Question about Dyson DC14 Bagless Upright Cyclonic Vacuum
My dyson dc 14 is not picking up as well as it should,but, suction still very strong when using hose with attachments, have checked belt and have checked for blockages. can any one help please?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 167 Answers
Hi its Darran at Dyson.
I would check that the brush bar is turning when you have the cleaner in the vacuuming position. To check this, make sure the brush control dial (on the cleaner head) is in the centre position and when you release the head of the cleaner to vacuum, it should move forward to the "on" position. Lie the machine on its side keeping hands and loose fabrics away from the base, switch it on and see if the brush bar is turning.
If it is, you would need to check the machine through for a blockage and wash the pre filter. To so this, please refer to your user guide or check out www.dyson.com and visit the Support section which has lots of self help information to help resolve this issue.
I hope that this information is useful to you.
Kind regards
Darran
Dyson Customer Service
Posted on May 12, 2010
My dyson 07 has no suction
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum in order to clean the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
Possible Problem # 2. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
This would also explain why the vacuum works fine when using the attachments, but not on the floors. The attachment hose uses a different suction channel, and when the machine is in the upright position, no suction goes through this hose. If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. I would suspect that this may not be the problem, but if neither of the solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
Possible Problem #4. If none of the above solutions worked for you, try this last one. The Dyson DC07 models use a clutch mechanism that stops the roller brush from spinning when changed from carpet mode to bare floor mode. This clutch mechanism is a notorious problem with all Dyson models, in fact they were such a problem that Dyson had to redesign the DC07 model to a non-clutch system. Even if yours is one of the newer ones that don't use a clutch, yours still has a belt inside. You can tell if your model uses a clutch or not by the shape of the roller brush. If your brush is a perfect cylinder shape, yours does NOT have a clutch. To check and see if the clutch or the belt have gone bad, first release the handle on the vacuum as if you were vacuuming carpets. Make sure the machine is set to carpet mode. Now while the handle has been released, turn the machine upside down and see if the brushes are spinning. If the brushes are spinning then turn the vacuum right side up and put the brushes on the floor. Can you still hear the brushes spinning when they are hitting the carpet? If yes, then this is not the problem. If the brushes however are NOT spinning, this indicates either your brush roll, clutch, or belt have gone bad.
Aug 06, 2014 | Vacuums
Plenty suction from wand, but when you tilt back to vacum no suction at base but brushes are turning
There could be a few things that would cause your Dyson to have no suction. I will give you detailed step by step instructions along with pictures on how you can diagnose this.
Possible Problem #4. If none of the above solutions worked for you, try this last one. The Dyson DC07 models use a clutch mechanism that stops the roller brush from spinning when changed from carpet mode to bare floor mode. This clutch mechanism is a notorious problem with all Dyson models, in fact they were such a problem that Dyson had to redesign the DC07 model to a non-clutch system. Even if yours is one of the newer ones that don't use a clutch, yours still has a belt inside. You can tell if your model uses a clutch or not by the shape of the roller brush. If your brush is a perfect cylinder shape, yours does NOT have a clutch. To check and see if the clutch or the belt have gone bad, first release the handle on the vacuum as if you were vacuuming carpets. Make sure the machine is set to carpet mode. Now while the handle has been released, turn the machine upside down and see if the brushes are spinning. If the brushes are spinning then turn the vacuum right side up and put the brushes on the floor. Can you still hear the brushes spinning when they are hitting the carpet? If yes, then this is not the problem. If the brushes however are NOT spinning, this indicates either your brush roll, clutch, or belt have gone bad. ....
Dec 30, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction near brush
Mar 03, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
My vac cleaner doesn't pick up.
Jan 13, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson 14 suction low when using footplate
If these solutions still didn't fix your problem, I'd be happy to try and help you further. Just use the Clarification Request, or comment section here on the Fixya repair page.
If this repair was helpful to you, please be sure to rate this repair as helpful by clicking the thumbs up icons in the top right hand corner of the repair. Thanks so much!
Jan 04, 2013 | Dyson DC14 Animal Bagless Upright Cyclonic...
No suction when vaccuming floor
Dec 02, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson vacuum cleaner doesn't seem to have the same suction power it used to. I have cleaned out the canister and have taken apart the vacuum head (for cleaning carpets) and it doesn't seem to be...
Hello, this is Ava with Think Crucial.
Most of the time the reason why the vacuum is not picking up is due to loss of suction. You may need to check for blockages of your wand and hose. Remove the wand and hose from your cleaner when checking for blockages and any damages. Make sure to turn off and unplug your vacuum from the power before doing this.
You can purchase a wide variety of high-quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Mar 08, 2011 | Vacuums
Suction bad when using as an upright
There are several things that this could be. Probably the most common problem that we see when customers come in with this problem is actually a fairly simple problem to fix. Here are just a few things that this could be.
The fist possible problem sounds like the most probable to me, just because of the fact that you said you had just replaced the clutch, and therefore you had to remove the bottom sole plate. This is a VERY common problem actually.
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum2_bing.gif in order to clean the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Possible Problem # 2. Turn the vacuum cleaner2_bing.gif upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
If you are getting suction power from the hose, but the vacuum still doesn't pick up on the floors, I think that these solutions should fix your problem. If you just replaced the clutch mechanism, the roller brush should be fine, but turn the vacuum over on it's side and make sure that the roller brush is actually spinning while it's on carpet mode. If none of these problems fixed your Dyson, please use the Clarification Request, or leave another comment here on the Fixya repair page, and I'll be happy to further diagnosis the vacuum cleaner with you.
I hope this was helpful to you. If so, please be sure to rate the repair as helpful by clicking the thumbs up icon in the top of the repair page. This is what keeps Fixya repair professionals like myself continue posting these detailed repair solutions for free. We really do appreciate when someone recognizes the work you've done. Thank you very much,
Chris J.
GoVacuum.com
Apr 13, 2010 | Dyson DC14 Low Reach Bagless Upright...
Dyson dc07 animal\ no suction
Chris J.
GoVacuum
Apr 01, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I just bought a used Dyson DC07. Works good but
From your description of the problem, it sounds as though the wand/hose is blocked. To test this, please remove the wand from the machine and switch on, testing the suction from the top of the wand handle. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its strong from the hose itself, the wand is blocked and you will need to clear this.
If there is poor suction from the hose, you can remove this by unclipping it from the base of the machine and can then remove any blockages. It is also worth checking the hose for any splits or holes.
If you need any further help or advice, please visit our website at www.dyson.com and check out our support section.
Kind regards
Darran
Jan 30, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC14 Bagless Upright Cyclonic Vacuum Logo
1,240 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
