Question about Poulan Pro Gas BlowerVacuum ()
Throttle assembly fell apart on Poulan BVM200 LE blower vac. Not sure if I have all parts (only 2). Would like diagram of how it should look when assembled.
  • 149 Answers
SOURCE: poulan pro bvm200 leaf blower/vac won't run on high
Is the exhaust spark arresor screen clean? a blocked exhaust will do this.
Posted on Jan 08, 2009
  • 31 Answers
SOURCE: where do I find a carburetor assembly drawing for
Does the carburetor have a name on it like walbro. if it does just search for the name. and if its a walbro carb. they are all the same from the smallest to the largest.
Posted on Sep 23, 2009
Dolfoff
  • 148 Answers
SOURCE: we have a featherlite gas blower model # F1 1500
Recoil starter pulley - Part # 530071792 (Rope & Handle NOT included)
Recoil starter spring - Part # 545008011
Hope this helps,
Dolf-
Posted on Oct 15, 2009
hunter19_46m
  • 7482 Answers
SOURCE: POULAN FEATHERLITE LEAF BLOWER WILL ONLY RUN AT 1/2 CHOKE
Sounds like you will need to clean your carburetor, or rebuild it. Could be some debris in the jets of the carburetor. If the blower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit, because the diaphragm will get hard and that will cause it to be hard to crank and not run at full speed. Hint: When you clean your carburetor and remove the jet screws, count the number of turns it takes to seat the jets from their original position. That way when you go to put the jets back in, you know how many turns they were in/out. Please rate me, Thanks Good Luck, I hope this helped
Posted on Jan 05, 2010
2strokeguy
  • 183 Answers
SOURCE: trying to get my poulan
How do you know that the coil is bad? Have you checked it with an inline spark tester? It is very rare for this model to burn up an ignition module.
Please check for spark with an inline tester. If there is no spark with that tester, then disconnect the on/off switch and retest. If there is no spark with the switch disconnected, then indeed the module is faulty.
To access the module, the engine has to be removed from the case. Start on the right side and remove the muffler cover and muffler. This is a good time to visually inspect the cylinder. Look into the exhaust port with a flashlight and look at the piston. If there are scratches/scoring on the side of the piston or cylinder walls, then the blower is probably not worth repairing.
On the left side, remove the air filter cover, then remove the filter base (carb cover). This will expose the carburetor. Remove the 2 fuel lines leading to the carb, and then the throttle linkage and remove the carb. Next, remove the carb mount.
Now, remove the 15 or 20 screws that hold the plastic case halves together. The lower hinged cover will have to be releases before the case will seperate. Once you have the case apart, the engine can be removed. The ignition module is now exposed and can easily be replaced.
To set the proper gap of the new module to the flywheel, use a clean and dry business card. Lay the card across the magnet of the flywheel and place the module against it, then install the screws and tighten up the module. Remove the business card.
While you have the blower down this far, check to make sure the cylinder is tight against the crankcase. This model is prone to having the cylinder come loose and will effect compression.
Reassemble in reverse order. Take pictures as you go to aid in reassembly. If the blower is more than a couple of years old, I would recommend to replace the fuel lines at this time. It will save a repair down the line.
You will need allen wrenches, phillips screwdriver, T15, T20, & T20 torx, a large, clean workspace. This is not a repair for the beginning mechanic, but with patience, it is not too difficult.
Good Luck !
Posted on Nov 18, 2010
Where where do I get a exploded diagram of my Poulan Pro blower model ppb 430 vs. also assembly. in diagram that would show me how to put it back together
Here is a source for the exploded views. Enter your model number as "PPB430VS" and chose your type number. This type number is the last of the serial number after the dash.
Poulan Parts Lookup by Model
Apr 07, 2015 | Poulan Garden
How do I remove/replace the assy-impeller assembly
dis-assemble the blower housing and you will see the required bolt to remove the assy
Dec 12, 2013 | Poulan Garden
Help replace Poulan Pro BVM200
Here is a diagram of the WG500 hope this can be of help.302b8173-0047-4eaa-b003-fb134eb098e4.png
Jul 01, 2013 | Garden
Manual for Poulan BMV200LE
wITH original cds have you only area code problem. You must your dvd driver this codes giving. (Instruktion you can read it) verx easy...
and unterhalten sie sich gut beim Film!
Jan 13, 2012 | Poulan Garden
Need to replace both fuel lines on My BVM200 LE leaf blower, 1 large and 1 small fuel line, can You tell what size they are??
On your blower, it looks like the small line supplies fuel to the carburator which will be connected to the fuel filter in the tank, and the large line looks like the fuel return line.
http://www.ereplacementparts.com/poulan-type-gas-blower-parts-c-16962_31724_131359.html
Jul 19, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
It is a BVM200 leaf blower but what type?
Its the BVM200VS. I just bought it 2 years ago.
Apr 17, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
Poulan BVM200 LE leal blower it about 4 years old and has no spark. It work well last fall. Must the ignition module be replaced. Thanks, Rick
hi rick
if the plug is ok and kill switch and wire have been isolated from the ignition unit
and the earth is good for the armature legs on the coil - then yes the ignition module must be replaced and the air gap set to 0.010 "
a fair bit of work involved in replacing coil in one of these units !!!
ps make sure compression and muffler are ok and have a look up the ex port and check rings / piston and bore for any damage before parting with any cash for new coil
and dont be tempted to use stale fuel mix in your blower it can cause a lubrication fault
resulting i damage to piston / rings etc
cheers pauly46
Mar 30, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
My Poulan 445 Pro's Gas tank brackets worn out (melted) I went ahead and replaced washers to hold into place! now my cable for my carb. came off and now I'm looking for a diagram to show me how to install...
There probably is'nt a diagram to show this as there is a shortage of repair info on these units in the way of manuals etc. Most people feel they either run or they don't and treat them as a disposable item. The carb cable should have a dog-legged end on it and with the carb in place you should just be able to twist it slightly enough to drop into the butterfly valve shaft's end plate where the hole is...and make sure the raw part of the cable is around the back of any guides, so it doesn't bind up or interfere with the throttle action.
Aug 20, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan pro bvm200 leaf blower/vac won't run on high
Nov 29, 2008 | Garden
Poulan PBV200 LE
Probably a low compression problem.
Oct 18, 2008 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan Pro Gas BlowerVacuum () Logo
89 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
