Question about Sony Cyber-shot DSC-W80 Digital Camera
My lense is stuck and it wont turn on - Sony Cyber-shot DSC-W80 Digital Camera
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 09, 2010
Samsung pl50 camera - lense wont go back in and wont turn on
The problem with mine was that the lens motor was somehow stuck. I gently pulled the lens out as I turned the camera on. It went back to normal afterward. Hope this helps
Feb 01, 2010 | Samsung PL 70 SL720 Digital Camera
Lense was stuck out did what toothy said now the lense is stuck i
Hi!
Please follow the troubleshooting given below to resolve the issue:
(a) Turn off the Camera and remove the Battery then press and hold the power button for 30 seconds.
(b) Then, reinsert the Battery and turn the Camera ON. Please make sure that the Battery is fully charged.
(c) Next, press and hold the Reset button for 30 seconds located above the DC-in jack on the Camera using a sharp pointed object.
If the Camera doesn't operate normally even after performing all the above mentioned steps then service will be required.
Aug 23, 2009 | Sony Cyber-Shot DSC-P72 Digital Camera
Kodak V1253 lense won't close
Use the vacuum cleaner to suckout the dust/sand particles stuck between the lens casing and the body.
Aug 11, 2009 | Kodak EasyShare Z1275 Digital Camera
My camera lense is stuck and my camera wont turn on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Jul 28, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Camera dropped and lens is stuck one day i tried to make a video on my camera but then it fell and now the lense is stuck and when i turn it on it wont come out and when i turn it off it wont close
this may sound drastic but, grab the lens and try manualy realigning. If you hear a grinding noise the lens assembly has to be replaced. Flat rate from sony is usually pretty reasonable. Hope this helps.
Jun 01, 2009 | Samsung S630 Digital Camera
Camera wont turn on&lens wont move
Folks,
Try to assist the machine mechanism. Turn the lenses (force is no necessary) when turning on or off. This should unlock the mechanism.
Aug 24, 2008 | Pentax Optio E40 Digital Camera
Digital camera
I had the same problem. After I "tore" the camera apart, I put rubbing alcohol all around the lense where it goes in and out. I then used a high quality synthetic oil that is for Grandfather clocks and other mechanical clocks to oil it again. I then ran the lense in and out (by turning it on and off) quite a few times to help work the oil down into the gears. My camera seems to be working fine now.
Dec 20, 2007 | Samsung Digimax D53 Digital Camera
Lense wont come out
It sounds like the drive gear(s) are broken. Kodak generally doesn't sell parts for their digital products so you are stuck taking it directly to Kodak for service.
Mar 28, 2007 | Kodak EasyShare C340 Digital Camera
Sony Cyber-shot  DSC-W80 Digital Camera Logo
499 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
