Question about Husqvarna Garden
22 horse kawasaki riding lawn mower will not run at full throttle unless the choke is engaged
    Scholar:
  • 47 Answers
That is not a good situation. Too rich of a fuel adjustment can wash the bores out on that engine and prematurely wear it out! You will likely need to have the carburetor linkage and plate adjusted so that full throttle operates without engaging the choke. (If this is a single lever that you slide from slow, idle speed to fast, then on to choke)
Posted on May 09, 2010
Have 22 HP briggs engine on a snapper zero turn mower. it will only run with the choke pulled out.
Check the throttle cable to make sure you our getting full throttle if not adjust it check your fuel filter it will also cause you to starve the engine if its plug.
Oct 07, 2013 | Garden
I have a 21 HP Kawasaki on a 2007 Toro zero turn.Lately when I push the throttle forward the engine backfires and it will also backfire when I engage the blades it also backfires a lot louder when I shut...
the best thing to do is to clean or replace carb filter.. check spark plug for fouling clean or replace also if gas has been sitting in unit and stored outside I would drain gas because of water contamination..
May 26, 2012 | kawasaki Fh641v 21hp 21 Hp Riding Lawn...
How do you start it?
what kind of mower is it?
For any mower you need to check that you have proper oil level, and that there is gas in the tank. If it is a riding mower there are a few things to know before you start. There are safety interlocks that have to be complied with before a start is permitted. The blades must not be engaged. Someone must be in the seat, and the brake must be fully engaged. Move the throttle to choke for starting (or pull the cable out if that be the case), start mower. Return choke to normal operating position.
For a push mower check your oil and fuel. Prime the carb. if necessary, push the button by the carb. until you are pushing fuel and then a couple more times. If it has a throttle cable put in choke position. Pull back on the safety bar. Pull cord to start. Throttle cable to normal running position, generally full throttle right before you start to engage the choke.
I hope this helps, if any questions just reply. Be sure you let me know what you did and what kind of machine it is.
If this is really helpful, please rate.
Jul 13, 2011 | Garden
I have a cub cadet rzt 50 with a kawasaki 22hp engine it cranks and runs fine for a while and then sounds like its running out of gas, I shut the pto off and it eventually quits running, I pull the choke...
PDF]OPERATORLS MANUAL - Cub Cadet
https://www.cubcadet.com/.../CubCadetCatalogAssetStore/.../own...Cub CadetRZT Series Tractor - Model RZT50VT. Form No. 769-04647 ... Please read this entiremanual prior to operating the equipment. It instructs you how to safely and ...
Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline ...
cubcadet.custhelp.com/.../basic-troubleshooting---zero-turn-riding-mowe...
Scripting must be enabled to use this site. Support Center. Cub Cadet Website ... Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline Powered). Answer ID 10646 ' Published 01/22/2014 11:27 AM ' Updated 01/22/2015 02:50 AM
May 23, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Will only run if you hold the choke half way
It is starving for fuel. Can be partially clogged fuel filter or the carburetor needs cleaning.
May 23, 2010 | Garden
I have a briggs and stratton 14 hp ohv engine on my murray lawn mower it starts and runs good until i go to full throttle or engage the blades then it seems to flood out and start backfiring i can lower...
It sounds like you are putting it into choke mode. The choke is usually all the way up on tractors. And it will make it backfire and flood out. Just rev it high enough to work and don't go into the choke mode. hope this helps.
Apr 21, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Troy built lawn mower (riding) won't go full
I did not know riding mower had a gas pedal. I know if you leave the throttle control up all the way the engine will choke out. The pedal you are pushing, I think, is the forward/reverse hydrostatic transmission. You may need a new drive belt. The one you have now may be stretched out.
Good Day.
Oct 07, 2009 | Troy Garden
Garden Logo
235 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
