Question about Konica Hexar Silver 35mm Point and Shoot Camera
Lost circular ring around eye piece. Is there any hope of getting this replacement part?
Vivitar Telescope
The only solution to get the part is to contact on their Main support number-805 988-0463
Jun 23, 2008 | Vivitar (1607225) Telescope
What can we do about constant leaking at the water intake connections?
Hi, One simple thing that you can do is to check the o-ring. Most likely located on the pressure washer side of the connection inside the fitting you will find a small circular rubber piece that is what creates the seal. If this o-ring is missing torn or warn out then you will have a leaky connection. You can buy a replacement for this at your local hardware store for less than a dollar. I hope this helps solve the problem!
Aug 29, 2011 | Homelite Garden
I have a frigidaire dryer model#FEQB2152FEO. A big white plastic piece broke off around the inside front. It looks white and circular and it seems like it was maybe a seal or ring around the drum?
did you ever get a solution for your problem with your dryer? i have same frigidaire dryer model number and the plastic ring on the front inside just broke off in mine last week and im not sure what to do to fix it.
Apr 11, 2010 | Frigidaire Dryers
My xbox cd has a line around it how do i fix it
usually within the ps2 and xbox they will produce a circular ring around the disc which means the laser is going bad and will eventually need replacing.... the only way to remove the circular scratch is to have the game resurfaced but its just gonna keep doing that untill you replace the laser!
Feb 18, 2010 | Microsoft Xbox Console
Repair spring to lower guard to spring back on dewalt 18v dc390 saw
You may be able to salvage the torsion spring that is there. Sometimes the end will break off and you can bend yourself a new end and just stick it back into the retaining hole in the housing or guard. There may be damage to the guard which will not allow you to just bend the spring to make a new joint. Either way, you need to know what you are dealing with. First remove the blade if you haven't done so already. Then remove the bumper (rubber piece) that stops the guard from returning too far. Next you will need a pick or a small flat head screwdriver. Look around the hub and you will notice a retaining ring. You will have to use the pick or screwdriver to get the ring started. Look for a little tab around the perimeter of the hub. You will have to work that tab out and make sure you keep your pick or screwdriver under it. Then work it around and off the hub. Then you can remove the guard from the hub. The spring is located under the guard and is a torsion spring. Look for damage to the guard and the housing as well as the spring. If there is any question to the integrity of the guard you should replace it. The part number for the torsion spring is 612517-00 ($1.50), the retaining ring is 150383-00 ($1.50) just in case you break it, and the guard number is 611925-00 ($6). If you have any questions please post back.
Oct 28, 2009 | Dewalt DC390K 18v Cordless Circular Saw...
Eye piece on my Bushnell rifle scope is loose. What could have happened?
There should be a lock ring that you need to snug up against the eye piece. Vibration can sometimes cause this ring to come loose.
Oct 01, 2009 | Bushnell Optics
How to replace Ryobi circular saw CSB140LZ lower guard assembly
Clean the area where the guard attaches to the hub assy. It is a snap ring that is holding the guard on. You will need to either use a pick or a small flathead screw driver in order to remove it. There should be a little tab that you will be able to work out. Look around the entire perimeter of the hub to locate it. You may need some extra light to see it. Stick the pick or small flathead behind the tab from the right. Work the tab out and above the hub. Now you can work your pick or scredriver around the perimeter to remove the ring. Install it in a similar fashion but use the flathead to guide the ring back into the groove, working it around the opposite way.
Sep 28, 2009 | Ryobi Saws
Replacement parts for Tasco binoculars
You'll need to measure your eyepiece in "mm". Also determine if your eyepiece has an outer ring the eyepiece will slip over. You can find eyecups/guards on Ebay. Search under Binocular Eyecup or Binocular Eye Guard. There are also eyecups under "rubber eyecups/rubber eyeguards" but alot of these are for Microscopes and may not fit. You will need to pay close attention to the mounting type and measurements.
Sep 18, 2009 | Tasco Wide Angle and Rubber 2023 (10x50MM)...
Finding replacement rubber eye pieces for my binonculars
These are the guys you need to contact if you are in the USA; http://www.bushnell.com/general/binoculars_legacywp.cfm?section=General%20Use They make a lot of the binoculars for B+L who make the optics, including the legacy models. Hope this helps :) If not in the US please ask again
Aug 15, 2007 | Bausch and Lomb Legacy 12-1056 Binocular
Konica Hexar Silver 35mm Point and Shoot Camera Logo
60 people viewed this question
Top Konica Cameras Experts
Robert A. Watson
Robert A. Watson
Tony Parsons
Tony Parsons
Are you a Konica Camera Expert? Answer questions, earn points and help others
