Question about NEC LCD1712 17" Flat Panel LCD Monitor
NEC LCD1712 Problem
Hi, Looking at most images such as email, desktop, etc., the screen looks fine. But, when I open Picasa or when I view any pictures, they are showing patches of vertical green/black lines - like the background screen (when the PC isn't attached) is breaking through. I have installed the proper driver with no improvement. I have also adjusted everything there is in the menu with some changes but not much improvement. Any ideas?
  • Robofix Mar 28, 2008
    Tried two other PCs with same result.Out of warranty. Will try looking inside to see if there are internal setup devices.
  • 286 Answers
Please try your monitor on a friends computer.
This is a very odd problem so you should make sure it's being caused by the monitor.
If it is the monitor, it's a tough one. It could be a bad main board, or a bad LCD panel.
I would check your warranty status. It sounds like it may need to have the signals checked on the board to determine which of the two parts are causing the problem.
Posted on Mar 28, 2008
SOURCE:
How do I flip an image on Picasa 3
Launch the Picasa application using the desktop or Start menu shortcut icon. Use the folder structure on the left side of the window to locate the image that you want to modify, and then double-click the image to open the editing interface.
Press and hold the "Ctrl" key.
Press and hold the "Shift" key.
Press "H" to flip the image horizontally.
Click the "Back to Library" button at the top of the screen to return to the image library. Picasa remembers the changes to the image automatically.
Sep 12, 2014 | Computers & Internet
Why did my screen turn light blue lcd1712 ?
Please try to connect your computer to a different monitor. It may be that you're experiencing the notorious "blue screen of death", but you will be able to determine whether that's the case by trying another monitor. Please keep me posted. Thanks!
Aug 06, 2014 | NEC LCD1712 17" Flat Panel LCD Monitor
Why is my monitor not displaying past start-up and how can I fix it?
You say that the problem occurs when you connect your secondary monitor up either solely, or as primary, but it also occurs when you have only the primary monitor connected Therefore I think the problem is inside your computer box not the monitor or cables.
I'd try another graphics card (the specs I have say the default the graphics is 1024MB NVIDIA GeForce GT220, but then they also say Win 7 Prof - http://www.pc-site.co.uk/reviews/dell-business/dell-vostro-230-mini-tower-desktop-review), either to the built in one (if your m/b has on-board graphics facility), or a different card (which may be the same model). Have a look in the BIOS too.
14.May.214
May 14, 2014 | NEC LCD1712 17" Flat Panel LCD Monitor
How to increase brightness of my monitor i put it
Hi, you can try this; in a clear area of the Desktop screen (right)) click, once the desktop window open, click on Personalize, next click on Display Settings. You can adjust the brightness by by doing the following: On the resolution scale adjust from Low>High; you can do this until you are satisfied with the view. In the (Colors) drop box, click the down (Arrow), and choose the "Highest" color (16bits>32bits) etc. Next click to open the (Advance)) settings, click on the (List All Modes) button, once the window open choose the (Highest) settings: example (1366 by 768, True Color (32bit), 60 Hertz. Remember to click the "Apply", and "OK" buttons after each selection or change. "Hope this helps' Ya"
Jan 29, 2010 | NEC MultiSync FE700 17" CRT Monitor
LCD1712 does not come, unplugged and still nothing. Power light on front is orange not green>>any ideas
Need to open up and check to see if do have 5v and 12v in the power supply, check for bad caps also. See example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 16, 2010 | NEC LCD1712 17" Flat Panel LCD Monitor
How do I adjust the 22 in. rectangular screen to prevent images from appearing wider than normal. For example, pictures of persons make them look fat and wide.
You can use any other image viewing software such as Picasa. It will open images at 100% size but you can change the size of images
Jan 02, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
How do you upload pictures to facebook from picasa
hi friend,
I use Picasa desktop tool to keep my photos organized and upload them to Picasa Web albums, however I use Face book too pretty often and was looking for a tool to upload photos from Picasa directly to Facebook.
There are a few different ways to upload photos to Facebook one is a Facebook-from-your-desktop.html" target=_blank>Facebook photo Uploader and another is a plug in to Facebook-using-windows-live-gallery.html" target=_blank>upload images to Facebook from Windows Live Gallery, however if you are a Picasa user there is another tool called Picasa Uploader which will allow you to upload images from Picasa directly to Facebook.
To upload images from Picasa to Facebook, follow the steps given below.
Step 1: Download the Picasa Uploader application, you will be prompted to launch the Picasa application when you click on the download link.
Step 2: Add the Facebook Button to Picasa by clicking on the Add button.
Step 3: Follow the steps to authorize the application to access Facebook.
Step 4: Select the photos you want to upload to Facebook, and click on the Facebook button from the bottom of the screen.
Step 5: A new window will open up, if you have already authorized access to Facebook, you will see a screen where you can add information about the album.
When the albums are uploaded you will have to personally login to Facebook and approve the uploaded photos, if you do not want to that everytime, just click on the enabling extended access, clicking on this link will show you a screen to authorize the application to upload photos.
If you do not authorize the application to upload photos you will have to login to Facebook and go to your photos and then approve the images.
On the other hand if you allowed the application to upload photos to Facebook, it will show up in your albums.
Pretty easy right, this is definitely a great tool for Picasa users who also use Facebook and will definitely save them a lot of time.
hope this helps u
please rate me................
thank u for using fixya
regards
sivaranjini
Nov 24, 2009 | Facebook Computers & Internet
NEC Desktop POWERMATE ML6 ML7 R series PCI
What is the actual device? Nic, Audio Video etc?
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 04, 2009 | NEC PowerMate ML4 PC Desktop
Distorted shrunken picture
hi
reduce the resolution to a bit lower and the refresh rate to a nominal 60hz and things should get back to normal
my hunch is u r using a slightly high resolution and refresh rates
but before that try the buttons on the monitor to see if expanding the image sideways or top and bottom would help initially
cheers
pls rate if this was any help
Mar 31, 2009 | NEC MultiSync FE700 17" CRT Monitor
White out
Take the monitor back where you bought it from.
Sounds like the main board or the LCD panel have gone bad.
Dec 25, 2007 | NEC LCD1712 17" Flat Panel LCD Monitor
Open Questions:
See all NEC LCD1712 17" Flat Panel LCD Monitor Questions
NEC LCD1712 17" Flat Panel LCD Monitor Logo
292 people viewed this question
Top NEC Computers & Internet Experts
Ekse
Steven Wander
Steven Wander
Thomas F. Schneider
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
