Question about Panasonic RP-WF930 Consumer Headphones
Reciever light for panasonic RP-wf810h headphones wont stay on...
The light on my reciever for my panasonic RP-wf810h headphones wont stay on! What can i do to fix it?I plug it out and back in and the light stays on for a minute or so... Please help!
4 Suggested Answers
SOURCE: logitech freepulse headphones not charging?
Same Problem, Headphones will charge but they wont turn on no matter what you do. Called, got them replaced, so I thought hmmm I can figure out what went wrong with the old ones.
It is the switch itself. The connection next to the charging plug does not make contact anymore. It is a weak point and after putting excessive force on the power button it actually twists the switch enough to beak the solder joint. DO NOT LIFT THE SWITCH ITSELF! Just solder the one next to the charging plug and it will be good to go.
To take them apart is a pain. Remove foam by pulling on it. Remove tiny torrx screw (CR VT-6, bit I used), then remove (actually pry up) silver "ring" at the point where the band meets the ear piece. Finally, pry apart at the band section. I used a razor blade. It is 4 tabs on the inside and is a pain, but came apart. Then take 2 screws out to remove the band and there is the board.
Solder the switch next to the light and charge plug and it is good to go.
Hope this works,
Ryan R. Gerner
Posted on Feb 28, 2009
SOURCE: Where can I get replacement ear pads for my
Solved my problem by finally finding the Panasonic parts dept.
Posted on Aug 02, 2009
Grubhead
  • 5487 Answers
SOURCE: need new earpads for my
See my tip on dealing with dodgy cables/plugs on headphones. There's a website that sells them at the bottom of it. Just click my user name to find it.
Posted on Feb 08, 2011
Hello. I have a problem with my headphones Panasonic Rp Djs200. When i connect them to my laptop is not working. I have windows 10 and all the updates. What should i do?
Could be a hardware problem if the driver rollback/ reinstall and troubleshooting facility hasn't worked.
Presumably the headphones work on other appliances and known good speakers or headphones consistently don't work from the headphone socket?
It probably needs to visit the laptop doctor...
Jun 30, 2016 | Panasonic Rp Djs200-W - Headphones
Connect headphones to tv
It sounds like you have wireless headphones so maybe its not tv maybe more like transmitter signal between headphones and reciever so hopefully you have a way to test siganal. However the default headphone jack on TV should work fine unless turned off in audio settings in TV. Hope some of this helps you.
Apr 15, 2014 | Panasonic Audio Players & Recorders
Where can I buy a panasonic ergo fit rp-HJE120-D
http://www.amazon.com/Panasonic-RPHJE120D-In-Ear-Headphone-Orange/dp/B003ELYQGG
Apr 13, 2013 | Panasonic RP-HJE120-A In-Ear Earbud...
Hey I have lost the Ear pad to my panasonic rp-htx7 and need to know where i can replace it! It's only a clip on thing so im hoping it shouldn't be hard
See my tip on replacing dodgy cables plugs on headphones. Just click my name. Link to a site that sells them at the bottom.
Nov 23, 2010 | Panasonic RP-HTX7 Consumer Headphones
RP-WF940T instructions
Try the Panasonic website they have free user manuals to download.
Mar 06, 2010 | Panasonic RP-WF930 Consumer Headphones
Reciever wont stay powered on
I fear that there's no easy fix. Sounds like the power supply or the board which controls it is bad. If you're not an electronics repair person, it'll need to go to a repair shop.
May 02, 2009 | Audio Players & Recorders
Logitech freepulse headphones not charging?
Hope this works,
Ryan R. Gerner
Dec 17, 2008 | Logitech FreePulse Wireless Consumer...
Panasonic RP-WF930 Consumer Headphones Logo
289 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
