Question about GE (PSS26MSRSS) Side by Side Refrigerator
. I need the hinge door stop on the lower right side of refridge
The door opens to 180 degrees and slams or bumps the handle up against countertops. We need the small pot metal part with the flange that attaches to the lower hinge that stops the door at the 80 degree angle and keeps it from hitting the countertops. Can You Help?? GE Profile PSS26MSRB SS
  • GE Master
  • 1,606 Answers
The door stop part # WR02X10782 If this is for the refrig door , check the screw at the bottom of the door , to make sure it is not adjusted too high , bypassing the door stop . The same door stop is used on both doors .
Posted on May 09, 2010
Installing lower oven door on GE profile gas oven`
Removing or Reseating Oven Door To remove most oven doors:
  1. Open door to the BROIL POSITION, where you feel hinge catch slightly.
  2. Place your hands on both sides of the door near the handle.
  3. Lift the door up and away from hinges.
  4. If the door does not readily lift off, there may be 2 phillips head screws on the inside of the door down near the hinges that are holding it on.
To replace the door:
  1. Place your hands on both sides of the door near the handle.
  2. Resting door against knee, line up door with hinges and slip into place.
For instructions specific to your model, check your Owner's Manual or Installation Instructions. Download a copy of your Owner's Manual and/or Installation Instructions
Aug 11, 2016 | GE Profile 30" Self-Cleaning Freestanding...
The refrigerator right side door swings all the way around when you open it (180 degrees). Shouldn't it stop half way? How can this be corrected?
Your frig should be properly leveled left to right and front to back when it was installed. If it is done correctly, when you open the door it should stop where-ever you stop it and it should stay there until you close it. If it swings either closed or open when you let go of the handle, it's not level. The door stop is there to keep the door from opening too far.
Jan 04, 2015 | Refrigerators
Door will not close without slamming
Possible causes - door switch, or door switch assembly out of adjustment; plastic latch guides on door switches worn; door hinge worn, causing door to be out of alignment. If it's the last one, the unit needs to be checked for microwave radiation.
Dec 22, 2013 | Panasonic Inverter Countertop Microwave
Blizzard lb 1ss upright freezer change door opening
Under the bottom hinge, unbolt it, remove plastic plugs on other side of door, transfer hinges over and door handle, refit the lower one in new position, put plastic plugs in old holes
Mar 12, 2013 | Freezers
When dryer finishes it just keeps on beeping
Instructions
Open the door to the dryer and remove the screws in the hinge. Lay a towel on top of the dryer. Place the dryer door on the towel with the inside facing up.
Remove the screws from the inside of the dryer door. Disassemble the dryer door carefully, removing the cover on the right side of the innermost section of the door and the shield and hinge from the left side of the innermost section. Reattach the side cover to the left side of the innermost part of the door. Install the new shield to the right side of the door section, with the flat side against the door and the notches facing up (they will face into the dryer). Attach the hinge on the same side as the shield.
Set the top section aside. Rotate the remainder of the door 180 degrees so that the handle is on the left of the upside down door. Check that the latch aligns with the cover before screwing the door back together. Screw the hinge into the corresponding holes on the left side of the dryer door frame. Remove any stickers that might be blocking the holes.
Check the alignment of the door by opening and closing it several times. Loosen the screws on the hinge and nudge the door slightly until the fit is correct. Tighten the screws into place.
Jan 10, 2013 | Haier HDY6-1 Electric Dryer
Can't get the door back on
Instructions
Jan 09, 2013 | Dryers
Change door from right opening to let side
Hi, Dayne here
There are plugs on the new hinge side that you take out and simply trahspose the door and you may have to flip the handle 180 degrees. Then put the plugs in the old holes.
Dec 12, 2010 | Refrigerators
Sliding Door Jammed
bump the back of the door (the part furthest from the handle) bump it inwards to close it "more" while pulling at the handle, do it a few times pulling and bumping- quite randomly and see if it opens, I expect it was slammed too hard and has knocked the latch out of alignment -which you can fix with the right spanner and a bit of trial and error.
Jan 15, 2010 | 1992 Dodge Caravan
Counter depth refrigerator
Do you have room to pull the fridge out from the wall, maybe just a couple inches? Pulling it out from the wall should give you more door swing without hitting the counter.
Let me know if this works for you.
Thanks,
Bill
May 16, 2008 | Refrigerators
Maytag Fridge French Door hinge discrepancy - hard swing
Vhotho, Maytag put out a service bullitin regarding this problem. This of course is for the model that is posted. The fix is to install a new right side center hinge and door stop limiting the opening to 135 degrees. They must of redesigned it. I can give you the part numbers. Black and stainless the hinge is 67006443 and the stop is 67006276. For white the hinge is 67006379 and the stop is 67006278. This bullitin came out in Feb of 2006. TDR-0057a-b. Catriver..post back.
Jan 04, 2007 | Maytag MFD2561HE Bottom Freezer French...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
1,209 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
