Question about Syntax LT30HV 30 in. HD-Ready LCD Television
Video gos black after about an hour or hour and a half. Audio remains on. If turned off and the right back on the video will work for a few seconds before going off again. If left for several hours it will run for about an hour or so before going black again. Audio still remains on. Is this a power supply over heat problem? The model number on this device is Syntax LT27 HV but your system only give me the choice of LT32 HV or LT20 HV
  • richardb617 May 09, 2010
    I haven't begun to try but the solution seem to fit with my thinking. Thanks
  • Syntax Master
  • 19,396 Answers
Hi.
The most common cause for the problem is a faulty inverter. In some case a faulty power supply or a defective main board can cause the same problem.
I explained how to test inverter, PSU and main board control line in this article:How to test an LCD TV or monitor PSU, main controller board, and Inverter.
As explained inverter is the most common fault causing this problem, but PSU and main board must also be tested(see also My LCD TV has sound but no picture.).
Here replacement parts for your set:
V0.88070.101 BACK LIGHT INVERTER DPS-162CP Power Supply Syntax SC0-P315000-002 Main Unit
Regards.
Posted on May 09, 2010
  • Ginko
    Ginko May 09, 2010
    Hi.
    You are welcome.
    Thanks for your feedback.
    Ginko.
Why does my receiver start stop producing audio output half an hour after turning it on?
Most likely is an intermittent solder connection opening up as set warms up.
May 09, 2012 | B&K CT600
Samsung HLR5067W: Screen goes black - Audio Remains. Several months back my 5 years old HLR5067W started displaying the following behavior: - Launches OK - After running for a while (anywhere between...
When was last time you replaced Lamp? Ballast Board is what powers the lamp on.
Lamp Fan, if it is defective it will shut lamp off to protect it, if it is Not cooling the Lamp.
Mats has Lamps for $99.00 1-800-628-1118
Encompass Parts Distribution has 10 Ballast Boards in Stock for $68.96 they also list Service Manual Free for this Model# 1-800-638-3328
Nov 03, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
I dont know what gos to what
Radio 12V- white/yellow
Radio Ground black
Radio Ignition yellow/red
Left Front Speaker (+/-) blue/green - gray/black
Right Front Speaker (+/-) red/green - brown/black
Left Rear Speaker (+/-) blue/yellow - gray/white
Right Rear Speaker (+/-) red/yellow - brown/white
Jun 08, 2010 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
My LN-S4095D (3 years old), only works for about 30 to 60 min, and then the picture disappears and the sound stays. If I turn it off for several hours or till the next day, it turns on back with picture,...
Hello Dsidneysis,
It appears that this failure could be in the power supply due to swelling/ bulging capacitors in the power supply.
Check the link below to find parts to fix your TV.
May 25, 2017 | Samsung LN-S4095D 40 in. LCD HDTV
No video problem
Wha is the chassis number for your set? It should be located on the rear of your setnext to the model number it will be an ATC number.
Feb 23, 2008 | RCA HD50LPW164 50" Rear Projection HDTV
Mitsubishi VS-60111 video blink
I would check for Bad solder joints around the flyback, and the verticle and horizontal yoke plugs for starters. Lower your volume and listen if you hear the high voltage come back up when your video comes back up. Let me know what you discover when you check the solder joints.
Jan 05, 2008 | Mitsubishi VS-60111 60" Rear Projection...
My playstation wont play games
HI Badask7776,
Give the PS2 a good internal cleaning. If your not able to do this, get it serviced. Click on " Repair Directory" at the bottom of this screen. Find " Video game Consoles" and click on that. Pick a good Playstation Repair shop.
Nov 21, 2007 | Sony PlayStation 2 (PS2) Console
No picture on a Sony KV-32V65 TV
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the Cboard, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking.
Jan 18, 2007 | Sony KV-32V65 TV
Syntax LT30HV 30 in. HD-Ready LCD Television Logo
67 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
