Question about Maytag PYE2300AY Electric Dryer
How to re-attach one of the paddles/wings inside the dryer?
4 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: Plastic wing inside the drayer drum fell
Replace the fin if you have found that it is broken.
Posted on May 28, 2008
SOURCE: MDE7600AYW Atlantis Dryer -paddle inside dryer is coming loose
Two of the three fins had broken off in my MCD7600. to replace:
1) remove the door from the front (2 screws) and the hinges will pull straight out
2) remove the 2 white blocks/covers on the opposite side
3) the front panel will then pop out and lift up and off
4) there is a small (2") bracket that is holding the top on, remove those and the top will flip right up as it has hinges on the back for this purpose
5) now you can easily (from the bottom) find the screws and replace (from the top) the fins that have come off
good luck
Posted on Apr 24, 2009
Greg20
  • 149 Answers
SOURCE: one of the paddles inside the dryer has come loose, how can I fix this?
remove door screws and screws on opposite side. pull front forward and down. remove two brackets at top corners to raise top (unplug machine of course). screws are on outside of drum.
Posted on Jun 12, 2009
How do i secure the internal plastic stays inside the tumble dryer drum?
You must pull the dryer drum out and replace the paddles. This is a problem that is common, broken dryer paddles
Sep 23, 2016 | Dryers
How do I clean the lint from the dryer drum paddles?
They are connected to the drum which means you have to disassemble down to the drum and remove and clean. Its a major job so not sure you would want to tackle.
Jan 07, 2015 | Dryers
Coins inside Kennmor dryer drum paddles
You will need a thin putty knife. Run the drier to get it warm inside. Use the putty knife to slip under the paddles and lift them just enough to let the coins drop out when you rotate and raise the drum on that side.
Aug 23, 2011 | Kenmore Dryers
One of the paddles inside my dryer came off. The dryer is otherwise working fine. There are holes where the paddle was attached. Do I need to reinstall this paddle or can I get by with just two paddles? Is...
Yes, it may present a fire hazard. The lint will build up after time and has the possibilty of catching on fire. There are screws that help maintain the baffle to the drum.
I would say, go to Searspartsdirect.com to find the baffle you need and you will save some money I mean since your dryer is working fine.
Jan 15, 2010 | Dryers
The drum wings broke off, how do I replace them?
remove the front cover,this will then let you revove the screws for the top cover then you can access the paddles/wings
Oct 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
One of the paddles inside the dryer has come loose, how can I fix this?
Jun 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Inside paddle fell off
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top.Rotate the drum around and reach inside the drum. Re-attach that baffle.
Apr 09, 2009 | Whirlpool LER5636P Electric Dryer
May 27, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
The paddle came off inside my Neptune Dryer
The screws for the paddle can be accessed by removing the small back panel. If they are stripped out you will need a new paddle.
Jun 07, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
21 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
