Question about Jenn-Air JGR8855BDS Gas Kitchen Range
On my Caloric gas stove Model RSK 3700 UWW, a control knob has broken off leaving about half of its stem (or tongue) tightly lodged in the stove's female control- knob socket. How can I extract this broken stem so that I can install a new knob?
Unfortunately you can't remove or replace these buttons, no parts seem to be available anymore. Keep a match stick handy to stick in the hole and press the leftover bit.
Posted on Aug 30, 2012
Gas won't stay on when I release knob
The old stoves.........so easy to work on and gain access to all the parts, etc. On the newer stoves, you'll have to get to where the knob goes onto the gas stem, and behind it----where the stem connects to the actual gas line inside the stove.. If you can do that, fine. Then, clean the stem, especially the nozzle. Check to see if it works before putting everything back together. If that doesn't solve it, you'll have to take the nozzle off and inspect the gas line that connects to the nozzle. Clear any gunk away, and do the same with the interior of the nozzle.........then reconnect, and test. If that doesn't solve the problem, you'll have to call a tech to come out.
Dec 08, 2015 | Kitchen Ranges
One of the nobs on the front of my gas stove is broken and i would like to know where i might get a replacement on ? the burner still works if i push the nob back on and turn it but it is broken in half...
Hello Danny, I have seen replacement knobs at Home Depot and Lowe's Hardware. Write down the make and model number of your stove and take a knob with you to compare.
Mar 24, 2015 | Kitchen Ranges
How do I fix the broken oven knob on my GE XL44 oven?
First you need to check the value body (around the value stem) for leaks.. you can use soapy water, your nose for smell...if you suspect a gas leak... turn the gas off to the appliance (located behind the stove) and call your gas supplier or a service tech...
You can use a thin pair of needle nose plyers to hold the stem.. or an easier way is to cut a playing card in half, poke a hole in the middle of it so it will slide over the stem... cut a line for the edge of the card to the hole so you'll be able to pull the card out from under the installed knob...
Jun 21, 2014 | GE Profile Spectra JGBP90 Gas Kitchen...
30 yer old caloric stove wher light pilot
http://www.partselect.com/Caloric-Stove-Parts.htm
Jan 04, 2014 | Kitchen Ranges
My oven wont turn off from the knob it keeps turning
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Mar 03, 2013 | Ovens
I have an stainless LG gas range and the knobs are loose and crinkled. LG will not replace them even though it is within the 1 year warranty period. They want to sell me a set for several hundred dollars....
I have the same problem. I have gone thru 2 sets of knobs for my LG Gas Stove. Even when I put JB Weld inside the knob to hold it together the knobs only last for 7-8 months of use. I am looking for a universal know with the same stem configuration to slip onto the shaft of the LG stove. It looks like a D
Jun 11, 2010 | LG LRG30855ST Stainless Steel Gas Range
I have a Caloric Heritage Series gas stove in which the oven will not light but the broiler does work. This stove has a analog clock and we have no idea what the model is. Please help us. Thank you,...
We replaced the igniter which I bought from the appliance repair service. We now have a working oven.
Thankyou for responding to my email.
Cheryli
Dec 29, 2009 | Ovens
Looking for a Oven knob for the Caloric Presige
http://www.appliancepartspros.com/partsearch/
or
http://www.expertappliance.com/caloric-stove-parts.html
Oct 18, 2009 | Ovens
Can't Remove Broken Electric Stove Burner Knob
Spray each of the screws with a little WD40, available at any autoparts store. This will dissolve any rust that may have formed. Leave it over night. Then loosen the screws and the knob will come off.
May 07, 2009 | Kitchen Ranges
Jenn-Air JGR8855BDS Gas Kitchen Range Logo
434 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
