Question about GE Refrigerators
GE Refrigerator Model gss25sgrbss water line problem
Hi-
I have a six year old GE refrigerator (model gss25sgrbss) that has a water line problem. The water to the ice and water dispenser stopped flowing. I've tried the following:
--Check water feed to the fridge...flow is good.
--Remove filter (hoping to bypass the filter) and try water/ice: no water
--Replace filter and try: no water flows into the filter, but the filter does pressurize. The solenoid sounds like it usually does and will pressurize the line with the filter attached...just no water getting in/out the filter.
When I remove/replace the filter, the backpressure will push a small amount of water out of the intake line into a bucket (when I disconnected it for testing). This tells me the intake line is not blocked...but no water gets to the filter.
Could this be due to a frozen line? I don't understand how water can't get into the filter, but it does pressurize. ???
Thank you for any help!
  • 3 more comments
  • brian May 09, 2010
    Thank you for such a fast reply! Water does not reach any part of the fridge that I can tell. I did not put the filter bypass cap on for the last test (which is a dumb mistake on my part), so I will try that right now.
    No water reaches the ice dispenser (no ice) or the water dispenser. When activating the water dispenser, I just hear the solenoid doing its thing, and the filter will pressurize.
    I'll go try the bypass one more time.
    Thank you-
    I just tried with the bypass cap in place of the filter and the same result...the line pressurizes, but no water reaches the ice/water dispensers.
    Is there a common location that I could try to defrost with a hair dryer or something?
    I disconnected the line going to the solenoid, activated the water line, and water did flow from the solenoid area. The freezer line appears to be a separate feed from the solenoid (black color). When I turn on the ice dispenser, I do not see water flow into the cube trays (even though the lines seem to be separate for water/ice), which is a bit confusing. I can try defrosting everything once I figure out what to do with all the items in the freezer.
    Thanks again-
    Resolved!!! :)
    Thank you for your help with this...MUCH appreciated. After using your tips and determining that the line must be frozen in the door, I found another post saying to try leaving the dispenser light on for a while to warm up the area. I did that for only 30 min and the water dispenser pushed out some ice chunks and works perfectly now.
  • Mike Smith
    Mike Smith May 11, 2010
    Do you have the filter bypass part that came with the refrig ? It sounds like water IS getting to the filter . What is not working , the water dispensor , ice maker ( no ice ) ?
  • GE Master
  • 1,606 Answers
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Posted on May 09, 2010
Testimonial: "Extremely helpful, accurate, and fast! Thank you!"
  • 2 more comments
  • Mike Smith
    Mike Smith May 09, 2010
    On some models of GE , the ice maker does not go thru the filter unless the wall line connects directly to the grey filter line . Try this test .
  • Mike Smith
    If you switch the wiring from 1 solenoid to the other , press for water , you should see water go into the ice maker ( this is a test only ) It sounds like the water line in the door for water dispensing is frozen up . Try the test for disconnecting the door water line at the bottom of the freezer door to see what happens .
  • jbconsumer Dec 31, 2010
    Is it possible that the water from the water dispenser and ice maker quit working at the same time? I get water from the input side of the coupling that connects the hose before it feeds up through the freezer door. With this being said, it seems that the water line in the door is frozen. I can't see why that would affect the ice despencer since the water that feeds it is from a seperate line (black) in the back of the freezer section. The green light blinks. When I turn it off, then back on, a little bit of water is dispersed into the tray, but not enough to make any ice.
  • Arthur Breaux
    Arthur Breaux Jan 01, 2013
    I opened my freezer door, taped a contractor garbage bag over the freezer seciton and placed a blanket over that, then the line thawed in about 30 minutes. I also found that my water plant was low on salt, so, I refreshed that. The salt in the water changes the freezing point of the water in the line a little so that should fix the problem along with warming the freezer a couple of notches too!
I don\'t empty the freezer. I tape a contractor bag and a beach towel over the open face of the freezer, and I tape the light switch in the off position. Now the door can be left open for about 30 minutes while it thaws. I leave the line disconnected down at the lower grill area (grill removed) and when water comes out, I know I have thaw. I suck the tube to get the icy water out, then restore everything. Yes, I still clean out the door section. I also realized that my water softener plant was low on salt, so, I topped that off with 180 pounds of salt, and warmed the freezer setting a couple of notches. That will prevent it from freezing up in the future. Plus, I will draw water more frequently from the dispenser rather than the kitchen faucet.... that will increase flow in the line to reduce probability of ice setting in....
Posted on Jan 01, 2013
  • Arthur Breaux
    Don't know why the word I used to describe "provide a vacuum on the supply tube orally" was censored... but... sorry... oh well... I had no idea.
I have this same model fridge and periodically experience this problem. A technician who was here servicing another GE appliance told me that the water line freezes up occasionally. There is a fix for it (they put a heater near the freeze point) but like you, my warranty has expired and I refuse to pay for the fix. To remedy, we empty the contents of both the fridge and freezer (fortunately we have a second freezer/fridge in the garage) and unplug for 24 hours. This always works and although it is a pain to do, i forces me to do a cleaning every 4-6 months.
Posted on Feb 18, 2011
Water will not dispence in ge refrigerator model number gsl25jfpa bs
Your line is frozen. Frozen water dispenser line is a problem with this model. There are number of solutions.
1. Contact GE 800 386-1215, option 5 and ask for WR49X10173 heater kit. There is a video http://www.youtube.com/watch?v=BdNX3LteJTw to help you install it. Try to get GE to send you the fix free.
2. Get a hair dryer and heat the dispensing box until the water dispenser works. This is not a permanent solution, though, and it takes 15 to 30 minutes. Hang a long beach towel or blanket over the open freezer to save the cold air.
3. Place a long, clean fishing line or weed wacker line up the water dispenser line. When it freezes, pull carefully to dislodge the frozen water.
4. Buy another brand of refrigerator and let GE know they make inferior products.
Jan 10, 2013 | GE GSL25JFPBS Side by Side Refrigerator
Can you tell where the water filter is located in my GE gss25sgrbss fridge?
in the upper right hand corner of the refrigerator compartment behind the plastic 1/2 round cover,it unsnaps and there will be the filter turn it 1/4 turn c.c.w. to remove
Jan 09, 2011 | GE GSS25SGRSS Side by Side Refrigerator
Water line leaks where line enters refrigerator
My 5 year old GE GSL25 refrigerator is leaking as well when using the water dispenser in the door. Removed kick panel to see better. The plastic water line on the door side of the union was improperly installed in a metal clip such that it was being crimped. This unintended pressure caused the water line to eventually fatigue and split. The door side of the water line needs to be replaced.
Oct 16, 2010 | GE GSL25JFPBS Side by Side Refrigerator
As of six months ago, my GE fridge starting leaking from where the air blows into the refrigerator part of the machine. I was getting a 16 oz cup of water out of it every 36 hours or so. Now the freezer...
If this is a top freezer model,remove the bottom and back freezer panels. You will find the defrost drain line frozen over.
It must be defrosted manually. A hair dryer will help melt the ice.
May 25, 2010 | GE Refrigerators
I am looking for the water filter placement location for a GE profile refrigerator that is about 10 years old. Model # is TPX24BRBB, serial # DV271857. I'm not even sure there is a filter???????
That was strange, I first checked at GE and the model did not exist. I went to our vendor and they had the drawings. There is not a filter in your unit. I would suggest an inline water filter such as the one at the site below. Thanks for asking.
Filter link
May 22, 2010 | GE Profile PSS26NGS Side by Side...
My refrigerator is six years old and for the past two months is making a loud buzzing noise. The frequency has increased over time. What could it be? It's an Amana side by side model ASD2626HE. Sounds like...
Saw your post a week late but the sound could be the start relay on compressor is weaking or if the water is turned off to ice maker the water control valve will try to fill ice maker if the ice make switch is left on and has no water. I will send a manual shortly, Sea Breeze
Apr 12, 2010 | Amana ASD2626HE Side by Side Refrigerator
Refrigerator not cooling, freezer is working.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fdite
Oct 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water periodically leaking from under refrigerator
we had this problem. Repair guy took all contents from freezer, defrosted it. There is a hole near the bottom in the back. It is for overflow. It was clogged or too full. Make sure the hole is cleaned out. Works fine now.
May 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Profile side by side refrigerator,model #GSC23LSRC SS
Have you tried a new GE filter? Use only GE brand. You can purchase a bypass plug from GE parts 800-626-2002
Jun 23, 2008 | GE DBSR453EBWW Electric Dryer
Refrigerators Logo
681 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
