Salter Bodywise 9117 Stainless Steel Analyser Scale, not weighing accurately? can they be recallibrated?
SOURCE: scale not accurate
This link allows you to trouble shoot directly with the company... I hope this helps. http://www.taylorusa.com/advantage/root/contact.html
SOURCE: Negative weight on Salter Stainless Steel Kitchen Scale
make sure the battery your getting is a good one longlastig and if that doesnt work then how nout the motor
SOURCE: I own the Salter Stainless steel electronic
yes. here is the link to the company http://salter-scales.com/ just click on the link and then enter your country. then you will see a place for parts or to contact them.
Testimonial: "Thank you! Wow, didn't expect a reply so quickly. Appreciate your help."
SOURCE: My weight is not accurate.
Very few electronic scales are accurate as they are a function of a resistance measured against a voltage. They may be accurate when you buy them, but over time the electronic components decay and read differently as the components are cheap 10% type resistors and capacitors and cannot hold their specific values over time.
If you want accuracy, you will have to get a balance type scale that can be calibrated on site.
