Question about Toro Lawnmower 20099 Mower Mowers Lawn
First start is excellent when cold, will not restart again warm
I have a Toro Personal Pace mower, Model 20041, with electric start, I have installed a new spark plug RJ19LM, new oil and air filter 491588S, the first start is excellent when cold, after stopping to empty the bag, the mower will not restart. What is wrong ? How can i fix it ? What should i adjust ? What should i replace ? The mover is only four years old purchased from Home Depot. Is it under warrenty for free repair or replacement ?
  • Toro Master
  • 640 Answers
It sounds as if your engine may be getting too hot. I suggest that you check under the covers and make sure that all the debris is cleaned out. These are air cooled engines and as such need to be kept relatively clear of debris, especially anywhere there are cooling fins.
Posted on Aug 12, 2010
What is spark plug gap on toro lawnmower model#20332?
Toro has your manuals here depending on year of purchase. If they don't mention the gap, I would use to the contact page to ask.
https://www.toro.com/en/homeowner/walk-behind-mowers/22-personal-pace-20332
22 56 cm Personal Pace 50 State 20332
Apr 14, 2016 | Toro Power Lawn Mower
Toro personal pace mower will not stay started?
If ir starts and runs for only a few seconds it's a dirty carb/bad gas. Drain the fuel system and use FRESH gas; change out your fuel supply monthly to avoid "phase separation" issues. If it runs for several minutes and then dies it is possibly a sticking valve. Do a compression check cold and after it stalls to confirm. Hope this helps
Mar 08, 2015 | Toro 20372 Recycler Personal Pace...
How do you change the transmission in a 20067 toro personal pace lawn mower
I followed this video and it was pretty accurate. http://www.youtube.com/watch?v=eSaNVZaUi-k This is for a newer model mower but most steps are the same.
Jul 07, 2011 | Toro Personal Pace CARB Walk Power Mower
Toro Model 20041 sputters and stalls out; If I cover the primer bulb the engine will rev up and run. Also the mower won't start unless I clean the spark plug. What do I need to do?
Most likely you'll have to remove the bowl nut, under the carb's bowl. You'll most likely find varnish in the jet, or maybe water. These are some typical jets, Tecumseh. Briggs, similar (baymee Lehigh Valley PA, 2009).
Jun 08, 2011 | Toro Personal Pace CARB Walk Power Mower
My mower starts when cold and runs for a while OK
it sounds like the ignition coil is shorting out inside once it gets hot. or it could be the spark plug as well.
May 01, 2010 | Toro Lawn Mower With Toro Power Tools
How do you replace the belt
this is not easy you have to turn the mower on its side <make sure the carb is down > take off the blade belt guide and look at it the space is really tight and you have to hold the trans with two fingers and then walk the belt on. its hard because the trans is spring loaded to twist backwards to keep the belt tight
Aug 13, 2009 | Toro Garden
Toro electric start won't start manually
If it doesnt start manually,you have another issue to deal with. Whether it has electric start or not you should be able to manually pull start it. You can also get the model and serial number off the engine and contact your nearest toro dealer to have charger and key ordered. As far as a push button,it can be done,just a matter of finding someone to install one for you.
Jun 03, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawnmower 20099 Mower Mowers Lawn Logo
864 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
