Question about Motorola Mobility SLVR L7 Cellular Phone
Upper right button Button has no response.
My upper right button, which is the select/ok button doesn't respond when i press it, that means i only have the half of the functionalities that motorola l7 has, can someone help me?
    Guru:
  • 274 Answers
This is the main problem of motorola  phone
U need to change the case of ur phone
it will get frm market........
Posted on May 09, 2010
Cannon mf 8350 Cdn confirmation of fax report
On the printers panel:
Press the "FAX" (actual button, upper middle)
Press the "Report" (actual button, upper right)
"Report Settings" (Press OK)
"Send Results" (Press OK)
"On" (Press OK)
Jan 17, 2012 | Canon MF8350Cdn AllInOne Laser Printer
Tip
How to delete multiple text messages on a Samsung Intensity
On many mobile phones, you only have two options for deleting text messages: deleting one message at a time, or deleting a whole folder at a time. However, the Samsung Intensity (among other phones) gives you the option to delete multiple text messages at once without deleting an entire folder. You just have to know how to do it.
Go into the Messaging menu, either by pressing the upper left option button or by going into the main menu and selecting Messaging (option #2). Select your inbox, then press the upper right option button (Options). Select #9, Msgs View by Contact. The text messages in your inbox are now grouped according to who sent them.
From this view, you can delete multiple text messages at once. Press the upper right option button again and select choice #2, Erase Multiple. Now as your messages are displayed, there is an empty box next to each one. Scroll down through the list and select the messages you want to delete by pressing the center of the directional pad. A check will appear next to that message. To uncheck a message, repeat the same process.
The only messages you won't be able to delete are messages that you've previously marked as locked. If you want to delete a locked message, you'll have to unlock it first, then delete it.
Once you've put a check next to all of the messages that you want to delete, click the upper left option button (Done) and you'll see a confirmation message. Choose whether you want to delete all of the checked messages or only the unread ones, and then click the directional button (OK). The messages you selected will be deleted.
To resume having your messages displayed in chronological order, click the upper right option button and choose option #4, Msgs View by Time.
on Jan 12, 2011 | Samsung SCH-U450 Cell Phone
Need instructions for my sr927w accurist watch
QUICKSTART - SET THE TIME
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three
seconds. The hour and minute hand will retract to the 12
O’clock position.
3. Select the time zone on the digital display by pressing the
upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of
the digital display will start flashing. Press the
bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds
flashing on the lower half of the digital display. Press the lower
left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes
flashing. Press the lower left button to set the minutes to your
current time.
7. Press the upper right button. You will see the hours flashing.
Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H
flashing. Press the lower left button to switch between 12 hour
and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR
indicator points to CAL.
2. Press and hold the upper left button for three seconds. The
hour and minute hand will retract to the 12 O’clock position.
4. Pull the bottom right button out one click. You will see the
month flashing on the digital display. Press the lower left button
to change the month.
5. Press the upper right button and the date will begin flashing.
Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing.
Press the lower left button to change the year.
7. Push the lower right button back in.
SET THE ALARMS
indicator points to AL1, AL2 or AL3.
4. Pull the lower right button out one click. You will see ON or
OF flashing on the digital display. Press the lower left button to
turn the alarm on or off.
5. Press the upper right button. You will see the hours flashing.
Press the lower left button to change the hour.
flashing. Press the lower left button to change the minutes.
SET THE TIMEZONE
1. Setting the time zones allows you to add or remove cities on
the digital display or switch between daylight saving and
standard time. Begin by pressing the lower right button to move
the mode hand indicator to SET mode on the bottom dial.
2. If the hour or minute hands are obscuring the digital display,
press and hold the upper left button for three seconds. This will
cause the hour and minute hand to retract to the 12 O’clock
position.
3. Now pull the lower right button out one click. You will see the
digital display flashing. Press the upper left button to select
SET to display the city or OFF to not display the city. Press the
lower left button to turn summer time on or off. Summer time is
indicated on the lower part of the digital display. Daylight
savings time must be manually set for each city.
4. Pressing the upper right button will allow you to scroll
through all the cities. After setting, push the lower right button
back in.
USING THE TIMER
1. Press the lower right button to move the mode hand
indicator to TMR mode on the mode dial.
position.
3. Pull the lower right button out one click. You will see the
minutes flashing in the digital display. Change the minutes by
pressing the lower left button. Once you have set the minutes
on the timer, push the lower right button back in.
4. Pressing the upper right button starts and stops the timer.
5. Press the lower left button when the timer is stopped to reset
the timer to its initial preset time.
USING THE CHRONOGRAPH
1. To use the chronograph press the lower right button to move
the mode indicator hand to CHR mode on the mode dial.
3 .To start or stop the chronograph press the upper right
button. If you press the lower left button it will display the split
time for 10 seconds.
4. When the chronograph is stopped press the lower left button
to reset back to zero.
SET THE TIME ZONE
the mode indicator hand to SET mode on the bottom dial.
savings time must be manually set for each city..
through all the cities. After setting, Push the lower right button
back in one click.
Hope this helps. =)
Oct 10, 2009 | Bulova Watch
Reset watch
Hi
Thanks for using FixYa. You can set the time on your accurist watch by following this procedure--
TIME SETTING--
2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position.
3. Select the time zone on the digital display by pressing the upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time.
7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour.
SET THE CALENDAR--
1. Push the bottom right hand button until the mode hand indicator points to CAL.
4. Pull the bottom right button out one click. You will see the month flashing on the digital display. Press the lower left button to change the month.
5. Press the upper right button and the date will begin flashing. Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing. Press the lower left button to change the year.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 31, 2009 | Watches
Steps to forward inbox texts to email with white screen problem?
First open your phone. Press upper right (-) key to get menu. Press joystick up 1 time to get Messaging. Press joystick center select button 1 time, then down 1 time for "Inbox" (or down 3 times for email). Press center select 1 time, joystick down 1time for Inbox, center select for first message. Press upper right (-) key for "More", then joystick down 2 times to get "Forward", press center select. Press upper left (-) key to "Continue", press joystick up 1 time to get "enter email addr." Press joystick center select button, and enter the email address you want to forward the message to. After you have typed in the email address, press upper left (-) key "OK" 2 times to "Send", if you normally enter a password, type it now, press upper left (-) key for "OK" and your message will be sent. Hope this helps. -Mike
Nov 11, 2008 | Sony Ericsson Z525a Cellular Phone
Error 405
this usually happen when sending fax ,if thats the case take the following steps
1. Press the setup button (upper right corner of the fax machine)
2. Keep pressing the setup button until you get to the fourth option which says "Advanced Fax Setup"
3. Press OK to select the "Advanced Fax Setup" menu
4. Then using the left or right scroll arrows (below the OK button) scroll till you get to the sixth option which says "Fax Speed"
5. Press OK to select this menu item
6. Press the right scroll arrow till you get "slow" for the fax speed.
7. Press OK to accept this selection.
Then initiate a fax as you normally would.
hope this helps if you have further problem do let me know
Sep 23, 2008 | HP Officejet 4315 All-in-One Printer
Setting instruction for Accurist world time wrist watch
Same just happened to me, performthe following:
The analogue hands are not precisely synchronised with
the digital time?
1. Press the lower right button to move the mode indicator
hand to CHR.
2. Pull the lower right button out one click. The hour, minute
and UTC hands will retract towards the straight up 12 O’clock
position. You will see UTC on the top half of the digital display.
3. Press the upper right button to advance the hands to the
straight up 24-hour position. Use the lower left button to go in
reverse.
4. Press the upper left button. You will see HR on the top half
of the digital display. Press the upper right button to advance
the hour and 24-hour hand clockwise until they both point
straight up at the 24-hour position. Use the lower left button to
move the hand anti-clockwise.
5. Press the upper left button. You will see MIN on the top half
the minute hand clockwise or the lower left button to move
anti-clockwise until it is pointing straight up at the 12 O’clock
position.
6. Push the lower right button back in one click.
The watch malfunctions in some way and the above
procedures do not work.
1. Press the lower right button until the mode indicator hand
points to TME.
2. Pull the lower right button out one click. Press the other
three buttons down simultaneously for three seconds and
release. You will see 8’s on the digital display.
3. Press the upper left button. You will see UTC on the top half
the hands of the top dial to the straight up 24-hour position.
Use the lower left button to go in reverse.
position.
Jul 06, 2008 | Watches
HOW DO I TURN OFF PREDICTIVE TEXT
First, hit the 'Message' button in the upper-left -hand corner. Select 'New Message'. Select 'New Short Msg'. An empty screen for inserting text will now be displayed. At this point press the top middle button (the one with the line on it like this -). Now the 'Message Menu' should be displayed. Scroll down to 'Entry Setup' & select it. Press the 'Change' button in the upper-right-hand corner when 'Primary Setup' is highlighted. Scroll down to 'TAP English' and select it. Now you are done. ('I TAP English is the setting for predivtive'. 'TAP English is the setting for manual').
Apr 23, 2008 | Cell Phones
Time set
How to change the time on a Pioneer DEH 1500 car stereo:
With the radio off, select the 'clock' (upper left button) to display the time.
Press and hold the 'audio' (upper right button) until the time display blinks.
Use the 'select' buttons to select the hour or minutes and adjust time (right button selects minute digits, left button selects hour digit, up button increases the time, bottom button decreases time). Comment by dognut, posted on Dec 25, 2007 Just a further comment posted by dognut:
After setting the desired time, 'press any
Oct 25, 2007 | Pioneer DEH-1500 CD Player
How to set watch
I just set the time on mine with these instructions 1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours) then you can use the upper right hand button to navigate thru seconds, minutes and hours. Then you can change the time with the lower right hand button you can only change the time forward. I hope this helps !!!
Apr 02, 2007 | Kenneth Cole RK5034 REACTION
Motorola Mobility SLVR L7 Cellular Phone Logo
23 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
