Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Hook up power from two 110 volts pumps from pool
Hook up power from two 110 volts pumps from above ground pool to meter box on house, from house topool about 90 feet, what all do I need and a diagram of how it works.
    Guru:
  • 351 Answers
I would run a feeder from the main breaker panel to a small breaker box near the pool pumps, so you have a disconnect near their location. Look at the drawing and see if you have any questions .. What is the amperage reading on the name plate label of each pump motor??
Posted on May 12, 2010
Chlorinator wont come on it appears dead.
You can check the 3 internal fuses located under the control housing..You will need to remove the 4 screws to open and check??? These fuses are not easy to replace and should be done by an electrician. Also, the on/off switch could be bad and could be checked with a volt meter. You can call intex and see if you can return under warranty???
Aug 24, 2011 | Intex Automatic Salt Water System for ...
We have a proline above ground pool pump. Model PE71 III V. Been working fine the last two weeks. We vaccumed pool and then pump just stopped working. We don't hear any noise....like there is no...
at home depot the sell a pen that beeps at the sight of voltage (sensor) 12$ good house hold tool to have.. check the cord running to pump see if the pen beeps when held against cord if its a 110 set up the pen beeps and youve the 110 V needed to run the pump if 220 V a bit different .. if left powered But not running in a few min, touch motor housing the metal part of this unit. is it hot as a grill (internal winding problem) or still cool .. Motors are a wear item like tires on ones car.. motors are inexp like 110$ for a 1 hp unit
Jun 04, 2011 | Hayward 3/4hp Super Pump Inground Pool...
A o smith b854 motor schematic diagram 115v . How do I hook up 115v to the factory set 230v?
Remove the back of the pump housing ... inside you will find the 110 volt connection place.
If your pump is on a dedicated line (as it should be) run it on 220 VAC ... To convert your line from 110 to 220 all you need is a double pole breaker of the proper amperage ... take the white wire presently on the ground bus bar and put it on the other side of the new double pole breaker. Then you will have 220 ... and you will save a few bucks on electricity.
Jul 11, 2010 | Smith Pool Pump Motor Square Flange - 1 HP
Wirng connecions for 110v pentair pool motor???
There shopuld be a diagram on the nameplate of the motor, or on the cover for the wiring compartment, or there is some stamped indication at the wiring lugs that tell you where to put your feed and what position the internal wires are to be in or the jumper .. for 110 volts or 220 volts.
May 29, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
How to connect the 3 phase power supply to a 3 phase synchronous motor with control panel
I assume you have 3 phase power where this is going? The panel has 3 legs, 2 are 110 volt and one is 208 volt, you will need a tester to find out which is which if it is not marked, the motor should have a map on it for the wires to attach to, they go the same way, two, 110 and one, 208, I hope this helps, There will be one wire for a ground or a solid wire separate from the unit.
Feb 13, 2010 | AO Smith Three Phase Swimming Pool Pump...
I am trying to connect my new pool motor. I have 3 wires coming out of the box. a black one 120v a white one 120v and a copper (ground). How do I test if it has 240v? How can I connect the motor so works....
Most probable cause is that you have the black and white on the same phase, and that's why you have 120 volts from black to ground and from white to ground, but 0 across black and white. If the motor ran on 120 volts, why are you connecting it to 240?
In any event, in order to get 240 volts, move the white to a circuit breaker that is directly above or below the breaker that feed the black wire. You are supposed to use a 2 pole breaker for 240 volts anyway
Jul 23, 2009 | Pool & Spa
My Generator is putting out voltage on both the neutral side and positive side of 110 Volt recepticles. When hooking a meter to both sides (Neutral & Positive) it is showing 184 volts! It burnt up a...
Check the voltage with a meter in all the recepticles with your meter leads in the left and right slots on the plugs. Is that 184 volts AC there? If so, your gen has big problems with the voltage regulator. Let me know what you read. You can check the right slot of each plug to the round ground hole on the plug too, should be 120 volts there.
Jul 01, 2009 | Coleman Powermate Proforce 6,000 Watt 12...
My hayward 1hp pool pump is running very hot to touch
Make sure the supply wire is the correct gauge for the current draw. The main reason to run on 240 volts is a smaller gauge wire and breaker than on 110 which draws close to 15 amps. For example a person using an above ground on a small extension will cause it to overheat. Make sure it is getting as much power as possible
Jun 30, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Changing motor hayward 1.5 HP
Super pumps are very easy. If it is a northstar it is more difficult. Super pump. You will need 1 motor, 1 pump seal, 1 diffuser gasket, 1 housing gasket. turn off breaker, disconnect wires -noting whether it is 110 or 220 volts- , unscrew four bolts on back of pump housing (shaft side of motor), pull out motor with rear housing and diffuser (sometimes diffuser sticks inside), on wire side of motor hold shaft with wrench (flathead in some cases, but it is harder), unscrew impeller counter clockwise (like normal screw - you will nee a big pair of channel locks or a strap wrench), there are two pieces of the back housing and once the impailer is off you can remove the half that is closest to the end of the shaft to reveal four more screws, unscrew those four screws. screw back part of rear housing onto new motor. Install new pump seal to front part of rear housing and impeller, slide on front part of rear housing and then screw on impeller while holding shaft on wire side with wrench (only hand tight), replace housing gasket, replace diffuser gasket, slide into front housing and screw in four bolts. If electrical was 110 you will need to move the jumper on the wire end..if it was 220 then just hook kup wires...doesnt matter which is which as long as green or bare goes to the ground screw.
Mar 14, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
271 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
