Question about Car Audio & Video
What outputs should be used for connecting an amp. lineout, rear-no fade, or rear
    President:
  • 676 Answers
The answer to your question is it depends. If you are connecting regular speakers to the amp then I would tell you to use rear. If you are using the amp for a subwoofer then use the rear no fade. Hope this helps.
Posted on May 09, 2010
Cant access the fade controls. Rear speakers are not operable without it.
When the rear output setting is "rear s/p:SW", you cannot adjust the front rear spreaker balance. Go to the rear speaker output from function and select "rear sp/full".
Aug 19, 2012 | Pioneer DEH-P7600MP CD Player
Im tryin to hookup aftermarket subs but the lineout converter isnt working, it sounds like alot of treble comin outt of the subwoofers. is there anyway to find a low frequency wire to tap into for the subs
instead of finding a low frequency line to attach to your LOC (line output convertor) use the built in crossover on yours subwoofer amp or an external crossover to limit the frequency range going to the subs
May 07, 2011 | Car Audio & Video
Hello i am rohit i have avh-6850 in my car i want how connect front and rear speaker and subwoofer there only two rc output one is front and other is non-fad & subwoofer tell how to connect front and...
If you only have 2 sets of pre-outs, you will either have to split the fronts into front and rear channels and use the other for a subwoofer signal, or else utilize an equalizer or other preamp that separates out a sub channel. I have an Alpine EQ that I send one stereo pair into, and it sends out front, rear, and sub outs. That allows for front/rear fade, and independent sub level adjustment.
Nov 08, 2010 | Car Audio & Video
Have stock radio # F75F-19B131-AA its in a 1998 F250 need to know how and if i can hook up one Amp for the two door speakers, and if i can hook up an additional Amp for some subs. Ofcourse if radio can do...
You will need a line level converter for starters (takes speaker level signal and converts it to line level/RCA signal) you connect this to the speaker left/right wires and it has a RCA left right on other end to connect and run to your amps, (you need this box because factory radios don't have RCA outputs on them) At that point all you have to do next is run the power/gnd/rem for your amp and then speaker wires to your front/rear speaker and then sub (if using). You can use one of these converters for your front/back speakers so you will still have use of your front/back/left/right fading options. make sure you disconnect th factory plug/harness at each speaker since the amp will be powering them and you will run speaker wires to each speaker. If you only want one converter it will be on your front channel and your sub will be power by the front. (you will fade to front for more/less sub bass unless your amp has a separate volume/bass control). If you want your sub to fade with rear speakers you will need to install another converter off of the rear speakers. Found a site with some photos that may help you with your project.
http://www.redlineforums.com/forums/howto-section/15003-how-sub-stereo-amp-install-factory.html
Aug 18, 2009 | Car Audio & Video
DEH-p5500mp will not fade F to R
Hello ryan_4run,
The "non-fading" output may be turned ON or the rear output may be set to R-SP:S/W or both.
Press AUDIO repeatedly until NOFAD:ON appears in the display. Press DOWN button to turn non-fading output OFF. Also make sure that the setting for the rear output is set to R-SP:FUL and not to R-SP:S/W.
Hope this helps.
Jun 02, 2009 | Pioneer DEH-P5500MP CD Player
Help with install on clarion vrx935vd
The green would have to be connected to the handbrake indicator switch. Additionally, Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 13, 2008 | Clarion VRX935VD Car DVD Player
Installation
If you've got a standard 4 speaker system (2 front, 2 rear), your best option is to connect both left speakers to the left channel amp output and both right speakers to the right channel amp output. The only thing you lose is the ability to fade the speakers front to back.
Mar 04, 2008 | Legacy - American II: 2 Channel 1200W...
Wiring question
Hi, If I got the specs right, your amp is a 4 channel hence the 4 RCA inputs. Probably the simplest would be to feed the 2 X RCA out of the deck to the 1 & 2 RCA in of the amp. This amp has also a line out, feed the amp's lineout back to the 3 & 4 in. This way, all four channels get same input from the deck and you will have identical power to all 4 speakers (front & rear). An afterthought is to also use the 4 outputs of the deck (since they are there anyway and it is not a good tech practice to leave outputs without load/speakers) and connect 4 mid-range or 4 smaller speakers. Hope this be of some idea/help. Post back should you need additional information. Good luck and kind regards.
Sep 02, 2007 | Performance Teknique ICBM-774 Car Audio...
Wiring Diagram for Sony car amplifier XM-554ZR
You can download the installation manual from the link below: http://www.sony.co.id/support/product/xm-554zr?site=hp_en_ID_i It has the following diagram plus other hookup info... Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 14, 2007 | Sony XM-2150GSX Car Audio Amplifier
(How To?) installing kenwood KGC 9044
You'll have to use your choice of either the front outputs or rear outputs to plug into the eq. Most equalizers I've ever seen only accept 2 channels of input, then give anything from 2 to 6 channels of output, depending on the eq.
Jul 25, 2007 | Kenwood KGC-9044 11-Band Car Equalizer
Car Audio & Video Logo
83 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
