Question about Thermador RDDS30 Dual Fuel (Electric and Gas) Kitchen Range
After cleaning, the lock won't disengage. How do I get it open?
  • 187 Answers
This is a very common issue with self cleaning ovens. Make sure that the oven is cooled down and there are no errors on the screen. Clear everything by either unplugging or turning off the power at the circuit breaker.
Wait a few minutes and the problem usually clears when it is powered on again. If it does not, it is almost always a stuck lock or an electronic issue that was caused by the super high heat. Use the cleaning cycle sparingly and never before a special dinner. If the oven doesn't unlock or does not work properly, please take note of the error that is shown on the panel. Please leave error info when you leave comments. Thanks for visiting fixya.
Posted on May 09, 2010
I am trying to play a record on my Aiwa LX-120 turntable but after scanning the record the arm won`t go down.
I'm not certain that you are meant to disengage the FG lock since this means that the turntable has achieved the correct speed. The problem you have is that the arm won't go down.
I don't know to much about the workings of this direct drive turntable. But I can say you can get the service manual free on-line if that helps.
May 01, 2015 | Aiwa Audio Players & Recorders
Self cleaning
Set back on self clean, then after about a minute, switch off. The lock should disengage.
Apr 25, 2013 | Bosch HBN 442 / HBN446 Electric Single...
Trunk won't open
Lower the back seat and crawl into the trunk and see what the latch is doing when you activate the key fob. the trunk lid will have to be open to enable any repairs. Also an emergency release cable is probably visible (yellow handle) inside the trunk and will Open the trunk lid.
Mar 10, 2017 | 2007 Toyota Camry
Trunk won't open
The actuator may sound as though it is working but the latch could be damaged or misaligned. Also, the actuator could be too weak to operate the latch. If it is necessary to replace the actuator, your Camry is old enough to make a junkyard a likely source.
Disengaging shift lock
If you mean the gear shirt is stuck and you want to use the shift lock, then beside your gear shift there will be a spot that says disengage shift lock, pry open the cover and usually you can disengage it with a screwdriver sometimes when you pop the cover there is a switch that you can push to disengage shift lock hope this helps you
Jan 05, 2011 | 2002 Hyundai Accent
Can't disengage oven door lock
Lock disengaged on its own after a day. Oven is now clean, everything working properly.
Jul 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
DOOR LOCK WONT OPEN
do both of you have a digital display? if so are you getting any codes that f- with a number?
Nov 20, 2007 | GE JGRP17 Gas Single Oven
Oven door locked
you would have to remove oven.remove top panel and disengage latch assembly if you are a tech.
Jun 23, 2007 | Kenmore 30169 Electric Single Oven
Open Questions:
See all Thermador RDDS30 Dual Fuel (Electric and Gas) Questions
Thermador RDDS30 Dual Fuel (Electric and Gas) Kitchen Range Logo
141 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
