. But I think I lucked out on this one. :) try it.
Nov 02, 2008 | Televison & Video
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Dell ultrasharp 1704fpt vertical line
i have tried to fix these problem before but no good i did find a web site that will also stat that this can not be fixed but rather they will replace the lcd film at a not so bad price
Nov 04, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
iLO 3200 32 in. LCD Television Logo
128 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
