Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
Green screen for 30 seconds, then shuts down
My dad has a GE D52GW12YX2. It is about three years old. The other day it was on and jsut shut itself off. The next morning when he turned it on there was a spark in the bottom of the unit and he said he thought he saw some smoke. Now when I turn it on the screen is all green but the sound works. It then shuts off after a few minutes.
I looked inside the cabinet and saw that the green tube is the only one working.
  • bhg3212 Jun 05, 2008
    same problem any info on a recall?
  • 97 Answers
Yes you need a new picture tube, those tend to lose there power after a few years.
Posted on Jul 15, 2008
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Alienware Aurora desktop crashes on bootup
try to change the cooling fan mayhbe its the problem that your proccessor is over heated.
Dec 25, 2008 | Alienware PC Systems Alienware Aurora High...
Won't Shut Down
Is your xbox button on your control stuck down? Are you haveing trouble while playing games?
Jul 14, 2008 | Microsoft Xbox 360 Console
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Infocus x1a projector shuts down after 30 seconds - dust problem ??
There is a safety themostat inside the unit (looks like a silver button the approx size of a dime) that will shut the system down if you do not have adequate airflow. You can dis-assemble the projector by removing the screws on the bottom and rear of the housing and pressing in the plastic locking tabs inside the cover all around the perimeter but I would advise against this unless you are comfortable with delicate nature of the projector.
Dec 17, 2007 | InFocus X1 Multimedia Projector
NEC-Mitsubishi MultiSync 1735NXM
is is power related problem see the adoptor is ok or show it service center. bye
Sep 24, 2007 | NEC-Mitsubishi MultiSync 1735NXM Monitor
Shuts off
projector turns off after 30 seconds problem solution
Sep 16, 2007 | Sanyo PLC XU35 Multimedia Projector
Dehumidifier keeps shutting itself off.
For some reason it is overheating and shutting itself off. There is a law that all electronics are supposed to have a point to where it automatically shuts off if it gets too hot from a malfunction or loose connection in the circuit board. It is to protect the consumer. You either need to take it to a tech or get rid of it. Get a new one.
Sep 13, 2006 | GE AHG40LA Dehumidifier
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
