Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
My refrigerator is running but it it not getting very cold
I have cleaned the condenser coils on the bottom of the unit but the freezer section, while cold, does not seem to be freezing
  • rtubac May 16, 2010
    the fans are working the defrost system is working the compressor is getting the temperature in the freezer to about 20 degrees. After awhile the temperature seems to go up a bit to close to 30 degrees.
  • rtubac May 17, 2010
    thanks for your help. The cost of getting a repair service out to our remote home is prohibitive. We will probably have to buy a new refrigerator.
  • 1,284 Answers
Hi, first check the dial inside the freezer and make sure you have it set for a cold temperature, check the back wall or floor of the freezer section for frost, check the freezer (evaporator) fan to see if it is running, check the condenser coil (under the unit) for blockage from dust, check the condenser fan (under the unit) to see if it is running.
If you have frost in the freezer, there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem, you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control if used on the unit, or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked.
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with DOORS WIDE OPEN to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Take care
Posted on May 16, 2010
    There is no frost build up. the defrost timer comes on about once every 24 hours but there is never much frost in the freezer section. When I start to run the refrigerator after having it turned off for a couple of hours, the fans and the compressor seem to be working, but the freezer section never gets really cold. only to about 20 degrees. I have read that this might mean the refrigerator is low on "freon" or whatever gas is being used. Could there be a problem with the compressor? a slow leak of gas? the refrigerator is 14 years old, is it worthwhile to call a repair service?
  • Shehu Pro
    Shehu Pro May 17, 2010
    Hi, you never told me that the regrigerator is 14 years old, then the problem should be with
    the compressor with either a slow leak of gas or the gas is totally empty. Please call in a repair service.
    Take care
    President:
  • 1,469 Answers
If a refrigerator doesn't cool at all, the problem is often with the basic electrical controls—almost never with a need for a boost of refrigerant.
Do not assume the problem is related to the compressor or the sealed, hermetic system; these types of problems happen only rarely. Your unit may have dirty condenser coils, a door that doesn't seal tightly, or a defective temperature control.
1) Check the cold control. Be sure it is set to "cold." Normally, the temperature inside the refrigerator should be about 37 degrees Fahrenheit.
2) Listen for the freezer fan inside the freezer. When the freezer fan is running, it means the defrost timer and the cold control in the refrigerator are both set to cool.
compressor is located (typically behind or beneath the refrigerator. When the freezer fan is operating, the compressor fan should also be working (most of the time).
4) If one of the fans is not working or the compressor is off, the refrigerator will offer very little cooling or none at all. Call an appliance repairperson.
Hope it helps.
Take care.
    none of the things you mention seem to help. the fans are working the evaporator coils build up a little frost, but the freezer only goes down to 20 degrees, even after 24 hours. what other things should i try to do?
The fridge top section is getting colder and freezing some items. The freezer section...the first tray apperas just alright but the bottom tray is warming and the food is thawing.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | Fisher and Paykel Active Smart® E522BR...
Both refrigerator and freezer section stopped cooling simultaneously.
heatman101
Aug 30, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
No cool air in the refrigerator section. The bottom freezer has frost but working.
heatman101
Aug 01, 2011 | Refrigerators
Zanussi frost free freezer, freezer section not freezing, amber light stays on
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
May 03, 2011 | Zanussi ZEBF250W Bottom Freezer...
My bottom freezer is flashing -3 and the ice maker section will not work. Every thing in the freezer is soft.
Refrigerator
heatman101
Jan 16, 2011 | Liebherr KIKNV3056 Bottom Freezer...
Maytag side by side dripping water out of freezer section, not freezing, doesn't turn off at all
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Oct 21, 2010 | Maytag MFD2560HES Bottom Freezer French...
I have a amana bc20tw fridge with bottom freezer that is keeping cold in the freezer and cool (43 degrees) in the fridge. I checked the coils in the freezer and there is no ice or major frost. Also, the...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 15, 2010 | Amana ABB1927DE Bottom Freezer...
Top section fridge warm frost in freezer section compreesor loud
heatman101
Oct 12, 2010 | Amana ABB1927DE Bottom Freezer...
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
Freezer/Refigerator not cooling
heatman101
oiopi
May 09, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
111 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
