Question about Slant Fin KZ-12 Air Cooler Fan
KZ-12. Where can I get cleaning instructions?
Cleaning instructions for my
Where is the on/off button located on KZ-TG7321NZ
Hi, Nerissa for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Panasonic KX TG7301NZ Operating Instructions Manual
Jul 03, 2017 | Panasonic Lands Phones
Where is the number one sparkplug located on a 1100 kz
Hi, Lenard if you are sitting on the bike #1 cylinder is on the far left #2 would be next to it etc. etc. for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
KZrider Archives Firing Order Kawasaki KZ motorcycles of the 70 and 80 era
Kawasaki kz1100 kz 1100 kz
Kawasaki KZ1100 Service Manual
OEM Parts for Kawasaki
Kawasaki KZ1000R Owner Manual
Dec 17, 2016 | kawasaki Motorcycles
What are the torque specs for crankcase bolts on 1977 Kawasaki KZ 1000 B-LTD
I thin k about 7 ft lbs to 12. personally I would PIN reverse this! / them all up and do them across the cover 12 oclock 6 oc, 9 olc 3 oclk, should be ok if you just make them all tight enough PIN up and ½ turn when seated maybe 3/4 turn, apparently the word pin in reverse is profanity lol
Oct 10, 2014 | kawasaki Motorcycles
Loss of power, poor fuel economy, backfiring
I would start with a clean and synchronisation of the carbs just the smallest piece of dirt can cause this
Nov 30, 2013 | 77-80 KZ650B KZ650C KZ650F KZ650 KZ-650 KZ...
Carbon monoxide detector
There is a good chance that the detector is being set off by fumes. This could be from hairspray, cleaning solutions, air fresheners, etc... Most aerosols use propane as a propellant and this will absolutely (and should) set the alarm off.
Nov 20, 2013 | KZ 2013 Sportsmen Classic 200
I have a 1980 kz1300 that starts up but mis fires any ideas?
Basic tune up. May need the carbs cleaned, new plugs/wires, and ignition system gone over, including points cleaning/replacement (if equipped) and checking for proper operation of alternator charge coil and rectifier/regulator.
Ensure battery is properly charged.
Aug 20, 2010 | 1980 kawasaki KZ 1300 A2
KZ-32TS1e cracked speaker grill.
If you can find a junker, you could rip one out of it. Try asking local repair shops if they have any dead units that they're just going to pitch. You should also figure out the dimensions of the grill, in case you have to find an improvised one from another set.
Jun 04, 2010 | Sony WEGA KZ-32TS1 32 in. Television
Can you lower the rear ? if so is it a big job?
The best way to do this is buy some shorter shocks. If your shocks are 12 inch from eye to eye then go to 10 inch eye to eye. You cant go to low cause of the shock travel and the fender may hint the tire and that would be dangerous.
Sep 30, 2009 | 1981 kawasaki KZ 1300 A3
Need info on kz 1300 carbs
This link will give you some idea where to begin...
http://www.valkyrieriders.com/shoptalk/ShopmadeCarbSyncGauge/gauge.html
you will probably need two sets of gauges to do a six cylinder as most synch sets are fours or two's..
Mar 19, 2009 | 1980 kawasaki KZ 1300 A2
Need programing information or my cordless telephone model KZ-TG2312W.
please visit the following link for support and download free manual by clicking on download icon given in front of english instructions option.........see if its helpful...
Nov 21, 2008 | Panasonic Lands Phones
Slant Fin KZ-12 Air Cooler Fan Logo
552 people viewed this question
Top Slant Fin Dryers Experts
Are you a Slant Fin Dryer Expert? Answer questions, earn points and help others
