I canot see my digital channels, the tv is stuck on 1 channel.
I canot see my digital channels, the tv is stuck on one channel (BBC3) and it wont let me change it. i have atempted to press the 'd-menu' button for the restart but that is not working either. is there a way to re-set my TV so that i can get my channes up and running again?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 86 Answers
You can try to reset it by unplugging it let it sit for a minut or two count to ten and least then plug it back in this lets the micro reset itself
Posted on May 10, 2010
My 27 inch rca truflat is stuck on channel 13 on the cable setting and 41-1 on the ant setting wont change to any other channel, can someone help me
try to preset the channels bec,it is not on the tv button memory but only on remote.go to channel settings and preset cable channels
May 23, 2016 | RCA TruFlat 27F520T 27" TV
I have a nw MAT19W127 tv and cannot receive BBC!, BBC2 and BBC3 on the freeview service (BBC4 is OK) Message shown is "No Signal". I have tried reloading the channels but still nothing. Othe...
dear,
in tv a device used called Hyperband, means
Hyperband
In the service channel network, the frequency used for distributing TV stations (300 - 470 MHz). It is the range of choice for digital transmissions according to DVB-C.
sometimes, it happens that the hyperband installed in tv doesnt catch/recieve the frequency of the channels. i think your case is like this..
you have to change it .. its not very costly..
there was a problem in my LG tv that i was not recieving the Discovery channel freq. then i had to replace this part. now i can see it..
regards,,
Aug 07, 2008 | Televison & Video
RCA LCD TV gets stuck on one channel
sounds like you have an intermittent defective main board. ebay rca model for replacement board.
Jan 11, 2015 | RCA Televison & Video
Have a new digital TV, can only record the 5 terrestial channels, how do I tune in to the other digital channels, i.e. BBC3, E4 etc.
It's not clear what you mean! So one of these answer might solve it. If you are talking VCR recording it must either have a freeview tuner or have a freeview box connected to it via a scart. Otherwise it will only record the five terrestial.
Digital TV -you must have a good aerial otherwise you will not pick up all the stations. If it has a hard disc drive the same will apply.
If the terrestial stations have any grain or the picture is not as clear as a bell on all, then your aerial will not be good enough. The type of aerial should be for freeview. See image below also you need to have CT100 cable (the stuff used for satellite) not the old brown co-axial cable (see below).
Jun 05, 2010 | Televison & Video
Unable to get BBC 1 and 2 on Digital. Both Channels are ok on Analogue but switch to Digital and programmes start at ITV( channel3) Have re tuned since last digital update but still the same. Have used the...
There is not a problem with the TV despite it's age this is can be due to your reception of the digital package for BBC. Have you checked through he full listings? sometimes the BBC channel will be at a different number setting because of the transmitter you are receiving. I assume you are using a digital box, you can enter a menu which will give you an indication of the strength & quality of the incoming signal. Do you pick up some of the other BBC channels such as BBC3 or CBBC? It's possible your aerial strength is a bit weak for the digital BBC package & you may need to have that looked at.
Oct 07, 2009 | Panasonic Televison & Video
After retuning digital tv my TX-28DTX1 BBC1 BBC2 BBC3 are missing. I have tried several times. Another tv in the house using the same aerial has found those channells.
It is a software problem with the television. I found the answer on the internet. I have contacted Panasonic for an upgrade of the software.
Oct 02, 2009 | Panasonic Televison & Video
I have a phillips plasma tv. model 42pfp5532d/05. i canot tune in the digital channels. what do i need to do ?
to get digital, you need to do the autoprogram or channel scan.. then it will find them and add them to your channel. point your antenna toward your towers and re-scan the channels. if you want digital cable, you need a cablecard (where applicable) or cablebox to decode..
Feb 18, 2009 | Zenith P42W46X 42 in. Plasma EDTV
TV is stuck on video 1?
You probably have a replacement remote. It will need to be reprogramed to your tv. You should have instructions that you got with the remot. Otherwise call your TV repair man and he can probably "walk" you through it over the phone.
Jan 12, 2009 | Sanyo DS32224 TV
TV gets stuck on channel, won't advance past channel 7.1
Try doing the Channel Search again. See if that helps.
If not, sounds like the Digital Board could be defective. Since this TV is brand new suggest calling your local sharp authorized service center to replace that board under warranty.
Mar 16, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
AUTO PROGRAMMING T.V.
Your TV is in Showroom Mode - to change:
Menu>Picture>Mode>Power up>Home
Then go back and autosearch channels.
Jan 10, 2008 | Olevia LT42HVi 42 in. LCD Television
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
Electro Med Services...
