Question about H2O Audio Komatsu Forklift Starter Parts 160 H20 Etc Engine
Excavator Komatsu Pw -130es electronic problem wont move.
Hi ! I have an excavator make Komatsu Pw -130es 1999 U.K made version. It has a burned out starter, what i want to know is , whether this starter is causing the fuse's to burn out which move the mahine back n forth? The wires get heated up , and in turn blows out the fuse within seconds of starting the machine. I finally found that the starting motor is the problem, but can it cause the malfunction of its movement? Since the machine is electronic.
Your help is very much appreciated!
Thanks.
Komatsu excavator
Could be a bad starter motor the brushes get worn out inside the starter motor try tapping on the starter with a hammer not to hard if it starts after you tap on the starter toward the back were the brushes are then you have a bad starter or you could have a bad starter solonoid hope this helps
Jan 29, 2014 | Toys
Replacement tracks needed for my 1;32 scale pc450lc !
Try reconnecting the tracks togeather it may not be easy but my Komatsu toy model excavator has the same problem one of the tracks got jammed while i was playing with it so I'm trying to put them back togeather i also have the PC 450 LC model.. I managed to reconnect some of the tracks togeather but its not easy and be careful not to loose and parts
Sep 06, 2011 | Joal 1/32 Komatsu PC 450 LC-6 Excavator
Control levers some wilnot move komatsu pc50uu-1excavator
pressure reliefe valve is malfunctioning as this can be one to several you need special hydraulic meters to know (best bet take it to the dealer) I know that stinks but as they become more complicated so does the repair process
If I helped at all please give me a response negative or positive ( i can handle it ,thanks )
Dec 05, 2009 | Garden
Possible problem of slow movement of Hydraulic cylinder and Travel of Komatsu excavator
hi, have u checked ur fluid and filter, if so u need to check the pressure.
u can buy a normal guage and and get a bit of pipe made up to suit ur job.
you might be able to get away by increasing the spool valve. but if ran low on hydraulic then it is a new pump.
Aug 29, 2009 | Norscot Group/Cat Norscot Group 1/87 Ho...
H2O Audio Komatsu Forklift Starter Parts 160 H20 Etc Engine Logo
162 people viewed this question
Top H2O Audio Toys Experts
Andrew Taylor
Andrew Taylor
Are you a H2O Audio Toy Expert? Answer questions, earn points and help others
